HP 15-CS3635ND SYSTEM FAN 90B missing components ??
  • pcrepai
    • Jul 2021
    • 46
    • Nederland
    Hi, guys, customer bring me laptop with SYSTEM FAN ERROR 90B, fan is not spinning at all !!! As far as I can see someone else tried to fix it, I dont have any boardview, or schematic, but it looks like some components r missing, can anyone confirm it ??
    BOARD DAG7BLMB8D0 REV D
    Fan itself works fine, Ive also change bios, without any result, does anyone have EC for this board ??
    Thanks in advance !!
    • 20990
    Re: HP 15-CS3635ND SYSTEM FAN 90B missing components ??
    Bios and EC requests go here -> https://www.badcaps.net/forum/forumdisplay.php?f=40 .Use the forum search, what you are looking for might already be posted,and if not you can can post your request in a related thread or start your own
    • pcrepai
      • Jul 2021
      • 46
      • Nederland
      ok. I get it . I didnt find any schematic of this board thats why I asked anyone can confirm missing components on this board. (photo HP02).
      • JaroTech
        • Mar 2015
        • 351
        Hi, they are both capacitors rated at 220pF 25V, but they have an asterisk which means they may not be essential.
        • pcrepai
          • Jul 2021
          • 46
          • Nederland
          thanks
          • trepachka
            • Oct 2022
            • 429
            Hey, if you are still experiencing System Fan Error 90B out of the blue, I have an HP 15-cs laptop with the same issue. My laptop comes with 2 identical fans for the CPU and the GPU. Using multimeter, I have found the CPU fan was missing a 3.3V pin. 5V pin and PWM pin were present. The GPU fan had all pins present. Both fans run but I did get the error message. I only have the schematics for this board, no boardview. So, I wound up running a wire from the GPU fan 3.3V pin over to the CPU fan 3.3V pin, about 2 inches long. Now, the error message is gone. Basically, according to the schematics, the EC chip pin 47 is used to probe if 3.3V line is present on the fan and since it was missing, the computer was giving out that error.
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • 944longdrift
              Help Identifying board components - iMac 2017 21.5
              by 944longdrift
              2017 iMac (Mid 2017) A1418
              I'm not quite sure how this happened but a couple of components got ripped off the board when removing from the Logic Board from the iMac.
              Can anyone help identify them?
              I'll have to do the trace repair on the board before soldering on replacements but would prefer to order the components rather than get a whole scrap logic board off eBay.
              Thank u
              03-14-2024, 11:53 AM
            • Caspar
              MSI 1660S Ventus missing components
              by Caspar
              Hi all, I accidently knocked off some components on a MSI 1660S Ventus while trying to remove the heatsink to repaste the GPU. The missing components are located on the top left corner of the GPU. Does anyone happen to know what the values of the components are? I circled the missing components in the provided picture. Any help would be greatly appreciated.
              Thank you!
              PS If there's a boardview, that would help as well!...
              03-31-2023, 11:51 AM
            • mferna14
              Logic Board 820-00840-A Missing EDP_BKLT_EN
              by mferna14
              Hi dear friends., I am working on a Apple MacBook Pro A1708 , Logic Board 820-00840-A that has no backlight. The logic board powers on fine, but no display. After Checking on the backlight driver chip, I found that the EDP_BKL_EN is missing. And this Power Enable comes from the PCH. So does this means this Logic board cannot be repaired & brought back to life again? The resistance from GRD to the test point of EDP_BKL_EN is around is 0.66M ohms. R8442 (0ohms) is ok. Any suggestion/Tip if any would really appreciate. ​
              07-10-2024, 05:18 PM
