Maxxair 4500K RV roof fan only works on intake, does not exhaust
  • withalligators
    • Jun 2013
    • 267
    Hey folks,
    I have a sprinter for field work. To keep it from getting roasting hot by 6am, I have a Maxxair RV fan installed high on the rear door to both exhaust (say if I'm cooking) or intake cooler from air from outside. It became functionally intermittent and just in the last few days has ceased exhausting. The motor sees no power when it should be exhausting, which leaves the control board as the culprit. Rather than simply replace the entire board which is a bit exhorbitant for what it is, I am wondering if there is a particular component likely to be at fault that you smart folks might identify.
    If I had to guess, I would say the big HK14FD relay has probably failed.
    • 31158
    Re: Maxxair 4500K RV roof fan only works on intake, does not exhaust
    "ROSH compliant" ??
    ba haha.
    thats supposed to be "RoHS" removal of hazardous substances.
    it does look like the relay flips the polarity, but check if it's actually getting power to the coil before condeming it
    • diif
      • Feb 2014
      • 6978
      • England
      Originally posted by stj
      "ROSH compliant" ??
      ba haha.
      No it's not. RoSH is Restriction of Hazardous Substances.
        • 31158
        keep trying, re-read your post
        • redwire
          • 3912
          "ROSH compliant" ??
          No it's supposed to read "ROSH COMPLAINT" hahahaa Xi is going to punish that guy
          OP, the IR remote receiver modules I have seen also go bad. Also check if the remote is the problem. A flaky relay can be flushed out by gently tapping them when on.
          • CapLeaker
            Leaking Member
            • 8292
            Either the relay failed, the relay coil failed, or the relay isn’t getting energized.
            • R_J
              • 9581
              Does the fan work on intake? if it does, can you vary the speed? If used, does the lift motor operate and open the vent cover? or is this just manual cover opening? Have you checked the (poly) fuse on the board?
              • CapLeaker
                Dell ATX PSU won’t start, but forcing it works fine?
                by CapLeaker
                Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                10-28-2024, 06:59 PM
              • rounin
                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                by rounin
                🛠 Original Issue
                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                04-19-2025, 01:18 AM
              • ex250
                Kenwood SW-505D no sound issue and pops from time to time when it works
                by ex250
                Hello mates,
                I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
                It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
                12-29-2024, 03:27 PM
              • eurowill
                a2141 820-01700 internal display not working / external works
                by eurowill
                Hey ya'll this is my first post on here. I recently aquired a used/broken 2019 mbp 16 a2141 with the 820-01700 board. Seller told me that the laptop needed a new lcd. However upon doing some troubleshooting i found out the lcd is fine.
                Laptop boots like a normal, plays chime, touchbar lights up however there is no image on the internal lcd. If i connect and external monitor while its already on, nothing happens and no image is displayed on external. However if i restart or boot the machine while its plugged in, the external then works and a backlight is now visible on the laptop....
                07-23-2024, 10:06 AM
              • vf fa
                EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
                by vf fa
                Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
                I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
                So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
                01-31-2024, 01:40 PM
