Nintendo Switch component identification
  • knu7nuk3m
    • Apr 2018
    • 8
    Hi there,
    I have been using this forum since a long time, and i could always find help by just searching the existing threads for informations. It seems like this is a great and helpful community.
    However, i coundn't find info anywhere on this particular problem i have right now.
    My Nintendo Switch works fine, until i plug in the official charger, then the switch itself charges, but the controllers and the Fan stops working/charging. It still works with a Regular 5 Volt Charger. So i guess it has something to do with the Step Down line from 15 Volts to the Voltage the controllers and the fan need.
    So i opened the device and searched for problems under my microscope. I found an 8 Pin SMD part with a big hole in it.
    I need some help identifying/sourcing this broken part for my Nintendo Switch.
    I added one photo from the Internet, because on my board the part has a big hole in it, so i couldn't read the complete SMD Marking from mine anymore.
    The Marking on the Internet Says: DC0 SE5
    The Marking on my Part Says: DC0 (Burnt hole) 5
    I think it might be a DC DC converter or a dual channel mosfet, but i coundn't find the info anywhere.
    Can you guys please help me out?
    Greetings from Germany
    Gerald
  • R_J
    • 9569
    Re: Nintendo Switch component identification
    I found another picture with DC0 S41, so I suspect the last 3 letters are a date code. It might be a custom number for nintendo
    • CapLeaker
      Leaking Member
      • 8265
      found also a picture with DC0 551. I did do a code search with DC0, but didn't come up with anything satisfactory.
      • knu7nuk3m
        • Apr 2018
        • 8
        Thanks for the effort so far.
        Yes the only thing i found so far was an Analog Devices DAC, but the Pinout is wrong, and I cannot believe that it would be a DAC.
        • CapLeaker
          Leaking Member
          • 8265
          I found that one too... and no, that isn't a DAC.
          • digby1951
            • Jan 2017
            • 36
            http://logiwiki.shinycomputers.com/i...ClCwnHCzaCuwVU
            • knu7nuk3m
              • Apr 2018
              • 8
              Thanks for the reply Digby, but the Link is for the Switch Lite model. The Board Layout is different. And from what i could see in the Pictures, the Part i'm searching isn't on there.
              • digby1951
                • Jan 2017
                • 36
                dco551
                https://www.tronicsfixforum.com/t/in...art-numbers/91
                double click to expand........may help.......he does a lot of switch's
                • R_J
                  • 9569
                  What are the voltages on the pins now? If it was a buck down converter it would have an inductor connected to it.
                  • knu7nuk3m
                    • Apr 2018
                    • 8
                    Thanks again for the replies,
                    i have disassembled a second defective Nintendo Switch which often freezes (i tried to reflow it in the past, ....it still freezes) but it should be okay for measurements. I have measured the voltages when charging a battery, and I measured resistance to ground in diode mode (positive to ground and neither battery or USB-C connected)
                    I mean i could use the part of the other Board, but as I dont know what caused the hole in the part, I would like to have a few replacement chips in stock before trying to do something like this. It would be terrible if i salvage this part, put it in the other Switch and it burns again.
                    Also i think it would be helpful for others to know what you could use if they have a similar problem.
                    Yes I know I shouldn't leave the Board in all that Flux. But its no-clean Flux so I took it literally.
                    • knu7nuk3m
                      • Apr 2018
                      • 8
                      I also plugged in the Battery of the other Switch and on Pin 1 I could measure for a short time 5V. I guess it has something to do with Slow/Fast charging. After a few seconds the Voltage was going down to 0V there.
                      That would also explain, why the Switch works fine on a 5V Supply, but not on the official Nintendo 15 Volt Supply.
                      • digby1951
                        • Jan 2017
                        • 36
                        hi.......try
                        https://www.youtube.com/results?sear...=my+mate+vince
                        watch his videos
                          • 31115
                          vince doesnt have a clue about electronics!!
                          • digby1951
                            • Jan 2017
                            • 36
                            i didn't say he did...........but interesting.........
                            • jikonik
                              Nintendo switch Help about Component identification
                              by jikonik
                              Hello I have a nintendo switch HAD-CPU-10 and the component in the red circle is knocked... any help to identify it will be highly appreciated!
                              03-25-2024, 01:05 PM
                              Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                              This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              09-06-2024, 05:30 AM
                            • Tomylee
                              No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
                              by Tomylee
                              Sorry for the person who’s going to read all this !
                              I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
                              While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
                              During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
                              07-11-2025, 11:52 AM
                            • estabilito
                              Nintendo Switch Oled dead
                              by estabilito
                              Hello, i bought dead nintendo switch oled.
                              after plugging charger with amp meter device shows 5v and 0,0 or 0,02 amperage draw.
                              I inspected motherboard and someone tried to reflow or replace m92t36 and didn't do it well, i resoldered it proper and find that usb-c fuse was blown too(replaced it).
                              After this device started to draw 15v and something around 0,48 but only for few seconds after this returned to 0A draw.
                              I tried to plug motherboard without battery - shows 15 0A and when charger was pluged i put battery back in then console started to charging battery but stuck...
                              05-07-2024, 03:48 PM
                            • tommy97
                              Nintendo Switch Oled - Joy con charging
                              by tommy97
                              I'm having an issue with a Nintendo Switch OLED that suffered liquid damage. After a full cleanup and replacing the Joy-Con rails and joysticks, everything was working fine for about a week. However, now the Joy-Cons won't charge or connect again.
                              I tested with a second set of Joy-Cons, and the issue persists. Measuring the voltage on the connector shows 3.7V instead of 5V, which I believe should be the correct value.
                              Any insights or suggestions on what could be causing this?
                              03-17-2025, 06:30 AM
