820-00165 no power, Missing PP3V3_S5
  • rtimots
    • Dec 2022
    • 11
    • Latvia
    Having trouble identifying the problem for this motherboard,
    some one has already been here and messing with U7501, but looks to be repaired, but this time had some corrosion by U3210, removed it and cleaned up the pads, and replaced with new one, still no power. By U7501 saw that C7588 was missing, put it on but still nothing, while doing investigation found that i have PPBUS_G3H - 8.6v; PPDCIN_G3H - 16.5; PP3V42_G3H - 3.44; PP5V_S5 - 5v; but i dont have PP3V3_S5 - 0v there fore don't have any S4; S3; S0 voltages; By U7501 i have P3V3S5_EN_R- 3.3v; SMC_PM_G2_EN - 3.3v; PP3V3_S5_REG_R- 0v; P3V3_S5_REG_L - 0v; pin24;25;27 on U7501 also 0v;
    Since I'm new to Macbook MB repair i cant figure out the problem.
    Already replaced U7501 vice versa from a know good A1502 board and and after that A1502 boots OK but the A1466 doesn't boot.
    Also tried removing U3210 to see if anything changed, but nothing.
    Haven't noticed any shorts on any lines mentioned.
    Will be grate-full for any advice, Thanks!
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: 820-00165 no power, Missing PP3V3_S5
    check for short on 3,3 coil. check resistance on l7560
    • rtimots
      • Dec 2022
      • 11
      • Latvia
      L7560 measures 1ohm, on donor board it the same, is that a good reading?
      L7560 pin 1 to ground measures 0.480 kohm, the same on pin 2
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        check voltage on l7560 when u put psu. check if there is some voltage spike.
        when wwe ask for resistance: red on gnd and black on measuring point.
        in ur case 0.480komh looks like there is no short on 3,3 rail.
        7501 u sure is good and well soldered ?
        voltage on r7516, r7546; both side of each resistor.
        • reformatt
          • Feb 2020
          • 1495
          Most common issue I see on this converter is corrosion eating at the test points next to it. If they are dark and not shiny, scratch at each one to make sure they actually aren't open circuit. Also check that boost components C7564/R7564 are present and correct. As dellxps15 asked, check for a spike of 3V3 after power is applied, as you may have an active short, rather than a passive one.
          I always do a quick check on the major coils of the board for resistance to ground, especially L7630 as a shorted PCH is a common failure on these boards.
          • piernov
            • Jan 2016
            • 4439
            • France
            480 ohms on a 3.3V power rail is too low.
            • rtimots
              • Dec 2022
              • 11
              • Latvia
              So while checking R7516 and R7546 voltages witch was btw 0v, I also checked the values of these resistors, and when checking the value of R wasnt getting any, and when poking around the wire trace was not soldered enaght to the resistor so the U7501 wasnt getting an EN signal, I soldered this trace correctly, and BOOM !!! Finaly fans spin!
              Thanks Dellxps15 for guiding me to the real problem, i think i would be given up at that point
              • dellxps15
                • Feb 2014
                • 1598
                • italy
                congratz for the repair
                • ugamazing
                  820-02020 PPBUS_AON missing
                  by ugamazing
                  Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                  Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                  02-05-2025, 04:21 PM
                • jpreza
                  Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                  by jpreza
                  I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                  Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                  It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                  Looking at the card, it appears to be missing the following:
                  1x 1.0uH inductor - orange square
                  2x...
                  11-01-2024, 10:54 PM
                • gurj1979
                  Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                  by gurj1979
                  Hey guys.
                  Need help with this one.
                  Fan not spinning due to missing PWN Fan signal.
                  Also 5 seconds from powering up it freezes, unless in BIOS.
                  But as soon as Windows starts to load, it will freeze.
                  CPU is COLD / Room temp when it freezes.
                  I've replaced the CPU, same problem.
                  Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                  Replaced fan - same problem.
                  Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                  Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                  08-19-2024, 05:22 PM
                • ein_individuum
                  Missing Capacitator Intel I9-12900KF CPU
                  by ein_individuum
                  I bought a use Intel I9-12900KF CPU and i received it damaged. But it looks like only one component one the backside is missing. But the solder pads looks fine.
                  I already "googled" it and compare the backside picture of other LGA1700 12th Gen CPU. They look all the same, no matter if its an I9 or an I3, even the Pentium. And at that spot should be a capacitor.
                  Does anyone have a schematics or assembly diagramm of the alder-lake cpu-backside? Or just know what size and value i need to replace the missing capacitator.
                  08-06-2025, 01:36 AM
                • reessi
                  HP - CE Series - DAG7ALMB8C0 REV.C - MODEL - G7AL-2G - Missing MAINON & SUSON - Turns on power LED & Charges
                  by reessi
                  I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
                  It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
                  What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
                  I have checked these lines in diode mode and they seam normal -> 600.
                  I have checked to see if they come on for even a fraction of a second...
                  07-15-2025, 09:14 AM
