HP G7000 Dead
  • fusionmax
    • Sep 2010
    • 42
    HP G7000 Dead
    I have a HP G7000 laptop here that is totally dead. Pressing the power button gives me nothing, connecting the AC adapter gives me nothing. No lights or anything.
    I have stripped the laptop and checked for anything obvious, I have also checked the solder joints on the mainboard and confirmed the power adapter is supplying the required 19.5v.
    Can anyone advise me on my next move?
  • gabik111
    ORD spotter
    • 142
    • USA / Poland
    Re: HP G7000 Dead
    Check AO4433 switching mosfets on power source side on mobo (just where power entering ). Did battery hold any power?
    Laptops and computers repair.
    • unlockdev
      • 81
      Re: HP G7000 Dead
      check power mosfets
      • gabik111
        ORD spotter
        • 142
        • USA / Poland
        Re: HP G7000 Dead
        If those are shorted you have to replace them (propably only one) for new ones. You can easly use AO4407 instead.
        • fusionmax
          • Sep 2010
          • 42
          Re: HP G7000 Dead
          I have found what I think are the equivalent parts on the mobo. I have attached a picture.
          The parts are labeled...
          AH5AJ
          FDS
          6675BZ
          Am i looking at the right thing?
          EDIT : I have also found a datasheet and am now pretty sure I am looking at the right thing.
          Any tips on how to test them?
          • gabik111
            ORD spotter
            • 142
            • USA / Poland
            Re: HP G7000 Dead
            That's right. You can use AO4433 or AO4407 instead of this.
            Measure resistance between pin 4 and 1,2,3 / between 4 and 5,6,7,8 / between 1,2,3 and 5,6,7,8. You got datasheet so you can see how it is look inside. If there is no resistance that component is shorted. Otherwise there should be some resistance one way .
            • fusionmax
              • Sep 2010
              • 42
              Re: HP G7000 Dead
              Any idea where I can get replacements in the UK??
              • gabik111
                ORD spotter
                • 142
                • USA / Poland
                Re: HP G7000 Dead
                I have no idea. I'm buying on ebay (imported from China of course) so I think you can try to find some on ebay (BTW I saw one guy from Portugal that was selling 4407's).
                • fusionmax
                  • Sep 2010
                  • 42
                  Re: HP G7000 Dead
                  Thanks for the suggestion, I spotted the guy in Portugal selling them and have ordered a couple.
                  Ill report back when I get them and fit them with the results
                  • FalconFour
                    • May 2011
                    Re: HP G7000 Dead
                    Well, I figure since this is a recent thread, I should pop in here too...
                    I have a DV4 that mysteriously stopped working after I let my roommate use it for a while (/headsmack). It had its fair share of thermal issues (poor thermal design - when will HP learn?), but charged/worked fine. It now does nothing but "zap" the adapter when I plug it in. Torn completely down, same thing. Measured current with a multimeter and it showed spikes of 2 amps but basically random figures, as the adapter cycled on and off rapidly (overload). Stumped. The DC-in plug on the mobo measured 0.5 volts after plugging in, 19v while unplugged from the board. Tested with another adapter and it did the same thing, but the adapter overloaded and powered-off immediately (high quality universal adapter with HP tip).
                    Looked over everything, nothing was burned. Nothing was spilled on it, not dropped, damaged, or anything. Well, I started ohm-metering the 8-pin SMT chips around the socket, and comparing it with the datasheets I could find. The chip marked "4433" and "BV8K2K" was the hardest to find; I thought BV8K2K was the P/N, since I couldn't easily search for "4433". I referenced the logo on it and found "Alpha & Omega Semiconductor" and ran a search on their site, found the AO4433 MOSFET. Bingo. Ohm-metered that chip, and all the source/drain pins were connected. Oops.
                    Unfortunately, I only found the "cause" in the process of confirming its destruction... with a drop of my "sledgehammer" pencil soldering iron, I ended up sliding the chip into 2 pieces... it literally slid apart on the board. Wel'p, there's our problem! Or at least, the culprit. Sadly, in the diagnostic process, I also destroyed the "gate" pin of a second MOSFET, a SI4835DY, in trying to temporarily lift the pin; it just crumpled and broke off, taking the board trace with it. So I'm probably going to have to replace the whole mobo.
                    But I figure I should chronicle my efforts here, for anyone else searching for the same thing Just chalking up another failure of this chip, I guess. I'd love to know what could've caused this blow-out though, if anyone has any suggestions...
                    • gabik111
                      ORD spotter
                      • 142
                      • USA / Poland
                      Re: HP G7000 Dead
                      I was talking with some guy on polish electronic forum and he had similar problem with NC6320. But he's still loking for cause.
                      Well , soldering things like those can be done by hot air station. That's the best way and more easy.
                      • mattbrad2
                        • Jan 2011
                        • 122
                        Re: HP G7000 Dead
                        NC series have problems with Maxim power controller. Its a BGA design so a reflow will work. Actually one I fixed with a hairdryer (was on vacation - had to improvise).
                        • gabik111
                          ORD spotter
                          • 142
                          • USA / Poland
                          Re: HP G7000 Dead
                          Well , MAX IC in NC series is SMT design component actually. I repaired couple of them with regular pencil soldering iron + flux to improve effect and do not solder together IC's tips.
                          • fusionmax
                            • Sep 2010
                            • 42
                            Re: HP G7000 Dead
                            Just a quick note to say my original issue with the HP G7000 was resolved by fitting those new parts.
                            Thanks for all your help
                            • amirbassim
                              • 22
                              • morocco
                              Re: HP G7000 Dead
                              hello, friends
                              please, what's the difference between AO4433, AO4407 and PF85Z FDS 6675BZ, 6675A, 6675S?
                              I can(t find in Morocco the AO4433 or AO4407, only I have 6675A or 6675S!
                              quick answer please!
                              thanks!
                              • MARKYMARK
                                • Nov 2012
                                • Great Britain
                                Re: HP G7000 Dead
                                Hi
                                I have the same problem. The two mosfets one shorts between pin 4 and 5 or Gate to Drain. I have found these mosfets in the UK at Farnell components for £1.30 Each http://uk.farnell.com/jsp/displayPro...ss_price=true- Hope this helps. The model number is FDS6675BZ. It is similar to the A04433 or A04407 but going to order direct replacements. Thanks for the thread.
                                Mark
                                • lord
                                  • May 2011
                                  • 319
                                  • Croatia
                                  Re: HP G7000 Dead
                                  I look in the datasheet for its specs (P-type, 30V 10A) and find same or stronger (usually on other boards that lay around and replace. Works every time.
                                  • double_DD
                                    How can I be sure that my EC chip is dead?
                                    by double_DD
                                    As the title suggests, how can I be sure that my EC chip is really dead?
                                    I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                    Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                    03-12-2025, 07:47 AM
                                  • disorder
                                    ps5 edm-033 dead after hdmi/usb ports destroyed
                                    by disorder
                                    hello guys,
                                    i need help to repair a edm-033 ps2
                                    history : as always hdmi port and usb ports destroyed after unplugged
                                    after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                    so i changed it
                                    now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                    but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                    i don't see any projection of liquid metal on pcb.
                                    01-14-2025, 12:48 PM
                                  • cezirmed02
                                    HP 15s-du3032TU charging stuck at 0%, "+12.6V_BATT_CHG" missing, 0.20V at battery point
                                    by cezirmed02
                                    This is hp 15s i5 11th Gen motherboard LA-K201P device is booting up fine and working normally as long as its connected to the charger. On my initial check I thought it was dead battery issue and externally charged each cell and then we have 9% battery percent but as soon as I unplugged the charger device turned off immediately then I checked the voltage motherboard was supplying to the battery and it was 0.2V then I followed the 19V supply from the charger and throughout the motherboard 19V supply was okay then at one particular mosfet (PQB13 image attached below) 19V goes in and comes out 0.2V...
                                    03-28-2025, 08:23 AM
                                  • zunasthegreat
                                    Chieftec GPS-450-AA with dead 20N60C3
                                    by zunasthegreat
                                    Hello everyone hope all doing well!
                                    I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                    09-01-2024, 07:12 PM
                                  • Beton
                                    Finding a dead short component
                                    by Beton
                                    Hi guys!
                                    I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                    So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                    I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                    I have a bench PSU and if I try to inject voltage the voltage...
                                    12-10-2021, 01:05 PM
