CLEVO N970TF turns fans to the full and goes of
  • huzo
    • Sep 2014
    • 185
    • CROATIA
    The laptop is CLEVO N970TF with i5-9400, RTX2070, i haven't disassembled it yet to know what is the board number, i will update that later, but the issue is laptop turns on normally and works for about 2 minutes,then both fans turn on to the max and in 30 seconds laptop shuts down! Nothing is warm or even close to overheating...
    i manage to get linux up and running and monitor the temperatures from all sensors, and the peak one is 51 celsius from a cpu cores...
    So something is acting up and thinks the laptop is overheating? How to foul the board into thinking everything is ok...
  • Razor0601
    Clevo P775TM1(XMG Ultra 17) Fans 100% and then turns off
    by Razor0601
    Hello, I have a problem with my P775TM1. When I turn it on the display stays black, after a while the fans spins at 100% and the led is blinking orange. After a few seconds the laptop turns off. CPU, RAM and GPU are working fine in another P775TM. I have also tried a cmos reset and flashed the Bios to the newest XMG Ultra Version.
    Can anyone help me to find a solution?
    05-19-2022, 08:16 AM
  • Rudolfl
    Clevo PC70DP issues
    by Rudolfl
    Hi all
    I have one of those machines. Clevo PC70DP.
    Machine starts, but turns off quite quick. Just before turning off one can hear fans are spinning at high speed. Can be turned back on again right away.
    So, feels like overheat problem.
    I cleaned up fans and heatsinks and replaced thermal paste. I can now see CPU runs cooler and machine stays on for longer, but still same.
    Few more findings:
    1. on-board NVIDIA card is not found. Not showing up in Windows or in BIOS.
    2. I tried to run CPU stress test. CPU stays at about 65 degrees. Works...
    07-16-2025, 01:43 AM
  • costivl
    Y50-70 turns on, no video, fans dont spin
    by costivl
    My Lenovo Y50-70 turns on but i have no video, fans dont spin, keyboard lights turns on, no ssd activity.
    I removed battery, hdd, rams, bios battery, then pressed power button for 30 sec to drain out all energy, still same thing, i did check both mosfets on power module of the board, pq301 and pq302, i get 20,5V on all pins except one pin that have 8.7V
    Connected external keyboard, tried on all 3 usb ports, no leds on the keyboard, neither numlock, checked voltage on usb pins, i only have 5.1V on 1 pin, rest 0V
    I have 1.4v on PL502 with...
    07-01-2024, 11:38 PM
  • costivl
    by costivl
    Any ideas what to check more?
    Thank You
    06-13-2024, 11:25 AM
  • Gigabit2
    MacBook Pro Mid 2012 turns on, fans spin for five seconds and turns off, repeats
    by Gigabit2
    I have a MacBook Pro Mid 2012 with 820-3330-B board.
    The laptop shows a green light on the charger, turns on and the fans spin for about five seconds. Then it turns off and this repeats over and over.
    Before it turns off, the SuperDrive (DVD/CD drive) makes a noise like it does when it first turns on from cold (on a working machine).
    I am stumped, can anyone help?
    06-22-2022, 09:29 AM
