DV2000 no light on screen
  • unlockdev
    • 81
    I Hav Problem with 2 Dv2000 Laptop same problem I Change the inverter and screen to but nothing always no light Problem in the motherboard
    Any one can Help Please
  • dobber
    • Jul 2008
    • 83
    Re: DV2000 no light on screen
    I suppose it is a AMD Proccessor with nvidea video chip. If it does, the Video Processor is the issue, and will need reflowed or reballed.
    • yyonline
      • Jul 2009
      • 692
      You should also check the video ribbon cable, as the video signal and inverter power runs through them. They can sometimes go bad from too much flexing when opening and closing the laptop lid.
      • gabik111
        ORD spotter
        • 142
        • USA / Poland
        Main problem of some DV-series is the GPU. Some nVidia GPU's has problem that nVidia made faulty series of GPU's installed on some laptops mobo's. Reballing with no-lead balls solving the problem for a while. On faulty chip some connections pad separating from the ball and makes crack between chip pad and mobo pad. Best choice is replacing GPU witn new one with better pads.
        I'd like to say Hello for everyone. It's my first message on this forum , I'm new here.
        And sorry for my english , I'm from Poland.
        Laptops and computers repair.
        • unlockdev
          • 81
          Hello All
          The problem is in the motherboard bi cos laptop is working fine just no light on screen like inverter problem i see hp logo but light is bad
          • unlockdev
            • 81
            Notice
            LCD screen has no light (everything else OK) I Check inverter 6pins
            pins1-2 nothing pins 3-4 3.3vcc pins 5-6 19vcc
            • gabik111
              ORD spotter
              • 142
              • USA / Poland
              Looks like cold cathode (CCFL) died. If you got frequency range in your multimeter put piece of paper between measuring pins (stick them together with piece of paper between) , set up multimeter on "Hz" range , put measuring pins close to inverter (do not touch anything) and turn on laptop . If frequency will be shown around 60kHz then inverter is ok. If the CCFL is dead inverter will be work only in first 2-3 sec after you turned on laptop.
              • unlockdev
                • 81
                I have replace both the lcd & inverter but the samme problem a Friend tell me is an mb but i dont know it Thanks
                • gabik111
                  ORD spotter
                  • 142
                  • USA / Poland
                  What about external monitor?
                  LCD panel is directly driving by graphic chip so this might be a problem. Try to reflow it (or heat it up) , if this will help you need to replace graphic chip. You got nVidia G72M-V G3-64.
                  • unlockdev
                    • 81
                    im sure is not the graphic chip i hav already reball it big problem
                    • gabik111
                      ORD spotter
                      • 142
                      • USA / Poland
                      But external monitor is working ok?
                      Well , reballing doesn't help in some situations. nVidia made series of faulty chips that have bad pads (lead-free balls can't stick to them). You can reball them only with balls containing lead. But best choice is to replace graphic chip. If you got schematic track all way that is between graphic chip and LCD or power source and LCD.
                      • unlockdev
                        • 81
                        Problem is not bga i'm sure i hav 2 dv2000 some problem intel and amd my friend repair this problem but i lost his phone number is mb but i dont know where is
                        • gabik111
                          ORD spotter
                          • 142
                          • USA / Poland
                          Then you have to analyze schematic and look for bad component (s).
                          • unlockdev
                            • 81
                            the problem is an mcp for Voltage Regulator but i dont know it that need an oscilloscop to know it ican't find it with multimulter thaty the problem
                            • pariscy
                              • May 2011
                              HELLO.
                              did you find any solution?
                              i have the same problem and i change inverter,monitor,cables,resolve the gpu but same problem. is working fine on external monitor only.
                              thanks
                              • mattbrad2
                                • Jan 2011
                                • 122
                                I'd be interested to see what you guys find out about this. I've been working on these since they came out and have fixed hundreds of problems with them but never had one do this. Especially an Intel. That makes no sense. Are you *sure* the LCD/inverter are fine? Try this - bypass the inverter all-together. They sell simple external LCD inverters that have an AC plug on one end and an LCD backlight connector on the other. I'll get you a link on Ebay if you like but I use this all the time to test backlight problems.
                                • unlockdev
                                  • 81
                                  I Find solution and now my dv2000 working Fine
                                  Thanks for All
                                  • mattbrad2
                                    • Jan 2011
                                    • 122
                                    What was the solution??
                                    • unlockdev
                                      • 81
                                      the solution is to send 5vcc to inverter pins is 1-2gnd 3 is 5v that is on/off 4=3.3vcc 5-6=19vcc when u will check the inverter u will see 3.3v 3.3v 19vcc 19vc but you will need 5vcc to start inverter That all
                                      • kiranfocuz
                                        • Jun 2011
                                        • 12
                                        here is no problem with Motherbord mosfets , only issue with Nvidia chipset . try to heat 150 digree heat for 1 minut . and wait 2 or 3 minut . try to On your laptop display will come . this Solution for maximum HP DV nvidia chipset serios
                                        • mmccomputer
                                          problem with replacing lcd screen
                                          by mmccomputer
                                          I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
                                          otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
                                          If anyone has any information on the subject...
                                          12-15-2024, 03:44 PM
                                        • jimjoe123
                                          LCD TV Green/Pink screen problem
                                          by jimjoe123
                                          I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                          Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                          Then each time...
                                          02-23-2020, 01:29 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • Chrissygizmo
                                          Sony KD-55XG9505 lines on screen problem
                                          by Chrissygizmo
                                          Hello again everyone,
                                          This is my latest mission, to try getting this Sony tv back to normal working order…
                                          I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                          02-19-2025, 11:31 AM
                                        • Rav_tangle
                                          MacBook Pro 2011 turns on with keyboard light , screen dead
                                          by Rav_tangle
                                          Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
                                          I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
                                          Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
                                          is this...
                                          05-31-2024, 04:09 PM
