HP OLED_EN Signal Missing 13-AW2007TU -DAX3ACMBAF0
  • sikocan
    • Oct 2019
    • 344
    Hi all, I need help on this case, I'd appreciate your time.
    Images for your reference are here:
    https://photos.app.goo.gl/dnpX1WMTgwE6aAq87
    History: Laptop comes in with no picture or backlight.
    Technician installs new screen, same issue. They tried 2 screens, same issue.
    It has come to me and I can see they only probed the fuse with multi-meter.
    As per attached schematics, I did some measurements for your reference.
    SM3201 Pins
    1 0
    2 0
    3 4.68
    4 17.59
    5 17.59
    6 17.59
    7
    8 5.59
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21 5.51
    22
    23
    24 5.49
    25
    26
    27
    28
    29
    30
    31 17.59
    32 4.49
    33
    34
    35
    36
    DIODES TEST:
    PD9203 BLACK ON ANODE - RED ON CATHODE 0.38V DROP
    PD9203 RED ON ANODE - BLACK ON CATHODE 0.10V DROP
    PD9202 SAME READING
    PQ9201 FDMC8032L REPLACED WITH SAME MODEL. in circuit measurements
    Resistance readings:
    G1 > S1 18ohms (Low isn't?)
    G1 > D1 9.27M
    S1 > D1 8.6M
    G2 > S2 18ohms (Low isn't?)
    G2 > D2 7.17M
    S2 > D2 6.82M
    SM3201A REPLACED WITH SM3201 DA1935 SMMS013
    ORIGINAL CHIP LABELLED SM3201A DA2027 SMPB00
    SM3201 Pins
    1 0
    2 0
    3 4.68
    4 17.59
    5 17.59
    6 17.59
    7
    8 5.59
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21 5.51
    22
    23
    24 5.49
    25
    26
    27
    28
    29
    30
    31 17.59
    32 4.49
    33
    34
    35
    36
    LVDS CONNECTOR
    1 0
    2 0
    3 0
    4 0
    5 0
    6 0
    7 0
    8 0
    9 0
    10 0
    11 0
    12 0
    13 0
    14 0
    15 0
    16 0
    17 0
    18 0
    19 0.08
    20 0.04
    21 0.04
    22 3.28
    23 3.28
    24 0
    25 3.28
    26 3.28
    27 3.28
    28 3.28
    29 3.28
    30 3.28
    31 0
    32 3.28
    33 3.28
    34 0
    35 0
    36 0
    37 0
    38 0
    39 0
    40 0
    (Pin 39/40 Resistance to ground 30M+)
    Schematic: https://www.badcaps.net/forum/showth...75#post1243675
    Last edited by Vesko356; 06-01-2023, 03:04 AM. Reason: Attached schematic removed and replaced with link.
  • sikocan
    • Oct 2019
    • 344
    Re: HP OLED_EN Signal Missing 13-AW2007TU -DAX3ACMBAF0
    I hope someone can shed some light on as to what's going on here.
    When the LCD is not connected, the Pin 14 of the SM3201A is not grounded. When the LCD is connected, it's grounded. This is an OLED model so there is no cap at PC9223, but PR9206 exists. It's 0 ohms. So when LCD is connected, it's grounded. I've checked the cable, continuity is good all the way on either side, no short, not touching ground. I've checked the Pin 8 of the LCD and it's grounded, same with another screen. To me this says the PMIC SM3201A knows there is a screen connected, is this correct?
    There is no datasheet for this chip. I don't have picture or backlight. Damn. Any tips?
    • JaroTech
      • Mar 2015
      • 351
      Hi, on the CN3401 connector, check if you have the voltages on it.
      • Sephir0th
        • Oct 2020
        • 1282
        The device completes the P.O.S.T. for sure?
        FairRepair on YouTube
        • sikocan
          • Oct 2019
          • 344
          Yes, it boots to Windows external screen.
          • sikocan
            • Oct 2019
            • 344
            Yes I've checked CN3401 area - no Voltages. Drives me crazy. A new screen arrived today. Same issue. I wonder if I replaced it with wrong chip, maybe SM3201A and SM3201 are different chip.
            • gurj1979
              Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
              by gurj1979
              Hey guys.
              Need help with this one.
              Fan not spinning due to missing PWN Fan signal.
              Also 5 seconds from powering up it freezes, unless in BIOS.
              But as soon as Windows starts to load, it will freeze.
              CPU is COLD / Room temp when it freezes.
              I've replaced the CPU, same problem.
              Replaced SIO/KBC IT8987e and reprogrammed - same problem.
              Replaced fan - same problem.
              Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
              Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
              08-19-2024, 05:22 PM
            • Fernon@Repair
              MSI mpg b560m bazooka motherboard RSMRST# signal missing
              by Fernon@Repair
              I have MSI mpg b560m bazooka motherboard . this motherboard RSMRST# signal missing . i already reprogram bios but same condition
              My Motherboard this power stages are ok ...but 3vsb voltage have 4.17v (image added)
              VCCRTC ok
              RTCRST# ok
              ATX_5VSB ok
              SIO_3VA ok
              3VDSW ok
              DPWROK ok
              SLP_SUS# ok
              VSB_ENABLE# ok
              5VDUAL ok
              3VSB showing 4.17V
              PCH_1P8_VSB ok
              PCH_VCCIN_AUX ok
              RSMRST# No voltage
              this all voltages are ok but RSMRST# voltage is missing i did try to re program bios and change io but same...
              06-03-2025, 10:49 AM
            • mohamed mm
              sony vaio mbx-247, missing S5_ON signal
              by mohamed mm
              Hi everyone, I hope you are having a good day.
              I have a laptop sony Vaio, DA0HK1MB6E0, MBX-247. REV: E
              The laptop suddenly shut down as the owner told me, so I did the normal check there is no short but the laptop it's not powering up and there is no light when I connect the adapter because there is no battery.
              so I checked.
              pu9:
              Vin: 19v
              Ldo: 4.89v
              Ref:1.99v
              Vcc: 4.89v
              Vdd: 4.89v
              output
              3.3v pcu.
              EN2: 4.89v
              but No
              01-19-2023, 05:17 AM
            • madura2010
              LA-G07FP ACIN signal missing
              by madura2010
              10th generation hp laptop(LA-G07FP motherboard) missing ACIN signal.charger light not blow.when pressing power button, only 3 blinks display on dc adapter bulb(only once).but not turning on.original hp charger attached.charging port perfect.
              19v (gate 25v) main power rail ok
              RTC section ok.
              3vldo ok
              5vldo ok.
              ECON missing.no 3v and 5v always voltage.
              REGN,ACDET perfect.but ACIN missing.No short in ACIN path(good impedence)
              Replaced the bq24725a charger ic.but no result.still ACIN not generating.
              is this sort of error occurs from...
              02-25-2023, 05:06 AM
            • Prott
              Surface 7 - missing S3 sleep signal, S4 present but weird
              by Prott
              Hey fellow Badcappers
              I am troubleshooting Surface 7 board (rev 1.0) which was working great until it experienced a short circuit due to a bad screen.
              Now it's missing SLP_S3 signal. Everything in the power on sequence works properly up until that signal.
              - The resistance to ground on the SLP_S3 line is >50 kOhms.
              - No shorts on any powerrails that I can find.
              - I get a proper clock signal on the RTC crystal (XTAL_2P) once the Surface gets power.
              - SLP_S4 is, suprisingly, present, but it looks very weird (jump up to 2 V for about...
              07-08-2023, 04:54 PM
