Clevo P775TM1(XMG Ultra 17) Fans 100% and then turns off
  • Razor0601
    • May 2021
    • 34
    Hello, I have a problem with my P775TM1. When I turn it on the display stays black, after a while the fans spins at 100% and the led is blinking orange. After a few seconds the laptop turns off. CPU, RAM and GPU are working fine in another P775TM. I have also tried a cmos reset and flashed the Bios to the newest XMG Ultra Version.
    Can anyone help me to find a solution?
    • 21517
    Re: Clevo P775TM1(XMG Ultra 17) Fans 100% and then turns off
    There`s a service manual/schematic here https://repo.palkeo.com/clevo-mirror...M1(-G)1123.zip ,log in with username: repo password: repo
    Follow the power sequence and see if any voltages are missing
    • Razor0601
      • May 2021
      • 34
      I flashed also another EC Version. Now on battery it starts for 2-3 Seconds and turns off. On A/C Adapter it turns on without pushing the power button and the fans are spinning with 100%.
        • 21517
        Flash the bios and EC from XMG.Don`t flash the ones from the repo.
        • Razor0601
          • May 2021
          • 34
          Why not?
            • 21517
            Why not?
            https://www.reddit.com/r/XMG_gg/comm.../xmg_vs_clevo/
            You can but you will lose the customised features if there are any for your model.
            • Razor0601
              • May 2021
              • 34
              I flashed Bios and EC and tried also my dump version again. But the old symptoms didn’t come back.
              • Razor0601
                • May 2021
                • 34
                What do I need to Programm via J_Flash1/2 connector? I want to flash the main EC.
                • Razor0601
                  • May 2021
                  • 34
                  So, the reflashing didn‘t work. Can you tell me where to measure the voltages?
                  • huzo
                    CLEVO N970TF turns fans to the full and goes of
                    by huzo
                    The laptop is CLEVO N970TF with i5-9400, RTX2070, i haven't disassembled it yet to know what is the board number, i will update that later, but the issue is laptop turns on normally and works for about 2 minutes,then both fans turn on to the max and in 30 seconds laptop shuts down! Nothing is warm or even close to overheating...
                    i manage to get linux up and running and monitor the temperatures from all sensors, and the peak one is 51 celsius from a cpu cores...
                    So something is acting up and thinks the laptop is overheating? How to foul the board into thinking everything...
                    03-06-2024, 05:28 AM
                  • costivl
                    Y50-70 turns on, no video, fans dont spin
                    by costivl
                    My Lenovo Y50-70 turns on but i have no video, fans dont spin, keyboard lights turns on, no ssd activity.
                    I removed battery, hdd, rams, bios battery, then pressed power button for 30 sec to drain out all energy, still same thing, i did check both mosfets on power module of the board, pq301 and pq302, i get 20,5V on all pins except one pin that have 8.7V
                    Connected external keyboard, tried on all 3 usb ports, no leds on the keyboard, neither numlock, checked voltage on usb pins, i only have 5.1V on 1 pin, rest 0V
                    I have 1.4v on PL502 with...
                    07-01-2024, 11:38 PM
                  • costivl
                    by costivl
                    Any ideas what to check more?
                    Thank You
                    06-13-2024, 11:25 AM
                  • Gigabit2
                    MacBook Pro Mid 2012 turns on, fans spin for five seconds and turns off, repeats
                    by Gigabit2
                    I have a MacBook Pro Mid 2012 with 820-3330-B board.
                    The laptop shows a green light on the charger, turns on and the fans spin for about five seconds. Then it turns off and this repeats over and over.
                    Before it turns off, the SuperDrive (DVD/CD drive) makes a noise like it does when it first turns on from cold (on a working machine).
                    I am stumped, can anyone help?
                    06-22-2022, 09:29 AM
                  • emil_t
                    RTX3090 working fine but fans not spinning
                    by emil_t
                    Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                    04-12-2024, 06:54 AM
