question about TPS51980B at 820-01987
  • rookieme
    • Oct 2014
    • 397
    • Greece
    Hello, the macbook has power issue - stuck at 5V.
    As I cannot find datasheet for TPS51980 [U7650] can someone help figuring out if there is an issue there.
    Voltages of TPS51980:
    pin23 VIN 12.27V
    pin22 VREG3 3.31V
    pin29 VREG5 0V
    pin13 VREF2 0V
    pin12 EN 0V
    so in order to get VREG5 & VREF2 it needs the enable at pin12 and VREG3 is always on?
  • mon2
    • 14171
    Re: question about TPS51980B at 820-01987
    Remove all power. Measure the resistance to ground of vreg5 pin.
    Post the measurement.
    • rookieme
      • Oct 2014
      • 397
      • Greece
      I have already checked for shorts.
      It is 17KOhm
      • dellxps15
        • Feb 2014
        • 1588
        • italy
        820-01987 is 2020 macbook right ? 12,3 volt on vin is not good.... it should be around 13 volt.
        dc in is 5 or 20 volt ?
        • rookieme
          • Oct 2014
          • 397
          • Greece
          2020 correct
          input is stuck at 5V so I'm searching for the reason
          • dellxps15
            • Feb 2014
            • 1588
            • italy
            5v on charger is totally different problem, not related to tps51980.
            check 3.3 g3hot volt if present, and all ldo volts.
            • rookieme
              • Oct 2014
              • 397
              • Greece
              you are right
              short at PP3V3_G3H
              I found shorted cap at PP3V3_G3H_SSD0 and more short under shield at T2 area
              is seems game over to me
              thank you for your time
              • dellxps15
                • Feb 2014
                • 1588
                • italy
                inspect ssd power ic if looks ok or bad... probably ssd got fried and unless u swap ssd nand ur board is dead, but before all that check everything
                • rookieme
                  • Oct 2014
                  • 397
                  • Greece
                  The security chip T2 has issue so there is a no fix.
                  I'm wondering how 2 separate locations have short at the same line, I'm guessing over-voltage.
                  • moderator
                    • May 2020
                    • 32
                    • India
                    can someone please tell me that can i use tps51980A or tps51980 insted of tps51980B??
                    • Deluccia
                      • Aug 2017
                      • 46
                      • uk
                      Any verdict on this?
                      • mon2
                        • 14171
                        https://www.badcaps.net/forum/showthread.php?p=1208119
                        • microitech
                          Mac Mini A1347 (820-5509) PM_SLP_S5_L missing
                          by microitech
                          I've been troubleshooting a Mac Mini A1347 (820-5509) that came in for a simple thermal paste replacement, but it turned into a challenging repair. I've made some progress, but I'm stuck at a point and could really use some advice from those more experienced with this board
                          Worked fine for a week, then started powering on intermittently.
                          What I've done so far:
                          • Found PP3V3_G3H in short.
                          • Removed and replaced an AND gate (74LVC1G08) and an OR gate, which were causing issues on the line.
                          12-21-2024, 11:57 AM
                        • moderator
                          TPS51980B Vs TPS51980A !!!URGENT!!!
                          by moderator
                          in schematics and in pdf ...they are both showing same signal and voltages..
                          actually i am working on A2141, 16 inch macbook pro and i am suspecting TPS51980B faulty..but i dont have same part handy...but i have TPS51980A ...
                          so can i use it?
                          02-11-2023, 03:07 AM
                        • rookieme
                          LA-3741P issue with TPS51120
                          by rookieme
                          I need some help with this MB.
                          Schematic available at
                          https://www.badcaps.net/forum/showth...24#post1272124
                          I have the 19,5V but not the 3,3 & 5 V.
                          TPS51120 gets warm
                          VREF2 = 2.00V
                          VREG3 = 1,01V
                          VREG5 = 4,99V
                          so far I have replaced the TPS but with same results
                          I cannot find any short
                          I have removed PJP4, PJP5 & PJP12 and after the PQ4,PQ5, PQ6 & PQ7.
                          the VREG still is low
                          Could the second TPS I had to be faulty too? I don't have more to try.
                          09-18-2023, 03:28 AM
                        • phantomEVO
                          [help]820-01700 "mistery problem"
                          by phantomEVO
                          Hi to all, i don't know the real history of this board.
                          the technician who gave me this board says: "i don't know the history of this board, it not switch to 20v. i have changed ub300 and ub400, than i've discovered to have short on 5v andi i have changed u7650. still 5v not switching"
                          so under microscope i've found
                          - shorts on rb246,rb401,rb400
                          - u7650 (tps51980b) changed with (tps51980A)
                          - j6640 melted (maybe some one has reflowed or changed u3100 or u3200?)
                          so i've bouth another identical board anche...
                          02-12-2025, 03:58 PM
                        • kitt7
                          Need help on Macbook air 1466 with board 820-00165-A. Doesnt turn on
                          by kitt7
                          Hi Everyone, I need help on my mac 820-00165-A. Here is the problem:
                          1. Mac does not turn on when power key pressed. Adaptor shows green then amber and stuck to amber. I tried to reset SMC using the keyboard techniques. Still it doesnt power up.
                          2. Prior to this, i plugged the MAC at 220v power outlet while it is off and took around 2-3 days plugged in at OFF condition without anybody using it for 3 days. The repairman i talked to said that it is wrong to leave the laptops OFF and plugged in and charged for very long time.
                          3. As i know a little about...
                          02-03-2019, 03:45 AM
