820-00165 issues - waht can i do
  • pb1911nt
    • May 2023
    • Deutschland
    Hello community, I have a MacBook Air 820-00165 with an i5 and 8GB Ram. The logic board doesn't want to start. I've taken some measurements but I can't really get any further.
    And please excuse me if something is spelled wrong, I have to use a translator.
    PPBUS_G3H = 8.6 V (stable)
    PP3V42_G3H = 3.44 V (stable)
    First Always/SMC signals
    SMC_RESET_L = 3.4 V (stable → SMC running)
    SMC_PM_G2_EN = pulses between 0 V ↔ 3.3 V
    PM_PWRBTN_L = pulses between 0 V ↔ 3.3 V
    PM_SLP_S5_L = pulses between 0 V ↔ 0.2 V
    S5/S4 supplies
    PP3V3_S5 (L7520) = pulses 0 ↔ 3.3 V (not stable, “hiccup”)
    PP5V_S4RS3 (L7560) = 0 V (does not come up because 3V3-S5 is missing)
    Regulator U7501 / Power Good
    PGOOD1 (3V3) = 0V
    PGOOD2 (5V) = pulses between 0 ↔ 3.3 V
    P3V3S5_EN_R = pulses between 0 ↔ 3.3 V
    P5VS4RS3_EN_R = 0V
    S5_PWRGD (U8130) = pulses between 0 ↔ 3.3 V
    U7501 internal pins
    VREG5 = 5 V, drops briefly every ~2 s
    VREG3 = constant 3 V
    VREF2 = 2 V, drops synchronously with VREG5
    SW1 (3V3 branch) = 0 V (no switching visible)
    Resistance measurements (without current)
    A1 (PP3V3_S5 → GND) = 3.1 kΩ (no short circuit)
    R7560 (5V divider) = correct 23.2 kΩ
    R7522 = 3 Ω (perhaps correct according to the plan, but needs to be checked in context → not the feedback divider)
    R7537 = unequipped (no-stuff, normal)​
    and.. yes I actually use an AI to help BUT! I can't get any further because I don't know what else I should or can do.
    It feels like I measure the same signal 3 or 4 times and suddenly it's component XYZ... So you can't really call it a help.​
  • mon2
    • 14629
    Pulsing only when you press the power button? Can you confirm? If not, test with a pair of tweezers and use the SMD pads to bypass the power button.
    Search for R5115 and R5116 - one side will be visible to you.
    • pb1911nt
      • May 2023
      • Deutschland
      So it pulsates as soon as it gets power. I don't press any power buttons - the logic board is lying naked on the table. The MagSafe plug first turns green then red. I don't have any fan spin
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        what value in L7520 in diode mode ?
        is fuse f7140 100% ok ?
        • mon2
          • 14629
          Follow this flowchart:
          https://logi.wiki/index.php/G3_to_S3..._and_Broadwell
          • SoulFreeze
            Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
            by SoulFreeze
            Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
            After repairing the above issue, I realized the following remaining problem,
            Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
            The computer recognizes headphones are connected and displays a popup in windows
            Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
            06-21-2025, 09:53 AM
          • Nagyesz
            Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
            by Nagyesz
            I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
            All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
            How can I extend its lifespan? Could reflow help?
            It has ryzen 5 5500h, rtx 2050, no soldered ram.
            Example of the artifacts:
            03-01-2025, 11:11 AM
          • pwnjuice
            Bitlocker issues
            by pwnjuice
            Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
            Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
            Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
            01-06-2025, 05:33 PM
          • Skgod
            Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu
            by Skgod
            Hey I am having Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu. Works fine when I open any game or whatsapp windows application. The issues are :
            Black screen, freeze
            The weird thing is that when as long as the laptop is running on igpu the problem keeps happening. But as soon as I open any game or whatsapp windows application, the laptop works completely fine.
            When the screen freeze or black screen I used to move the display lid up and down and it usually works like that.
            So can anyone tell me what would be the possible cause?...
            10-16-2024, 08:11 PM
          • junda
            MacBook Air A1466 820-00165-A 5V Rail Pulses (on & off)
            by junda
            hi, i also have the same (P5V_S4RS3) MacBook Air A1466 820-00165-A 5V Rail Pulses (on & off) The strange thing is when I kept machine for 1 day and connect the power It powers on with Chime and booots half way with Apple logo and stuck. at that time when I power of and try power up Fan spins for few seconds and goes off with no P5V_S4RS3 and also the P5V_S4RS3 EN pulses on and off with 3,24 V. Plezzz doesn any one can help me
            08-26-2024, 09:54 AM
