Nintendo Switch Oled dead
+ More Options
Posts
  • estabilito
    • Aug 2020
    • 55
    • poland
    Hello, i bought dead nintendo switch oled.
    after plugging charger with amp meter device shows 5v and 0,0 or 0,02 amperage draw.
    I inspected motherboard and someone tried to reflow or replace m92t36 and didn't do it well, i resoldered it proper and find that usb-c fuse was blown too(replaced it).
    After this device started to draw 15v and something around 0,48 but only for few seconds after this returned to 0A draw.
    I tried to plug motherboard without battery - shows 15 0A and when charger was pluged i put battery back in then console started to charging battery but stuck on 0,48A (this time, stays on this level and battery charge going up).
    Even when i tried to turned it on using this method with putting battery after plugginch charger console won't turn on and when i try to click power switch - draw drops to 0A.
    No shorts on board - checked all typical problems with M93T36/BQ/PI3USB caps and no shorts at all.
    Im thinking about replacing M92T36 with new one but i have no experience with this consoles.
  • chickenhawk88
    • May 2024
    • 86
    • US
    I followed/used the info from this guide and it was helpful for me to understand a little better. Do you have hot air station to do the repairs? You mentioned you resoldered the m92t36 chip, meaning you reflowed it or just touch up the solder points ?
    • tommy97
      Nintendo Switch Oled - Joy con charging
      by tommy97
      I'm having an issue with a Nintendo Switch OLED that suffered liquid damage. After a full cleanup and replacing the Joy-Con rails and joysticks, everything was working fine for about a week. However, now the Joy-Cons won't charge or connect again.
      I tested with a second set of Joy-Cons, and the issue persists. Measuring the voltage on the connector shows 3.7V instead of 5V, which I believe should be the correct value.
      Any insights or suggestions on what could be causing this?
      03-17-2025, 06:30 AM
    • CraigR
      Nintendo switch dead.
      by CraigR
      I got in 2 Nintendo switches that appear dead but the amp meter shows charging. I removed the board and just the plain board plugged in with no battery and it draws 0.10A so I checked for shorts and did not really find anything but under the thermocam I see the MAX77620A chip lights up on both of these. I never had to replace that chip before. Is this common and just my luck I get 2 in a row? Or is this normal and I should look elsewhere? I have also replace the M92 and BQ with same results.
      12-19-2024, 06:01 PM
    • privato89
      Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
      by privato89
      I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
      Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
      Let's begin:
      Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
      03-26-2024, 06:37 AM
      Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
      This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
      09-06-2024, 05:30 AM
      ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
      This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
      09-07-2024, 04:30 AM
