Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
Clear CMOS on unowhy Y13 Ultrabooks on motherboard
  • corona100
    replied
    Originally posted by dwardo
    Re: Clear CMOS on unowhy Y13 Ultrabooks on motherboard
    I also am facing the same black screen as I wanted to install Manjaro Linux using a USB key and modified
    * / Setup / Chipset / Southbridge / OS Selection from "Windows" to "Linux"
    * / Setup / Boot / USB Support from "Partial Initial" to "Full initial"
    after save & exit got the black screen...
    So I ordered my ch341a... am waiting and discovered AMIBCP
    Have you tried opening your own dumped "borked" bios bin file in AMIBCP, changing the Setup/Boot/Fastboot parameter (cf. attached screenshot), saving under new name and flashing the modified bios ?
    Bios contains the Serial Number of the Y13 computer (cf. attached screenshot)... so maybe its not just information and checked agains someting/somewhere and that's why flashing someone elses Bios is not working for you when you flash it...
    i try allready with another dump of some one and i change the serial u will find 2 serials but unfortnly not work
  • dwardo
    replied
    Premium supporters get full download access and other benefits.
  • highsnoop
    replied
    I flashed this bin file whose it the same version of mine.
    I checked, erase, write , read and save it to compare to the original and no difference.
    I desoldered all, check short circuits
    Start the notebook and same result "Power led with black screen"
    No idear....
  • highsnoop
    replied
    With the AMIBCP tools i read my dump
    BIOS Date: 10/28/2020 19:55:13 Ver: 3BAPS05
    American Megatrends Inc.
    V0.5.0_P1S0M2E0F3L6B0T0P2G00A0U0D601_ENE
    10/28/2020
    Can i set option directly from this tools or can i do it with another one ?
  • highsnoop
    replied
    For the expert
    It's the same model of this thread https://www.badcaps.net/forum/showpo...91&postcount=2
    So can i put this bios on my mine without problem ?
  • highsnoop
    replied
    Originally posted by YourBlamp
    Salut highsnoop
    J'essaye aussi de dumper et remettre un autre bios dans un unowhy.
    Quel outil tu as achetƩ pour rƩaliser la manip ?
    Merci d'avance.
    CH341a + adaptor 1.8v
    For the driver + tools : Driver+tools
    Impossible de lire la puce avec la pince, j'ai directement souder (voir photo) les pin 1 2 4 5 6 8
    Attention ce n'a pas été facile car c'est très petit et la solution avec l'air ne pas convaincu avec le nombre de petite résistance proche du chip.
    Pour l'instant je suis toujours bloquƩ et en attente d'un modification de mon Bios ou bien d'un bios compatible pour le remplacer
    Impossible to read the chip with the pliers, I directly solder (see photo) pins 1 2 4 5 6 8
    Attention it was not easy because it is very small and the solution with the air does not convince with the number of small resistance close to the chip.
    For the moment I am still stuck and waiting for a modification of my Bios or a compatible bios to replace it
  • YourBlamp
    replied
    hi highsnoop
    I also try to dump and put another bios in an unowhy.
    What tool did you buy to do the trick?
    Thanks in advance.
  • highsnoop
    replied
    Yattaaa
    I managed to solder directly on the chip after one hour of fight.
    I got the dump of my bios (I doing it twice time to compare result and the both files are identical).
    Does the parameter to change in the file is my picture proposal (A Vs B)?
    Thanks again for your help and hope my story can be help anyone in this adventure
    or if someone can provide the same bios version (i don't know what is it) without password
    Bios - https://www.badcaps.net/forum/showthread.php?t=115849
    Last edited by SMDFlea; 02-18-2023, 03:16 AM. Reason: Bios moved to "Bios requests ONLY!" sub forum
  • reformatt
    replied
    Direct read from a chip on a board rarely works, so you'll have to remove it. I think in that kit, they give you a small PCB to solder the chip onto. You have to use hot air for WSON8 EEPROM's.
    There is another adaptor I use that doesn't require soldering if you are interested. You have to wick the pads clean usually and clean up in IPA before good contact is made though.
    https://www.aliexpress.com/item/1005...8daDVlmaC&mp=1
  • highsnoop
    replied
    I used a voltmeter between 8 and 4 and I get 1.8V so the voltage was set correctly.
    So I think it's the connection with the clamp around the chip...
    I will try to weld it but it's very very small....
  • highsnoop
    replied
    i tried with another chip from an older motherboard
    Asus M4A785STD-V
    Chip : CfEON EN25F80
    https://pdf1.alldatasheet.com/datash...N/EN25F80.html
    Full voltage range: 2.7-3.6 volt
    so without 1.8v adaptor i get something from the chip (No detect automatically, i selected it manually)
    see capture too confirm
    So the issue can be from Adaptor or chip
    I don't have others chip in 1.8v
  • mon2
    replied
    Be sure your tools are supporting and configured for 1v8 operation. Otherwise this flash chip will be killed.
    You will need to remove the flash chip off the logic board and then proceed to use the programmer to read / write / erase the chip.
    Be very careful on the hot air tool that can and will hurt the display or any nearby plastic parts. Keep the air flow low and ample flux to remove the part. Practice if required on other donor boards first.
  • highsnoop
    replied
    I received everything needed but I find an empty chip
    Before plug ch341a key on pc (windows 10), i check with a tester the good contact with pins on motherboard to the adaptor 1-1 2-2 3-3 ....
    The chip doesn't be found with asprogrammer, i selected GD25B64C in the device list manually without success
    thanks for what i am wrong
  • reformatt
    replied
    Wondering if this thing is a rebadged Chuwi, as it sounds like they have the same issues on those lappies. The settings seem to be stored within the EEPROM and are non-volatile. Hence why removing the battery won't work. Cheap garbage from China.
    https://forum.chuwi.com/t/i-need-a-w...2778/65?page=2
    Where to get a donor BIOS from though?
    This kit on Aliexpress has everything included the 1.8V adaptor.
    https://www.aliexpress.com/item/3278...8dat0Nx70&mp=1
  • highsnoop
    replied
    With adaptor 1,8v because ch341a=3,3v like raspberry
  • highsnoop
    replied
    With difficulty i Can read the chip ref
    Gigadevice
    25lb64cvig
    Ef8211
    Aj2039
    The voltage seems to between 1.65 and 2.0
    Here is the Doc https://www.mouser.fr/ProductDetail/...IVPR6ZyQ%3D%3D
    If you confirm, i will buy a ch341 like this
    ch341a
    Sorry for sponsor but not choice 🥴
    Thks for your help
  • reformatt
    replied
    On board read/write of SPI25 EEPROM's is a bit hit and miss for me. It's quicker just to hot air it off and put it in a programmer. If the EEPROM is near anything heat sensitive (or I don't want to take the board out), I use Chipquik on the pins and it will just come off with an iron.
    Any SPI25 programmer will work, even CH341. You may need a 1.8V adaptor though if the EEPROM you are trying to read is 1.8V variant. Check datasheet of the EEPROM to confirm.
  • highsnoop
    replied
    https://github.com/bibanon/Coreboot-...h-Raspberry-Pi
    But does each chip have the same schema ?
    example
    https://1.bp.blogspot.com/-oqp22M52C...o2+diagram.jpg
    Can i used only pin : 1 2 4 5 6 only (used O for the welding) ?
  • mcplslg123
    replied
    I've no idea about raspberry as i've never used it. Any SPI programmer will read /write your bios chip. If you dont have the tools, you can get it done by a repair shop in your location.
  • highsnoop
    replied
    I watched a lot of youtube videos on eproom flash in recent days
    But this problem (black screen after changing a setting in the bios) happens several times on noname motherboards (like pipo X8)
    Because the manufacturer uses a common bios with all the options not available on its own device
    I can't read the chipset number So I can't figure out how to make a short circuit (pin x to pin y) like a clearcmos jumper without the risk of burning it.
    My last chance, as you both said, is to read the eproom with my rasbperry (I've never done that before ) to read/delete/write I also don't know the voltage for this chipset (3.3V?)
    any help are welcome
    Thks
  • delosit
    Lenovo IdeaPad XiaoXin Chao7000-15ARR – only motherboard available, need help reconstructing clean BIOS
    by delosit
    I’m working on a Lenovo IdeaPad XiaoXin Chao7000-15ARR (Ryzen platform) and I need some help with BIOS reconstruction.
    Unfortunately I only have the bare motherboard (no original chassis, no sticker, no working system).
    The laptop came with black screen.
    What I have:
    - Original SPI dump read from the board (W25Q64DW 1.8V, 8MB)
    - Official Lenovo BIOS update (.CAP file)
    - Photos of the motherboard (front and back)
    - Board powers on, but with original dump it stays black screen
    What I tested:
    01-15-2026, 09:11 AM
  • glovecaps
    Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
    by glovecaps
    I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
    My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
    The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
    11-25-2024, 04:23 PM
  • Docus
    Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
    by Docus
    Hi everyone šŸ˜€,
    I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
    To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
    Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
    1. I already own the exact same model, but its plastic chassis is badly damaged.
    06-10-2025, 04:24 PM
  • sheffieldyorky
    ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
    by sheffieldyorky
    Hey there people
    While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
    This is what I tried, but not in any order.
    Google
    YouTube
    BIOS
    Command Prompt (administrator privileges)
    On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
    10-25-2025, 02:22 AM
  • questore
    XPS 13 9370 CMOS battery voltage always low
    by questore
    Hi Everyone,
    I have brought you a mistery item
    This laptop have come with some strange faults.
    1. CMOS battery was flat 0v
    Symptoms:
    - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
    Amp drawing was stuck at 0.005 milliamps.
    - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
    After inverstigation RTCD1 diode had a low value...
    09-30-2025, 05:47 AM
