PS5 brief power won't start
  • Themi
    • May 2020
    • 79
    • Scotland
    powers on + beeps briefly for a second displaying a blue light then powers back off
    • checked all fuses ok
    • checked for voltages, found 12v, 5v, 3.3v, 1.8v (I am not 100% sure where to successfully check for all)
    • started checking each inductor ohms to ground, all ok apart from a 1R5 near the DCIN, shorted 0.3ohms
    • checking components around the inductor appears a small plane on the front of the board is shorted progressing through to a plane on the rear side
    • surrounding circuits not on this plane are not affected
    • I have check caps around the board in each various circuit for a similar short and have found none (so far)
    • everything appears localised to this single area
    • I did remove the mosfet on the right (stupidly) as I had a lapse of judgement and forgot the inductor to the right was still in circuit. I tested it off board anyway and it's fine
    red shorted (0.3ohms) , blue not shorted
    shorted inductor
    top of the board
    back of the board
    mosfet? end of the back of the board shorted trace (I can't find a datasheet)
    I don't have voltage injection + thermal yet but I'm in the process of buying both.
    I am wondering where to progress through to next. The short seems so localised to this single area that I am tempted to start removing the ceramic caps but wondering if anyone has any further input.
    Last edited by SMDFlea; 05-02-2022, 03:11 PM. Reason: images copied to badcaps from external image host
  • Themi
    • May 2020
    • 79
    • Scotland
    Re: PS5 brief power won't start
    found out it was one of the small caps below one of the mosfets which had gone bad, replaced it for another and it's back up an running
    • kjchatman
      • Dec 2012
      • 198
      • united states
      my ps5 power supply is only supplying 6 volts. can i use my bench power supply to troubleshoot the board?
        • 31003
        if the psu is only supplying 6volts - shouldnt you fix it first?
        • kjchatman
          • Dec 2012
          • 198
          • united states
          my ps5 has a display for a split second then it beeps 3 time and cuts off
          • HelpMeRepair
            • Jun 2022
            • 62
            Hi Themi do you remember where was that BAD CAP exactly ? =) thanks
            • Aliseo
              • Dec 2022
              • 12
              • Italy
              do you try to inject voltage?
              • Themi
                • May 2020
                • 79
                • Scotland
                sorry I've only just seen this.
                you still need the info?
                • keklikelektronik
                  • Apr 2022
                  • 7
                  • bulgaria
                  first you try remove the coil.which side is short.next remove the smd caps first.and mosfet.i think its a shorted mosfet.
                  • Son23
                    • Mar 2023
                    My ps5 dropped and has same issue 1 second blod.
                    Back and around the APU the capacitor are shorted. Is this normal?
                    I don't see any video where these capacitors are measured.
                    apart from that everything is alright and can’t find any other problems.
                    I would appreciate any help!
                    • CapLeaker
                      Leaking Member
                      • 8135
                      Is it just low on resistance or is it a dead short?
                      • Son23
                        • Mar 2023
                        Dead short
                        • lotas
                          • Jan 2016
                          • 4576
                          • Russia
                          Originally posted by Son23
                          Dead short
                          What is shown in the photo is the choke (inductors), they will show a short circuit.
                          If it fell, then the chip most likely fell off (the processor under the radiator), only a reball will help, if the nickels on the motherboard under the processor have not come off.
                          • vinse
                            • Nov 2018
                            • 9
                            • france
                            yes and should be 12v
                            • vinse
                              • Nov 2018
                              • 9
                              • france
                              Dead short
                              not sur dead short on those beware tey have low resistance
                              • itech4u
                                • Nov 2023
                                Hello can someone help my were i can get this cap.
                                • CapLeaker
                                  Leaking Member
                                  • 8135
                                  Just about any electronic component store like Mouser, DigiKey, or eBay and AliExpress etc. Take a measurement of the size of the cap to the left of your missing one and figure out the SMD size like 603 or 402 etc. Measure the capacitance from that cap, order what you need and Bob is your uncle. Or you get a donor board from eBay etc.
