Clevo M77Sx, Fan Do Not Turn On When Power On Process, Sometimes it turns on!
  • badcaps2012
    • Dec 2011
    Hello Guys,
    i have some issues with my new latop which i bought from ebay as used.
    Model: Clevo M77S 17"
    mainboard nr: nkm770su8k00209
    6-71-m74so-XX-XX
    Some Info:
    Bios revision: 1.00.09NX
    KBC/EC Firmware Revision: 1.00.05
    I got a t3200 @ 2ghz
    VGA Card: nVidia 9300M GS
    VBIOS Revision: 62.98.2E.00.A1
    VBIOS Build Date: 08/01/08
    Sometimes the laptop turns on and it runs into windows.
    But sometimes it is not booting although I press 10 times the power on key.
    What I did`?
    I opened the Notebookcase and controlled the Fan-Voltage and Fan-speed .
    The Fan do not turn on. I measured the voltage on the red and black pin when i push the power on keytop and leds lights up and dvd is searching...i can measure only 0,5Volts. I think the fan need 5Volts ?
    Why do not starts the fan to run during the power post process? And when it runs into windows it does not start the fan also.
    I checked the temperature during my observation whith opened notebookcases.
    The cpu and gpu getting very hot, but i shuted the notebook down to not burn the cpu and gpu.
    Is it possible that the guy flashes the wrong bios or this bios do not turn the fan on ?
    Would be happy if you have some information for me to solve the problem?
    might be that i reball the gpu? i am confused why the fan do not goes on during the power on phase ?
    TIA
  • badcaps2012
    • Dec 2011
    Re: Clevo M77Sx, Fan Do Not Turn On When Power On Process, Sometimes it turns on!
    Okay Guys,
    i disassembled the notebook again and found out that the notebookcase
    fits not rigid in the case. The Mainboard is round a bit 200 mm x 200 mm small and placed into the left corner of the bottom-case which is 450 mm x 300 mm case, i mean a lot of space from the mid to the right side. The Mainboard is only half size of the case is..
    You twirl the case on a easy way if you press on the bottom right corner of the notebook, you can see that the upper left corner of the notebbook mainboard moves a little bit.
    Exactly on the upper left corner is the power supply whre the 19 V jack is.
    I am thinking that one smd part in the powersupply has not full contact to the motherboard. I found also out that 20 mm from the power input is mounted a 10 x 10 mm^2 chip it is called SC452-0828-CC12488-1.
    Is this the powerswitch or maybe the Bios?
    I do not know, but it seems that in the moment of moving the Notebook (not softly) the notebook fries and reboots.
    At the moment i assembled it fix and the Notebook starts when i press 2-5 times power-key.
    That means that something of the soldered parts or part loose the contact.
    Should i catch may fan-heater and try to heat the power area up?
    To resolder, i know that i am a rookie.
    Yesterday i rund windows xp on it and start 3 times the 3dmark06 benchmark programm to look if the problem lies on the GPU-Craphic card. But it runs very well the fan colled the cpu and gpu not over 63 GRAD CELSIUS, the processor was round about 55 Grad Celsius.
    I mean when it runs it runs whitout problems. But when i sut it down and the notebook cools down and then i try to start again it is possible that i need 2-6 times to boot this machine.
    I would be happy when you guys out there would give me a idea?
    Or should i dissassemble again and makes some pictures.
    TIA
    • senchire
      • Dec 2012
      • 190
      • Bosnia
      Anyone faced this laptop, it start sometimes (when it starts it frezzes later on).
      Ram changed, and cpu (no bga yet touched).
      Had x2 SiS671 and nvidia 9300m GS.
      • blasterboomer
        • Dec 2013
        • 135
        Does it just hang? or does it show graphical corruption
        • senchire
          • Dec 2012
          • 190
          • Bosnia
          Sadly only freezing.
          Thought its the CPU but its not, neither the bios, neither the hdd and neither the ram's .
          Only think are the BGA's or voltage drop around the board.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            My money's on the northbridge. As far as i've heard those crappy SiS chipsets need to be replaced, they will most likely burn in the reballing process. I haven't had any of them in so i cannot comment myself.
            A working TV? How boring!
            • senchire
              • Dec 2012
              • 190
              • Bosnia
              Well its the nvidia 9300 in the end, forgot to report . Reflowed and works pico bello.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                Lucky.
                • senchire
                  • Dec 2012
                  • 190
                  • Bosnia
                  Well this board is strange, after reflow it works for few boot ups. Now I am wondering is it maybe that the BGA needs reball, or some other component gets heat during this period and works for a bit (few hours).
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    My money's still on the northbridge. But also, the 9300m is on the defective chipsets list from nvidia so it may need replacement. If it's the 9300m that's broken, reballing will not help.
                    Try the following: Use your hot air station to heat just the die of the nvidia GPU for a couple minutes. Temperature should be set around 300C or so, nothing that would melt solder from a distance. Then fit the heatsink without allowing it to cool and power it up.
                    If it works now and then stops working when it cools down, the nvidia's broken.
                    • elab23
                      • Mar 2013
                      • Phil
                      hello laptop troubleshooting experts, I have Clevo M74S, can be powered on, power indicator, bat. charging indicator but no display on screen, I need your idea on resolving this problem, thanks!!!
                      • senchire
                        • Dec 2012
                        • 190
                        • Bosnia
                        I'dbet not on the nb i have reflowed it and it didn't work even for an hour. Heating nvidia chip gets it to work. Safe bet needs a new one .
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3581
                          • slovakia
                          did u make PROPER reflow or just light heatup?
                          • senchire
                            • Dec 2012
                            • 190
                            • Bosnia
                            Ofc proper, won't reball it yet since the client isn't responding on the price.
                            Will give it today a "light heatup" as you said, to refer will it start if it starts don't have to look any more.
                            As Unique said reball isn't really worth it (1-3 months) isn't really a fix.
                            • senchire
                              • Dec 2012
                              • 190
                              • Bosnia
                              Ok I skipped the "light heatup" and went again for a reflow but with bigger dwell time on liquid phase.
                              Results = laptop works. So will offer a reball with a pinch of salt or chip replacement.
                              • huzo
                                CLEVO N970TF turns fans to the full and goes of
                                by huzo
                                The laptop is CLEVO N970TF with i5-9400, RTX2070, i haven't disassembled it yet to know what is the board number, i will update that later, but the issue is laptop turns on normally and works for about 2 minutes,then both fans turn on to the max and in 30 seconds laptop shuts down! Nothing is warm or even close to overheating...
                                i manage to get linux up and running and monitor the temperatures from all sensors, and the peak one is 51 celsius from a cpu cores...
                                So something is acting up and thinks the laptop is overheating? How to foul the board into thinking everything...
                                03-06-2024, 05:28 AM
                              • Stephen
                                MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                by Stephen
                                MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                03-15-2024, 09:37 AM
                              • Günter Schuch
                                searching for Schematics & Boardview for Clevo P641HK1
                                by Günter Schuch
                                hallo leute ich habe ein problem mit meinem laptop der marke Schenker XMG P407 und zwar ist mir anscheinend der Grafikchip gtx 1050ti der direkt auf dem motherboard verlötet ist kaputt gegangen sie ist im Gerätemanager nicht mehr aufgelistet. deshalb hoffe ich hier unterlagen für das gerät zu finden. soweit ich herausgefunden habe wird die Platine die bei der firma Schenker verbaut wird von Clevo gefertigt und zwar mit der bezeichnung "Clevo P641HK1" ich hoffe auf eure hilfe und bedanke mich.
                                Hello folks I have a problem with my laptop of the Schenker XMG P407 brand...
                                05-14-2025, 06:34 AM
                              • www
                                LG L192WS-BN backlight turns off after 1 second
                                by www
                                I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                03-24-2024, 05:26 PM
                              • Razor0601
                                Clevo P775TM1(XMG Ultra 17) Fans 100% and then turns off
                                by Razor0601
                                Hello, I have a problem with my P775TM1. When I turn it on the display stays black, after a while the fans spins at 100% and the led is blinking orange. After a few seconds the laptop turns off. CPU, RAM and GPU are working fine in another P775TM. I have also tried a cmos reset and flashed the Bios to the newest XMG Ultra Version.
                                Can anyone help me to find a solution?
                                05-19-2022, 08:16 AM
