GPU Shims
  • thesloc
    Banned
    • Dec 2011
    • 587
    Re: GPU Shims
    I have reballed countless D630s/620s. That epoxy stuff is nonsense. All you have to do is preheat the board and remove it with tweezers or whatever you can.
    • thesloc
      Banned
      • Dec 2011
      • 587
      Re: GPU Shims
      But if you're stubborn so be it, I'm just trying to be of some help
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Re: GPU Shims
        sigpic
        (Insert witty quote here)
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Re: GPU Shims
          got the pads in... what the buddy didn't tell me was that they were part of an NOS d620/d630 nvidia heatsink that he happened to have... not a used pull, brand new (as in no die marks on any of the pads).
          when I pulled off the old heatsink, there was a mat of dust covering about 30% of the inlet of the heatsink...
          so far my temps have been not too bad... the gpu got up to 72C during a youtube video but when not giving it much load it is staying about 60-65 ish.
          sigpic
          • thesloc
            Banned
            • Dec 2011
            • 587
            Re: GPU Shims
            • popeye
              • May 2011
              • 155
              #26
              Re: GPU Shims
              Hi ratdude747
              I have done some experiments in the past on the HP laptops that I get in for repair after correctly cleaning out the by takeing it apart replaceing any heat sink compound with the one i have used for the last 30 odd years only ever baught three 25g tube last a long time I use less than the manufacturers when I have assembled it I then check that the rubber feet are in tackt if not I replace then so the laptop is off the bench surface I messure the temp by the laptop exaust grill I then put the laptop on a lsaptop stand wich raises the back up then did the same check the results were with out stand the temp was about 3 or 4 times higher. so I recomend to all my trade and public customers to get a staad cost here UK £1 less than 2$ us and never put a laptop on a bed carpet your lap air needs to flow. and if fan etc; cleaned regular. you will have your laptop running a lot longer hope this helps a lot of people.
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                Re: GPU Shims
                Originally posted by popeye
                Hi ratdude747
                well, I know not to use it directly on a bed... that defeats the purpose of the fan and will fry a laptop in a month.... as for the temps, I was using lm-sensors to read the laptop's sensors... example:
                $ sensors
                acpitz-virtual-0
                Adapter: Virtual device
                temp1: +44.5°C (crit = +99.0°C)
                nouveau-pci-0100
                Adapter: PCI adapter
                temp1: +65.0°C (high = +100.0°C, crit = +110.0°C)
                coretemp-isa-0000
                Adapter: ISA adapter
                Core 0: +44.0°C (high = +100.0°C, crit = +100.0°C)
                Core 1: +44.0°C (high = +100.0°C, crit = +100.0°C)
                Originally posted by thesloc
                ummm... ok? I was just saying that the parts came in and all was well.
                sigpic
