Clear CMOS on unowhy Y13 Ultrabooks on motherboard
  • highsnoop
    • Feb 2023
    • 21
    • IDF
    After disable fastboot option in the bios of a unowhy Y13 ultrabooks the screen stay black with power led on.
    I search how to clear cmos with jumper or battery off without sucess.
    Help appreciate to know how we can do it on an ultrabooks.
  • sikocan
    • Oct 2019
    • 344
    Re: Clear CMOS on Ultrabooks on motherboard
    Disconnect battery and any CMOS battery, press power button 5 times. Voila!
    • highsnoop
      • Feb 2023
      • 21
      • IDF
      So where is the CMOS battery ?
      If it too simple for you
      • sikocan
        • Oct 2019
        • 344
        Re: Clear CMOS on unowhy Y13 Ultrabooks on motherboard
        Some models like these, there is no CMOS battery, just disconnect internal battery and press power button few times.
        • highsnoop
          • Feb 2023
          • 21
          • IDF
          I tried with Internal battery disconnected
          - 5x time slowy
          - 5x times quickly
          - 5x time slowy + external power
          - 5x times quickly + external power
          - 1x long time 60s
          - 1x long time 60s + external power
          - 30x times quickly
          no result , black screen with led power on
          Thank you anyway
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Ask for a clean me bios while posting your backup in "Bios Section" and flash the new bios. Hopefully that will restore the settings to default and you may get display back. Woth the try.
            • highsnoop
              • Feb 2023
              • 21
              • IDF
              Thanks for your proposal but i don't have a BIOS backup.
              I didn't update it, I only changed a simple parameter.
              I never has been get this issue with a real motherboard (MSI, ASUS, LENOVO; ACER,...)
              I hate noname without technical documentation
              The ultrabook don't boot from USB too, so how I can flash the BIOS if a get a BIOS flash file ?
              • highsnoop
                • Feb 2023
                • 21
                • IDF
                This is the picture of a part of the motherboard.
                You will see the bios chipset and the connector to manage it.
                I think something can be executed from here to reset or update the code when the laptop boot on a black screen
                • reformatt
                  • Feb 2020
                  • 1506
                  All the manufacturers don't provide much in that way. Schematics and boardviews aren't actually published by them, the bulk we have in the public domain have been stolen or leaked. The exception is Framework, who according to Rossman are publishing theirs. Random stuff like this is so uncommon that nobody sees the worth in stealing it I guess.
                  Removal of the battery should result in a CMOS reset, unless there is something screwy with the EEPROM. Take it off the board, dump it and post it in the BIOS group like @mcplslg123 suggested. It's good advice.
                  • highsnoop
                    • Feb 2023
                    • 21
                    • IDF
                    I watched a lot of youtube videos on eproom flash in recent days
                    But this problem (black screen after changing a setting in the bios) happens several times on noname motherboards (like pipo X8)
                    Because the manufacturer uses a common bios with all the options not available on its own device
                    I can't read the chipset number So I can't figure out how to make a short circuit (pin x to pin y) like a clearcmos jumper without the risk of burning it.
                    My last chance, as you both said, is to read the eproom with my rasbperry (I've never done that before ) to read/delete/write I also don't know the voltage for this chipset (3.3V?)
                    any help are welcome
                    Thks
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      I've no idea about raspberry as i've never used it. Any SPI programmer will read /write your bios chip. If you dont have the tools, you can get it done by a repair shop in your location.
                      • highsnoop
                        • Feb 2023
                        • 21
                        • IDF
                        https://github.com/bibanon/Coreboot-...h-Raspberry-Pi
                        But does each chip have the same schema ?
                        example
                        https://1.bp.blogspot.com/-oqp22M52C...o2+diagram.jpg
                        Can i used only pin : 1 2 4 5 6 only (used O for the welding) ?
                        • reformatt
                          • Feb 2020
                          • 1506
                          On board read/write of SPI25 EEPROM's is a bit hit and miss for me. It's quicker just to hot air it off and put it in a programmer. If the EEPROM is near anything heat sensitive (or I don't want to take the board out), I use Chipquik on the pins and it will just come off with an iron.
                          Any SPI25 programmer will work, even CH341. You may need a 1.8V adaptor though if the EEPROM you are trying to read is 1.8V variant. Check datasheet of the EEPROM to confirm.
                          • highsnoop
                            • Feb 2023
                            • 21
                            • IDF
                            With difficulty i Can read the chip ref
                            Gigadevice
                            25lb64cvig
                            Ef8211
                            Aj2039
                            The voltage seems to between 1.65 and 2.0
                            Here is the Doc https://www.mouser.fr/ProductDetail/...IVPR6ZyQ%3D%3D
                            If you confirm, i will buy a ch341 like this
                            ch341a
                            Sorry for sponsor but not choice 🥴
                            Thks for your help
                            • highsnoop
                              • Feb 2023
                              • 21
                              • IDF
                              With adaptor 1,8v because ch341a=3,3v like raspberry
                              • reformatt
                                • Feb 2020
                                • 1506
                                Wondering if this thing is a rebadged Chuwi, as it sounds like they have the same issues on those lappies. The settings seem to be stored within the EEPROM and are non-volatile. Hence why removing the battery won't work. Cheap garbage from China.
                                https://forum.chuwi.com/t/i-need-a-w...2778/65?page=2
                                Where to get a donor BIOS from though?
                                This kit on Aliexpress has everything included the 1.8V adaptor.
                                https://www.aliexpress.com/item/3278...8dat0Nx70&mp=1
                                • highsnoop
                                  • Feb 2023
                                  • 21
                                  • IDF
                                  I received everything needed but I find an empty chip
                                  Before plug ch341a key on pc (windows 10), i check with a tester the good contact with pins on motherboard to the adaptor 1-1 2-2 3-3 ....
                                  The chip doesn't be found with asprogrammer, i selected GD25B64C in the device list manually without success
                                  thanks for what i am wrong
                                  • mon2
                                    • Dec 2019
                                    • 14672
                                    Be sure your tools are supporting and configured for 1v8 operation. Otherwise this flash chip will be killed.
                                    You will need to remove the flash chip off the logic board and then proceed to use the programmer to read / write / erase the chip.
                                    Be very careful on the hot air tool that can and will hurt the display or any nearby plastic parts. Keep the air flow low and ample flux to remove the part. Practice if required on other donor boards first.
                                    • highsnoop
                                      • Feb 2023
                                      • 21
                                      • IDF
                                      i tried with another chip from an older motherboard
                                      Asus M4A785STD-V
                                      Chip : CfEON EN25F80
                                      https://pdf1.alldatasheet.com/datash...N/EN25F80.html
                                      Full voltage range: 2.7-3.6 volt
                                      so without 1.8v adaptor i get something from the chip (No detect automatically, i selected it manually)
                                      see capture too confirm
                                      So the issue can be from Adaptor or chip
                                      I don't have others chip in 1.8v
                                      • highsnoop
                                        • Feb 2023
                                        • 21
                                        • IDF
                                        I used a voltmeter between 8 and 4 and I get 1.8V so the voltage was set correctly.
                                        So I think it's the connection with the clamp around the chip...
                                        I will try to weld it but it's very very small....
                                        • glovecaps
                                          Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                                          by glovecaps
                                          I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                                          My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                                          The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                                          11-25-2024, 04:23 PM
                                        • Docus
                                          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                          by Docus
                                          Hi everyone 😀,
                                          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                          1. I already own the exact same model, but its plastic chassis is badly damaged.
                                          06-10-2025, 04:24 PM
                                        • sheffieldyorky
                                          ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
                                          by sheffieldyorky
                                          Hey there people
                                          While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
                                          This is what I tried, but not in any order.
                                          Google
                                          YouTube
                                          BIOS
                                          Command Prompt (administrator privileges)
                                          On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
                                          10-25-2025, 02:22 AM
                                        • questore
                                          XPS 13 9370 CMOS battery voltage always low
                                          by questore
                                          Hi Everyone,
                                          I have brought you a mistery item
                                          This laptop have come with some strange faults.
                                          1. CMOS battery was flat 0v
                                          Symptoms:
                                          - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
                                          Amp drawing was stuck at 0.005 milliamps.
                                          - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
                                          After inverstigation RTCD1 diode had a low value...
                                          09-30-2025, 05:47 AM
                                        • Archimedes
                                          HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                                          by Archimedes
                                          Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                                          Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                                          Fans are spinning. Blindly could install windows11 and got the device manager...
                                          07-30-2024, 05:14 PM
