question about TPS51980B at 820-01987
  • rookieme
    • Oct 2014
    • 403
    • Greece
    Hello, the macbook has power issue - stuck at 5V.
    As I cannot find datasheet for TPS51980 [U7650] can someone help figuring out if there is an issue there.
    Voltages of TPS51980:
    pin23 VIN 12.27V
    pin22 VREG3 3.31V
    pin29 VREG5 0V
    pin13 VREF2 0V
    pin12 EN 0V
    so in order to get VREG5 & VREF2 it needs the enable at pin12 and VREG3 is always on?
  • mon2
    • Dec 2019
    • 14839
    Re: question about TPS51980B at 820-01987
    Remove all power. Measure the resistance to ground of vreg5 pin.
    Post the measurement.
    • rookieme
      • Oct 2014
      • 403
      • Greece
      I have already checked for shorts.
      It is 17KOhm
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        820-01987 is 2020 macbook right ? 12,3 volt on vin is not good.... it should be around 13 volt.
        dc in is 5 or 20 volt ?
        • rookieme
          • Oct 2014
          • 403
          • Greece
          2020 correct
          input is stuck at 5V so I'm searching for the reason
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            5v on charger is totally different problem, not related to tps51980.
            check 3.3 g3hot volt if present, and all ldo volts.
            • rookieme
              • Oct 2014
              • 403
              • Greece
              you are right
              short at PP3V3_G3H
              I found shorted cap at PP3V3_G3H_SSD0 and more short under shield at T2 area
              is seems game over to me
              thank you for your time
              • dellxps15
                • Feb 2014
                • 1598
                • italy
                inspect ssd power ic if looks ok or bad... probably ssd got fried and unless u swap ssd nand ur board is dead, but before all that check everything
                • rookieme
                  • Oct 2014
                  • 403
                  • Greece
                  The security chip T2 has issue so there is a no fix.
                  I'm wondering how 2 separate locations have short at the same line, I'm guessing over-voltage.
                  • moderator
                    • May 2020
                    • 33
                    • India
                    can someone please tell me that can i use tps51980A or tps51980 insted of tps51980B??
                    • Deluccia
                      • Aug 2017
                      • 47
                      Any verdict on this?
                      • mon2
                        • Dec 2019
                        • 14839
                        https://www.badcaps.net/forum/showthread.php?p=1208119
                        • microitech
                          Mac Mini A1347 (820-5509) PM_SLP_S5_L missing
                          by microitech
                          I've been troubleshooting a Mac Mini A1347 (820-5509) that came in for a simple thermal paste replacement, but it turned into a challenging repair. I've made some progress, but I'm stuck at a point and could really use some advice from those more experienced with this board
                          Worked fine for a week, then started powering on intermittently.
                          What I've done so far:
                          • Found PP3V3_G3H in short.
                          • Removed and replaced an AND gate (74LVC1G08) and an OR gate, which were causing issues on the line.
                          12-21-2024, 11:57 AM
                        • pb1911nt
                          820-00165 issues - waht can i do
                          by pb1911nt
                          Hello community, I have a MacBook Air 820-00165 with an i5 and 8GB Ram. The logic board doesn't want to start. I've taken some measurements but I can't really get any further.
                          And please excuse me if something is spelled wrong, I have to use a translator.
                          PPBUS_G3H = 8.6 V (stable)
                          PP3V42_G3H = 3.44 V (stable)
                          First Always/SMC signals
                          SMC_RESET_L = 3.4 V (stable → SMC running)
                          SMC_PM_G2_EN = pulses between 0 V ↔ 3.3 V
                          PM_PWRBTN_L = pulses between 0 V ↔ 3.3 V
                          PM_SLP_S5_L = pulses between 0 V ↔ 0.2 V
                          09-30-2025, 12:26 PM
                        • moderator
                          TPS51980B Vs TPS51980A !!!URGENT!!!
                          by moderator
                          in schematics and in pdf ...they are both showing same signal and voltages..
                          actually i am working on A2141, 16 inch macbook pro and i am suspecting TPS51980B faulty..but i dont have same part handy...but i have TPS51980A ...
                          so can i use it?
                          02-11-2023, 03:07 AM
                        • rookieme
                          LA-3741P issue with TPS51120
                          by rookieme
                          I need some help with this MB.
                          Schematic available at
                          https://www.badcaps.net/forum/showth...24#post1272124
                          I have the 19,5V but not the 3,3 & 5 V.
                          TPS51120 gets warm
                          VREF2 = 2.00V
                          VREG3 = 1,01V
                          VREG5 = 4,99V
                          so far I have replaced the TPS but with same results
                          I cannot find any short
                          I have removed PJP4, PJP5 & PJP12 and after the PQ4,PQ5, PQ6 & PQ7.
                          the VREG still is low
                          Could the second TPS I had to be faulty too? I don't have more to try.
                          09-18-2023, 03:28 AM
                        • Bradbeat
                          TPS51225CRUKR Voltage limit
                          by Bradbeat
                          I have a PGOOD pin down on this chip and I’m wondering if it could be because there is 5,2 v on VREG5 ( the high limit according to the datasheet is 5,1v ).
                          if yes, why is it to high?
                          the motherboard board is LA-G881P.
                          thank you.
                          here is some measurements :
                          • VIN = 16,3 V
                          • VREG3 = 3,299 V
                          • VREG5 = 5,203 V
                          • SW2 (repos) = 3,423 V, pikes at ~16,4 V
                          • VBST2 = 8,592 V → VBST2 − SW2 = ≈ 5,17 V
                          • VO1 = 5,28 V (stable)
                          • EN1 = 3,08 V, EN2 = 3,04 V
                          • VFB1/VFB2 ≈ 2,1 V
                          09-18-2025, 05:07 AM
