MacBook Pro 16” 2019 Boots installs os Catalina but won’t install Ventura or lower.
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    So got an issue, did a DFU recovery for a 16” we have.
    It will install Catalina from internet recovery perfectly fine.
    Tried upgrading to Ventura, no bueno, so created bootable installer of Ventura. Nothing it just gets hung up at the half way point for over 24 hours.
    No water damage on board. Board is clean. Any idea why this is?
    All ports works
    Did a DFU RECOVERY AND RESTORE, twice with success and successfully reinstalled Catalina. But it seems it won't install anything higher. Any suggestions would be great.
    Fans spin normally, heat is normal etc. no cpu panics or gpu kernel panics.
    Also to add, did a download (fresh download from Apple servers of Monterey, and Ventura) and those wont install either gives us errors.
    Ok update, external USB Monterey or other installers will not load. They get hung up. This is a new for us since the board seems fine. Would love input about this.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Re: MacBook Pro 16” 2019 Boots installs os Catalina but won't install Ventura or lowe
    Computer restarts and fans spin quick when trying to install then it just loads then gives and error. Then it loads Catalina fine. It will not install Monterey, or Ventura. Catalina loads fine which is off. Lol the reason why we want this fixed is it has 64GB of ram i9 2.4Ghz 2TB ssd 5500M 8GB. So we want to fix this lol
    sigpic
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 674
      Would like to bump this and hope anyone has experience this before in this model
      sigpic
      • ugamazing
        • Jun 2013
        • 171
        • usa
        GPU or CPU failure.
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 674
          Originally posted by ugamazing
          GPU or CPU failure.
          Where do you believe this is the case when it runs 100% perfectly on Catalina without issue?
          sigpic
          • mon2
            • 14588
            See if this helps:
            https://www.macworld.com/article/672...orted-mac.html
            • Stephen
              Meow Meow MEOW!
              • Apr 2020
              • 674
              I don’t think this relates to this computers issue since it is supported for those OS installs
              sigpic
              • ugamazing
                • Jun 2013
                • 171
                • usa
                Is this an unlocked/bypassed unit, or clean? Nothing done to the board at all--no repairs, no work done, etc?
                It will end up being a CPU, GPU or possibly a PCH fault. This assumes nothing goofy like a bypass or anything.
                • Stephen
                  Meow Meow MEOW!
                  • Apr 2020
                  • 674
                  Clean, No bypass. No work done to board. It boots fine into Catalina and plays videos and music without any issue and doesn’t crash. It just crashes when you try to install any newer OS.
                  sigpic
                  • piernov
                    • Jan 2016
                    • 4437
                    • France
                    Memtest?
                    • Stephen
                      Meow Meow MEOW!
                      • Apr 2020
                      • 674
                      Hmm, did a diagnostic test with Apple diagnostic test when booting and pressing D. Logged in and and it passed without any faults. I guess we can try a separate memtest.
                      Also did a DFU restore with latest patch so clean board
                      sigpic
                      • ugamazing
                        • Jun 2013
                        • 171
                        • usa
                        Can you force the board to fail (or show any weirdness) in any other way? Running Heaven for hours, etc?
                        With Catalina installed (and working), can you try to install Ventura over Catalina (don't wipe the SSD), then wait for it to crash/freeze, then view the crash report? If so, post it here. Just trying to get more information on the actual crashes.
                        • Stephen
                          Meow Meow MEOW!
                          • Apr 2020
                          • 674
                          I'll take a look tomorrow
                          sigpic
                          • Stephen
                            Meow Meow MEOW!
                            • Apr 2020
                            • 674
                            Board refuses to fail. Will only fail trying to install any os higher than Catalina.
                            Also no kernel panics, plugged up to external monitor to test GPU, nothing no issues.
                            [Mod. Edit-Vesko356] Use if you want to add something instead of posting a new reply!
                            sigpic
                            • Stephen
                              Meow Meow MEOW!
                              • Apr 2020
                              • 674
                              Update:
                              Board installed MacOS Big Sur after a security update but however it crashes when trying to install Monterey or Ventura.. currently now on Big Sur without issue. However I did replicate a kernel panic. Picture attached.
                              Update: tried installing Ventura. This is the error.
                              Pic attached
                              Going to try safe mode install….
                              Edit:
                              Safe mood install failed.
                              sigpic
                              • dellxps15
                                • Feb 2014
                                • 1596
                                • italy
                                are u able to install osx on a usb hard drive ?
                                • ugamazing
                                  • Jun 2013
                                  • 171
                                  • usa
                                  This may be a RAM failure after all, as piernov alluded to, but could still be a CPU issue. I'd run memtest over and over (3-5x) to start with. If nothing pops up, this board would be a good reflow candidate. Reflow RAM first and test. If that doesn't resolve the issue, reflow the T2 and try again. If that doesn't work, I'd suspect CPU at that point. You can then try to reflow the CPU, but generally this will only help confirm the issue, not resolve it. If reflowing CPU changes the symptoms in any way, I'd replace the CPU. Reflowing RAM/T2 *can* resolve, especially if the board was ever flexed harshly on the T2-end.
                                  Did you confirm absolutely zero damage to the board?
                                  • kevingill
                                    • Jun 2013
                                    • 152
                                    • England
                                    Got to be something with the DFU recovery in the first place?
                                    Diagnostics comes back clear?
                                    It's normal to set the date back on earlier versions of MacOSX, but worth checking the date is correct for later versions?
                                    The disk was reformatted APFS?
                                    • Stephen
                                      Meow Meow MEOW!
                                      • Apr 2020
                                      • 674
                                      Testing further. Would love to figure out this problem so we know how to address it in the forums from here on out for anyone else. We just fixed another board with no power but this board works lol and operates perfectly fine, we are assuming it may be something with the board but there is no water damage whatsoever. We did get it to boot and operate fine on Big Sur. Nothing past that though. Still trying to figure it out. Going to do a MEMTEST Monday.
                                      sigpic
                                      • spidertnt
                                        • Jul 2016
                                        • 34
                                        How did you install Big Sur ? ....from USB installer .
                                        I thought Apple stopped allowing USB installing of OS since T2 chip ...only allowing internet recovery mode for OS installs.
                                        You can install older OS using DFU mode and IPSW files
                                        watch this https://www.youtube.com/watch?v=q-FsB2onSx0&t=1s
                                        Link to files
                                        https://mrmacintosh.com/apple-silico...iles-database/
                                        • duwane
                                          A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
                                          by duwane
                                          Hi All.
                                          Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
                                          The issue:
                                          Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
                                          10-26-2022, 07:02 AM
                                        • japlytic
                                          DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                                          by japlytic
                                          In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                                          Tried (only with keyboard/mouse connected):
                                          • BIOS + database update
                                          • Using latest Windows 11 image built with official image creation tool
                                          • Previous setup version for Windows 11 installer
                                          • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                                          • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                                          • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                                          06-19-2025, 04:59 PM
                                        • 24gsm
                                          MacBook Pro A1708 install macos fail
                                          by 24gsm
                                          hi to all
                                          i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
                                          after enter to recovery and format hdd 1to .
                                          after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
                                          can help please
                                          Serial Number: FVFXP0U0HV2J
                                          Config Code: HV2J
                                          Find My Mac: OFF
                                          04-16-2025, 03:57 AM
                                        • tommy97
                                          ASUS FA507R - BLOD, cannot install windows
                                          by tommy97
                                          I have an ASUS FA507R in for repair where I’m unable to install any operating system. The laptop works fine when booted from an external Windows or Linux drive, but any attempt to install on an NVMe SSD fails.
                                          I’ve already tested with three different SSDs (Gen 3 and older), and the issue persists. The laptop originally came in with a faulty SSD showing 0% health....
                                          08-22-2025, 07:55 AM
                                        • pepebmx
                                          ThinkPad T14 Gen 3 - Boots Only on Charger
                                          by pepebmx
                                          Subject: Lenovo ThinkPad T14 Gen 3 - Boots Only on Charger, Fan Spins Full Speed with Battery
                                          Laptop: Lenovo ThinkPad T14 Gen 3
                                          Serial No: PF-437QTG
                                          PCB: NM-E441 Rev 1.0 (JT4C1/JT6C1/JP6C1)
                                          Extracted BIOS: Will upload tomorrow
                                          BIOS Password: None Issue Description:
                                          • Boots only on charger → Works normally when connected to AC.
                                          • With battery connected:
                                            • Fan spins at full speed, no display.
                                            • Not all voltages present (some missing).
                                          • Battery charges correctly (detected in Windows, shows percentage).
                                          • When battery is plugged in while in Windows:
                                            • Laptop shuts
                                          05-08-2025, 01:53 PM
