LA-G07FP ACIN signal missing
  • madura2010
    • Feb 2021
    • 32
    • Sri Lanka
    10th generation hp laptop(LA-G07FP motherboard) missing ACIN signal.charger light not blow.when pressing power button, only 3 blinks display on dc adapter bulb(only once).but not turning on.original hp charger attached.charging port perfect.
    19v (gate 25v) main power rail ok
    RTC section ok.
    3vldo ok
    5vldo ok.
    ECON missing.no 3v and 5v always voltage.
    REGN,ACDET perfect.but ACIN missing.No short in ACIN path(good impedence)
    Replaced the bq24725a charger ic.but no result.still ACIN not generating.
    is this sort of error occurs from EC bios?what should i check further to fix ACIN signal.?
    I would be much grateful to you if you could help me regarding this issue
  • mon2
    • Dec 2019
    • 14310
    Re: LA-G07FP ACIN signal missing
    Link or post the schematic. Unable to find the ECON netname in the schematic I have. Also where does ACIN signal originate?
    • gs84
      • Dec 2022
      • 36
      • Ukraine
      did you try another original charger or hp 3 pin adapter like this?
      • madura2010
        • Feb 2021
        • 32
        • Sri Lanka
        i have tried with the other hp charger with adapter id.still problem persist
        • madura2010
          • Feb 2021
          • 32
          • Sri Lanka
          https://www.badcaps.net/forum/attach...6&d=1654389965
          schematic of LA-G07FP.Here i have mentioned "ACOK" as "ACIN"
          ACOK signal origiantes from Bq24725a charger ic and goes to super io(KB9022QD)l
          ECON should be corrected as EC_ON.
          • mon2
            • Dec 2019
            • 14310
            There will be required pull-up resistor on ACOK / ACIn pin since this is an open drain (also known as open collector) output.
            What is the voltage to ground of the other side of this pull-up resistor?
            With a logic low on this charge pin, the AC adapter is NOT OK.
            • madura2010
              • Feb 2021
              • 32
              • Sri Lanka
              "PRB15" resistor side "1" shows +3VL=3.3v.
              side "2" of that resistor shows "0V"
              what should i do?I have tried another charger too.should i want to try any other charger also to test whether it is a charger fault?
              • mon2
                • Dec 2019
                • 14310
                Review the voltage of pin # 6 = ACDET.
                What is the voltage to ground of this pin ? If this voltage is too low, the adapter will be deemed as not worthy to power this logic board.
                Next, remove all power. Meter in resistance mode.
                Measure the resistance across PRB17.
                Measure the resistance across PRB21.
                Post each reading.
                • madura2010
                  • Feb 2021
                  • 32
                  • Sri Lanka
                  ACDET voltage =2.7V
                  PRB17 412kilo ohm
                  PRB21 66kilo ohm
                  • mon2
                    • Dec 2019
                    • 14310
                    Look like good readings.
                    Focus on the EC. North of the UK1 symbol in the schematic are the power pins for this component.
                    Measure the voltage to ground of each such pin. Post each measurement.
                    In following the power sequence chart on page #5, the EC_ON should be high next, if this component is being powered and has valid firmware. This device has an internal 8051 microcontroller core that requires firmware to sample the GPIO pins and to drive the EC_ON function.
                    • madura2010
                      • Feb 2021
                      • 32
                      • Sri Lanka
                      EC_ON is 0V.
                      Super io all power pins recieve around 3.3Volts.
                      • mon2
                        • Dec 2019
                        • 14310
                        I think the very first requirement for the RTC is being met?
                        What is the voltage to ground of EC_RST#? It should be a logic high to allow for the KB9022 to run.
                        The firmware appears to be held inside uc2 flash. Is it being powered? Check each pin on this spi flash chip.
                        After these checks, to me, the KB EC controller is a suspect.
                        Do wait for other comments but the EC controller may be with corrupt firmware.
                        • madura2010
                          • Feb 2021
                          • 32
                          • Sri Lanka
                          thanks a lot for your attention.
                          • gurj1979
                            Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                            by gurj1979
                            Hey guys.
                            Need help with this one.
                            Fan not spinning due to missing PWN Fan signal.
                            Also 5 seconds from powering up it freezes, unless in BIOS.
                            But as soon as Windows starts to load, it will freeze.
                            CPU is COLD / Room temp when it freezes.
                            I've replaced the CPU, same problem.
                            Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                            Replaced fan - same problem.
                            Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                            Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                            08-19-2024, 05:22 PM
                          • Fernon@Repair
                            MSI mpg b560m bazooka motherboard RSMRST# signal missing
                            by Fernon@Repair
                            I have MSI mpg b560m bazooka motherboard . this motherboard RSMRST# signal missing . i already reprogram bios but same condition
                            My Motherboard this power stages are ok ...but 3vsb voltage have 4.17v (image added)
                            VCCRTC ok
                            RTCRST# ok
                            ATX_5VSB ok
                            SIO_3VA ok
                            3VDSW ok
                            DPWROK ok
                            SLP_SUS# ok
                            VSB_ENABLE# ok
                            5VDUAL ok
                            3VSB showing 4.17V
                            PCH_1P8_VSB ok
                            PCH_VCCIN_AUX ok
                            RSMRST# No voltage
                            this all voltages are ok but RSMRST# voltage is missing i did try to re program bios and change io but same...
                            06-03-2025, 10:49 AM
                          • mohamed mm
                            sony vaio mbx-247, missing S5_ON signal
                            by mohamed mm
                            Hi everyone, I hope you are having a good day.
                            I have a laptop sony Vaio, DA0HK1MB6E0, MBX-247. REV: E
                            The laptop suddenly shut down as the owner told me, so I did the normal check there is no short but the laptop it's not powering up and there is no light when I connect the adapter because there is no battery.
                            so I checked.
                            pu9:
                            Vin: 19v
                            Ldo: 4.89v
                            Ref:1.99v
                            Vcc: 4.89v
                            Vdd: 4.89v
                            output
                            3.3v pcu.
                            EN2: 4.89v
                            but No
                            01-19-2023, 05:17 AM
                          • Prott
                            Surface 7 - missing S3 sleep signal, S4 present but weird
                            by Prott
                            Hey fellow Badcappers
                            I am troubleshooting Surface 7 board (rev 1.0) which was working great until it experienced a short circuit due to a bad screen.
                            Now it's missing SLP_S3 signal. Everything in the power on sequence works properly up until that signal.
                            - The resistance to ground on the SLP_S3 line is >50 kOhms.
                            - No shorts on any powerrails that I can find.
                            - I get a proper clock signal on the RTC crystal (XTAL_2P) once the Surface gets power.
                            - SLP_S4 is, suprisingly, present, but it looks very weird (jump up to 2 V for about...
                            07-08-2023, 04:54 PM
                          • Benass
                            GigaByte Radeon Rx5700xt 8gb VDDCR_GFX_PWR_GOOD Signal is missing.
                            by Benass
                            This will be a headscratcher. I don't know how to break it down to a readable topic.
                            Im troubleshooting Rx5700 GPU. Core voltage missing.
                            I have schematics and Boardview.
                            I'm currently troubleshooting a power management setup that involves the IR35217M and NCP81022 chips. I've encountered some issues specifically with the SM_ALERT#, SM_DIO, and SM_CLK pins, and I'm hoping to get some insights or suggestions from those who might have experience with these components. Current Observations:
                            • The SM_ALERT# pin is active (pulled low), indicating a potential fault condition.
                            10-11-2024, 01:58 PM
