Aquarium PCB - shorted FET?
  • magneh
    • Apr 2014
    • 589
    • Portugal
    Hi there
    I have an aquarium PCB for pump control that is shorted.
    I found the short, seems to be one of the pump driver Fet
    Can anyone help me identifying this IC?
    googling the reference on it does not help apparently.
    Any idea of a correct replacement for it?
    Some pics attached.
    The reference on the IC is Si4020 NX7Y32
    Any help is appreciated!
    • 31048
    Re: Aquarium PCB - shorted FET?
    made by siliconix - owned by vishay
    • magneh
      • Apr 2014
      • 589
      • Portugal
      Thanks, how can that help finding a correct replacement?
        • 31048
        find a datasheet - or email vishay
        • redwire
          • 3910
          I could not find datasheets for the oddball mosfets. Nanxin data:
          Si4020 N-ch 40V 20A 4.5V logic level drive, RDS-on 15-20mohm 10V drive, RDS-on 32-40mohm 4.5V drive
          Si4015 P-ch 40V 15A 4.5V logic level drive, RDS-on 34-42mohm 10V drive, RDS-on 57-70mohm 4.5V drive
          I would look at Alpha&Omega parts, maybe AOD240. I'm not sure what parts are available in your country.
            BTW, are they all shorted out? It looks like bridge drive setup so the driver IC outputs are driving all the MOSFET's on, you need to check otherwise you may blow up your new MOSFET's.
            You should provide the pictures of the whole top and bottom side of the board and how all the boards and other parts are connected together.
            • magneh
              • Apr 2014
              • 589
              • Portugal
              Hello!
              No, only one of them is shorted , one of the Si4020.
              Short went away after removing this one, which tested bad with multimeter.
              All the others seem to be ok
              So should be fine, Replacement FET ordered, will update when it arrives.
              Thanks all for the precious inputs!
              • magneh
                • Apr 2014
                • 589
                • Portugal
                Hi Redwire!
                Thanks for these inputs, very helpful.
                BTW, how did you find that Nanxin data?
                Bit lost how to look for those for next time.
                Any explanation is much appreciated
                Cheers!
                • magneh
                  • Apr 2014
                  • 589
                  • Portugal
                  Quick update.
                  Got the replacement FETs
                  Happy PCB again!
                  • R_J
                    • 9550
                    These are the best I can find for datasheets
                    • redwire
                      • 3910
                      What make and model is the pump? For others who might have to repair one.
                      I would also check the electrolytic capacitors, they look kinda cheap and these pumps must be on all the time.
                      • magneh
                        • Apr 2014
                        • 589
                        • Portugal
                        Sure, this is the reference the owner gave me:
                        Maxspect gyre
                        bi-pompe xf 230
                          • Jul 2011
                          • 6040
                          If I were repairing this unit I would recommend replacing all of the capacitors on this controller unit
                          • reessi
                            Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                            by reessi
                            Hello:
                            I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                            I started on the ACER:
                            Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                            All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                            I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                            10-29-2024, 11:31 AM
                          • Yanleb
                            Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                            by Yanleb
                            Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                            I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                            D608, good
                            D618 RF101L4S, good (See warning 1 below)
                            D619 RF101L4S, good (See warning 1 below)
                            D865 RF101L4S, shorted (See warning 1 below)
                            IC464 Inverter HA MC74HC1G14, shorted...
                            03-09-2020, 12:00 AM
                          • modtool
                            HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                            by modtool
                            Hi to all,
                            the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                            I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                            I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                            04-01-2025, 08:22 AM
                          • BalkanBoy
                            Dead Razer Blade 14 2022, shorted CPU?
                            by BalkanBoy
                            today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                            Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                            I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                            Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                            I removed coil and injected 0.7V, it draw around...
                            09-27-2024, 12:44 PM
                          • barry101
                            Apple 820-3662 VCore shorted to ground.
                            by barry101
                            Hi, Would appreciate some help.
                            I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                            Get charger light but no fan spin or chime. No liquid damage.
                            Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                            Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                            With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                            Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                            06-24-2025, 07:34 AM
