Surface 7 - missing S3 sleep signal, S4 present but weird
  • Prott
    • May 2022
    • 154
    • Czechia
    Hey fellow Badcappers
    I am troubleshooting Surface 7 board (rev 1.0) which was working great until it experienced a short circuit due to a bad screen.
    Now it's missing SLP_S3 signal. Everything in the power on sequence works properly up until that signal.
    - The resistance to ground on the SLP_S3 line is >50 kOhms.
    - No shorts on any powerrails that I can find.
    - I get a proper clock signal on the RTC crystal (XTAL_2P) once the Surface gets power.
    - SLP_S4 is, suprisingly, present, but it looks very weird (jump up to 2 V for about 10 ns and then plummets down to under 1 V).
    Do you have any idea or experience with similar issue? Thank you
  • Prott
    • May 2022
    • 154
    • Czechia
    Re: Surface 7 - missing S3 sleep signal, S4 present but weird
    UPDATE: It was a bios issue.
    • gurj1979
      Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
      by gurj1979
      Hey guys.
      Need help with this one.
      Fan not spinning due to missing PWN Fan signal.
      Also 5 seconds from powering up it freezes, unless in BIOS.
      But as soon as Windows starts to load, it will freeze.
      CPU is COLD / Room temp when it freezes.
      I've replaced the CPU, same problem.
      Replaced SIO/KBC IT8987e and reprogrammed - same problem.
      Replaced fan - same problem.
      Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
      Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
      08-19-2024, 05:22 PM
    • Fernon@Repair
      MSI mpg b560m bazooka motherboard RSMRST# signal missing
      by Fernon@Repair
      I have MSI mpg b560m bazooka motherboard . this motherboard RSMRST# signal missing . i already reprogram bios but same condition
      My Motherboard this power stages are ok ...but 3vsb voltage have 4.17v (image added)
      VCCRTC ok
      RTCRST# ok
      ATX_5VSB ok
      SIO_3VA ok
      3VDSW ok
      DPWROK ok
      SLP_SUS# ok
      VSB_ENABLE# ok
      5VDUAL ok
      3VSB showing 4.17V
      PCH_1P8_VSB ok
      PCH_VCCIN_AUX ok
      RSMRST# No voltage
      this all voltages are ok but RSMRST# voltage is missing i did try to re program bios and change io but same...
      06-03-2025, 10:49 AM
    • mohamed mm
      sony vaio mbx-247, missing S5_ON signal
      by mohamed mm
      Hi everyone, I hope you are having a good day.
      I have a laptop sony Vaio, DA0HK1MB6E0, MBX-247. REV: E
      The laptop suddenly shut down as the owner told me, so I did the normal check there is no short but the laptop it's not powering up and there is no light when I connect the adapter because there is no battery.
      so I checked.
      pu9:
      Vin: 19v
      Ldo: 4.89v
      Ref:1.99v
      Vcc: 4.89v
      Vdd: 4.89v
      output
      3.3v pcu.
      EN2: 4.89v
      but No
      01-19-2023, 05:17 AM
    • ferah831208
      lenovo legion legion 5 15ach6 no video output but completes post sequence
      by ferah831208
      Hello there, i'm stucked with a lenovo legion legion 5 15ach6, mb code NM-D562, after power button all voltages are correct, different power stages of cpu transitions are present, when pressing power button laptop turns off like everything is working OK. The owner referred laptop was working perfectly, turned it off one night and next morning had black screen but he noticed system sounds. He managed to open windows voice narrator and accessed control Panel and there is no display adapters or unknown devices of any type (not the NVIDIA or AMD igpu present). I measured all discrete Nvidia card voltages,...
      11-04-2025, 12:48 AM
    • Kooopa
      Acer Nitro 5 AN515-43 Turns on Then Off..
      by Kooopa
      Hi! I'm back again... so I solved my previous issue but now it's back with a vengeance...
      First, history... previous issue was dead motherboard, blinking power LED, no fan spin nor LED backlight, which was caused by a missing SLP_S5#. This was fixed when I replaced the RTC crystal.
      Which brings us to the present. The screen started glitching every other 2 seconds. The screen corruption looks like the horizontal pixels/scan-lines are being shifted to different spots. This also happens on the BIOS setup. So I thought, "Okay, this might be my LCD since the thing has...
      10-06-2024, 09:44 AM
