LA-3741P issue with TPS51120
    I need some help with this MB.
    Schematic available at
    https://www.badcaps.net/forum/showth...24#post1272124
    I have the 19,5V but not the 3,3 & 5 V.
    TPS51120 gets warm
    VREF2 = 2.00V
    VREG3 = 1,01V
    VREG5 = 4,99V
    so far I have replaced the TPS but with same results
    I cannot find any short
    I have removed PJP4, PJP5 & PJP12 and after the PQ4,PQ5, PQ6 & PQ7.
    the VREG still is low
    Could the second TPS I had to be faulty too? I don't have more to try.
    Re: LA-3741P issue with TPS51120
    Check if the +RTC_CELL /+3.3V_RTC_LDO & PC30 capacitor for any short And check the resistance to ground Diode mode pin 9/12/ 29/19
      105K at PC30
      22K at +RTC_CELL
      I have also injected 3V at PC30 to see if anything heats up but nothing came out.
        Maybe the TPS replaced is faulty or +3.3V_RTC_LDO line is connected to PC 118 / PU7 check these two components fault
          PR160 is missing from the pcb and there is no connection between +3.3V_RTC_LDO and the PC118 / PU7
          TPS could be faulty but it's strange that it has same output with the original one
