Nintendo Switch Oled - Joy con charging
  • tommy97
    • Mar 2023
    • 165
    I'm having an issue with a Nintendo Switch OLED that suffered liquid damage. After a full cleanup and replacing the Joy-Con rails and joysticks, everything was working fine for about a week. However, now the Joy-Cons won't charge or connect again.
    I tested with a second set of Joy-Cons, and the issue persists. Measuring the voltage on the connector shows 3.7V instead of 5V, which I believe should be the correct value.
    Any insights or suggestions on what could be causing this?
  • tommy97
    • Mar 2023
    • 165
    Any ideas?
    • Unspun01
      • Jun 2011
      • 349
      Nominal voltage of most lithium-ion or li-po batteries is 3.6-3.7V, so you would definitely need a voltage larger than that to charge your batteries. Almost every lithium ion rechargeable device we use, which charges from a regular USB cable uses 5V to charge a 3.6-3.7V battery. I think you are correct that the voltage is too low.
      I suspect there is more corrosion that you have not seen or located. Go over all affected areas with good magnifying lens. Use isopropyl alcohol. Use 99%, not 70% grade or 50% grade because those lesser percentage ones have too mush water in them to be useful.
      Also, double check that you are not missing any surface mount caps or resistors that may have come off or been damaged due to water damage.
      Do you have any photos? maybe someone will spot something out of the ordinary.
      • fab13
        Nintendo Switch lite charging chip heats up and does not short circuit
        by fab13
        Hello everyone
        Small technical problem on a Nintendo Switch lite
        Here's what I noticed: the USB port has been damaged internally, with a short circuit on the power supply line to the small fuse.
        After replacing the USB connector, the short circuit went away and I can't see any other short circuit in the whole motherboard.
        When I charge the console, it seems to be charging: I get 15 volts and an amperage of 0.450 A.
        Then, after a while, the amperage increases to 1.1 A and the BQ24193 charging chip starts to heat up, as evidenced...
        09-16-2023, 04:59 AM
      • nebulink
        Nintendo Switch-No Shorts and not charging
        by nebulink
        This is a strange one for me. I have a Nintendo switch that turned on initially. The BQ chip was getting very hot. I unplugged and tried a different battery in case there was a problem with them one that came with it. I was told that the battery had been swapped.
        After trying a new battery, the unit would not turn on.
        Ammeter shows 15v 0 amp draw.
        Tested around BG, P13 and M92. No shorts. Decided to swap out BG. Same result.
        Checked voltages around BG, M92 and Max 177050.
        Also checked Max 177621.
        Getting desperate, I changed M92. Nothing
        I changed...
        06-23-2024, 03:22 PM
      • privato89
        Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
        by privato89
        I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
        Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
        Let's begin:
        Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
        03-26-2024, 06:37 AM
      • coasterghost
        Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
        by coasterghost
        For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
        Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
        Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
        System Hardware:
        Processor: AMD Ryzen 7 PRO 5850U
        Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
        09-08-2025, 10:46 PM
        Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
        This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-06-2024, 05:30 AM
