HP pavilion dv6000 power problems
  • salvador437
    • Oct 2010
    • 9
    hi to all, my friend has a hp pavilion dv6000 that wont turn on, when I plug the charger the light on the power jack comes up but the other lights like the one that show is charging not turn on and when I press the power button nothing happen, my friend told me that the problem start when he had the laptop turn on and he plug the charger, wen he turn the laptop off and tried to turned on the laptop will not turn on, I suspect of a fuse or a short but a don't know where to start and I will appreciate you advice. thanks again.
  • yyonline
    • Jul 2009
    • 692
    Re: HP pavilion dv6000 power problems
    Will it run on battery power? This is assuming you can find a charged battery or can use another laptop to charge the battery.
    The power jacks in laptops often go bad due to cracked solder joints, or the jack contacts lose their springiness.
    It looks like the DV6000 power jack is on a daughter card, which means you can replace the card at a modest cost and avoid soldering if you choose to go that route.
    P/N 431445-001 with 65-watt power adapter
    P/N 431446-001 with 90-watt power adapter
    Was the power button hard to press before it died? If so, the power button may be bad: P/N 431437-001
    This series may have Nvidia graphics, this generation of which are very failure prone, especially in laptops. Did the computer experience any video corruption issues before it stopped functioning? If so, you may want to research what is involved in reflowing the GPU chip. Check your model's specs first, I am not sure if all of the dv6000 series had nvidia graphics or just some models.
    • Gabriel
      • Jan 2010
      • 620
      • Norway
      Can you turn it on with the touch buttons ?
      I had a dv6000 that would not turn on with the powerswitch, I replaced the cheap Hp zif cabels under the keyboard with some I got on ebay.
      Never had that problem again.
      They were similar to these but I cant remember the sellers id.
      http://cgi.ebay.com/Power-Button-Rib...item3f064f5892
      • salvador437
        • Oct 2010
        • 9
        I test the power jack and is good and the the small board the jack is solder on look to be good because I toked apart and nothing look off of place and I toked the small daughter board and I plunged the charger an check for power on the par that connect with the mother board I cheeked the red and black wire and the multimeter comes up with 19V, for the ribbon cable a test the cables on continuity and the 2 cables test good. any other ideas. and thanks for reply.
        • dobber
          • Jul 2008
          • 83
          Does it have a AMD Chipset, becouse if it does, it could be the problem. I have a DV2000 that does it about every 5 months. Also Check to see if the power button ribbon to the board is good, they go bad a lot when they have been pulled out to many times. Also I just got a DV6000 a few weeks ago from the local recycler, that had the intel board that would not turn on, and the power would flash one time. I was able to buy a new one on ebay for 63 dollars, and now it is fine.
          • gretti
            • Jan 2011
            • 28
            Check the transistors opposite side of the board from where the DC cable plugs into the board. I have had to replace many of them.
            • ortiko
              • Apr 2014
              • 62
              • Greece
              I have the exact same problem as friend posted.
              Managed to replace a working ribbon cable with power button from a second laptop (dv6700) that i have and problem remains.
              The laptop doesn't start with battery
              Can someone guide me where to start and measure voltage or fuse on motherboard?
              • ortiko
                • Apr 2014
                • 62
                • Greece
                Later today i will post back with pics and schematic i found about dv6700 as i searched the forum almost all night long.
                I would be very grateful if someone could help
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  "Doesn't start with battery" is quite vague. Does it at least recognize the battery? Does the charge LED light up on the front?
                  A working TV? How boring!
                  • ortiko
                    • Apr 2014
                    • 62
                    • Greece
                    Sorry i mean that with power supply disconnected and only battery on laptop it doesn't power
                    No led powers on exept dc jack led
                    • ortiko
                      • Apr 2014
                      • 62
                      • Greece
                      Some photos of the motherbaord and link for the schematic :
                      https://www.badcaps.net/forum/attach...4&d=1356686752
                      • atsio
                        • Oct 2013
                        • 819
                        • Greece
                        Check PQ3. If allright, give voltage on all pins with only battery connected.
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          Is there a rodent repeller-like sound coming from the power brick when plugged into the laptop? (laptop shorting PSU?)
                          If there is, I'm afraid it's dumpster food!
                          And I just wiped the HDD and reinstalled Windows 7 on an HP Pavilion DV6000 laptop yesterday, IIRC.
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • ortiko
                            • Apr 2014
                            • 62
                            • Greece
                            Thanks Atsio for the reply.
                            All pins except one reads 12V on PQ3 with battery only connected.
                            No sound coming from the power brick.
                            Thanks for the response
                            • atsio
                              • Oct 2013
                              • 819
                              • Greece
                              Check voltage on pins 2 and 3 of PQ31, PQ32
                              • ortiko
                                • Apr 2014
                                • 62
                                • Greece
                                After searching the pcb about 15 min i managed to find the below in red circle but not sure if the right side one is PQ31.
                                With yellow circle is the PQ32 marking and suppose that below in red circle is PQ32
                                This Volt readings are with battery plugged. Without battery and only dc jack plugged no volt readings
                                • dj_ricoh
                                  • 2073
                                  you can trace where is the voltage coming from to that fet.
                                  if you can check it with a DMM on diode mode will be nice to see if its actually bad.
                                  When its not getting any voltage that does not mean its broken .
                                  • atsio
                                    • Oct 2013
                                    • 819
                                    • Greece
                                    The 5 pin one is PU7 with 5v on pin 5 and 3.3v on pin 3. Give voltage and to the rest of pins.
                                    PQ32 is on the left of it. To find which ones are on the right of PU7, you have to find the Z and R sections printed on the board which they define the layout of the smt's in those sections.
                                    • ortiko
                                      • Apr 2014
                                      • 62
                                      • Greece
                                      Only with battery on there is dc volts i attached on pic
                                      Without battery and only dc jack i get zero V at both FETS
                                      • ortiko
                                        • Apr 2014
                                        • 62
                                        • Greece
                                        Please have a look at the below pic i have attached for you.
                                        I have only 3.8V at one pin of PQ32 as i marked at pic. other pins are zero Volts.
                                        Maybe from this pic which is more clear you can identify PQ31?
                                        Best Regards
                                        George
                                          09-06-2024, 05:59 AM
                                          HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 02:15 PM
                                          HP Pavilion Power 580-071na Pavilion Power i5-7400 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Power 580-071na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-071na boardview and Pavilion Power 580-071na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 02:00 PM
                                          HP Pavilion Power 15-cb094tx Notebook 15 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Power 15-cb094tx Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Power 15-cb094tx boardview and Power 15-cb094tx schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 05:54 AM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
