York AC X800 treadmill
  • warsztat
    • Feb 2017
    • 190
    • Polska
    I know that the forum is about specific topics but I have a question that I am looking for answers
    York AC X800 treadmill, after switching on the effect as in the picture.
    Nothing else works.
    Possible blockage by ignoring the message about necessary service (maintenance). I haven't researched it yet so maybe it's just a bug. Asking for reset procedure if any.
    Possible it may be worth creating that section in this forum, to check interest.
    If this topic is undesirable, I am sorry admin and the topic can be deleted.
    Regards.
    • 31298
    Re: Trademill
    looks dead - time to open it and look at the power circuits!
    • warsztat
      • Feb 2017
      • 190
      • Polska
      Re: York AC X800 treadmill
      I will do it, but there is a green light under the lcd.
        • 31298
        yes, but the logic may have a different supply voltage.
        • warsztat
          • Feb 2017
          • 190
          • Polska
          possible, I will deal with it soon
          • warsztat
            • Feb 2017
            • 190
            • Polska
            Hi, after open cover the cable connecting the console to the engine module turned out to be crushed.
            The transmission belt is ok, i can adjust the speed.
            Elevation adjustment not work, initially after connecting the grade elevation display showed two zeros,
            position change attempt ended with switching off the device, after restart there are no zeros, only two lines, no reaction to the height control buttons.
            Check has detected an incorrectly connected elevation motor.
            It looks like console lock, how to unlock it?
            I tried to change the position of the elevation so that the coupled potentiometer showed other values, but it does not work.
            I hope that I write clearly, my English is still poor, for which I am very sorry. I hope that participation in this forum will change that.
            • R_J
              • 9628
              Did you repair the crushed cable?
              • warsztat
                • Feb 2017
                • 190
                • Polska
                Not yet but all line ok, now no short circuit or broken line.
                  • 31298
                  if the elevation motor has limit switches i would check them,
                  also check the motor is o.k.
                  do you own this unit?
                  i am wondering what it does normally - like does it try to move the motors to the lowest position when it starts.
                  • warsztat
                    • Feb 2017
                    • 190
                    • Polska
                    This unit not my, after on power elevation motor does nothing. Trademill belt ok, i can set the speed & the belt is moving.
                    I check limit switches in elevation motor, it ok.
                    Giving power to the engine i can change the angle of inclination but the computer does not reset it after startup, does nothing only print two lines on display. As i showed in picture.
                    Thank you interest.
                    The situation looks like deliberate blocking of functions after an error.
                    • R_J
                      • 9628
                      Were any of the crushed wires, insulation damaged and if it was, did that wire short to another wire in the cable or did it short to the chassis? If it did I would check for a damaged component in the console where the wire connects.
                      Someting else to try (if you have'nt already) is move the elevation to its lowest position, then plug the unit in and see if it resets the elevation display.
                      • warsztat
                        • Feb 2017
                        • 190
                        • Polska
                        Not reset elevation display. Wire short to by another wire. I found no damage on the modules on the console cable connectors with the motherboard.
                        My problem is similar to :
                        https://www.justanswer.com/fitness-e...ner-light.html
                        But maybe I am mistakenly suggesting.
                        • warsztat
                          • Feb 2017
                          • 190
                          • Polska
                          Hi, I received the procedure, I will try it on the weekend. if it is confirmed I will describe it in the forum.
                          Why I have so short time to editing in forum post ?
                          • warsztat
                            • Feb 2017
                            • 190
                            • Polska
                            Plug power, on power
                            Press "Slow" & "Stop"
                            Press Fast & Stop (all leds off)
                            Press "Slow"
                            Press "Slow"
                            Press "Start" - Clear error
                            Press "Fast"
                            Press "Start" - Run calibration
                            wait
                            I hope I have not mistaken anything.
                            • wzamoyski
                              Treadmill controller (zipro dream (?)) - PCB-ZYXK9- 1111-V1.2.PCB not working
                              by wzamoyski
                              Hello
                              I received a treadmill controller (probably Zipro Dream) for repair (more like replacing parts). Board designation: PCB-ZYXK9-1111-V1.2.PCB. existing in it were:
                              • mosfet Q9 (originally MDF4N60 was installed) - mounted on P10NK60ZFP;
                              • resistor R64 (replaced);
                              • F2 protection.
                              After turning on the power of AC1 and AC2, the components burned again. The existing elements were desoldered and new ones were soldered. The controller has not been connected yet because I'm afraid they would be destroyed again.
                              There are no additional restrictions that can be applied,...
                              02-26-2025, 02:29 AM
                            • xTomtom
                              Treadmill hit with power surge
                              by xTomtom
                              Recently I acquired a treadmill that was hit by a power surge (I assume). On the control board, there was a varistor that was blown apart and two traces that were partially blown out. I replaced the varistor (to my knowledge it is a matching one) and wired back where the traces were with some 22 awg solid copper wire. When I went to power it on, still nothing. On a quick inspection with my meter, I was getting incoming voltage on the AC in terminal.
                              The board is a MC2100LS-30 treadmill controller.
                              Visibly, there are no other problems....
                              05-09-2023, 08:06 PM
                            • bryanX
                              Control board for treadmill Horizon Omega II
                              by bryanX
                              Hi guys!
                              Firstly, I will apologize if my topic is in the wrong section, please move it if necessary.
                              I want to repair one treadmill from the brand Horizon the model is Omega II. Practically, the motor power control board has suffered one damage.One mosfet has blown and I suppose by doing that, the short circuit has damaged a couple of diodes, one zener diode and two transistors. I hope that is all. I will find out when I will put them all back on board. I have dismantled and cleaned the rotor of the DC motor, tested it, and it seems to be working properly. I suppose it was water...
                              03-05-2024, 01:11 PM
                            • Sheppma
                              Reebok treadmill PSU SW01-CA-REV1.0 blown
                              by Sheppma
                              Hi, I have a Reebok treadmill PSU SW01-CA-REV1.0 (KSW13) that's blown, I can identify most parts but have diode D7 and chip capacitor C8 that have burnt out and are unidentifiable - does anyone have a schematic or a PCB they can identify the parts from?...
                              01-31-2023, 08:22 AM
                            • G0RIT
                              Reebok one GT40s treadmill lift motor runs at switch on
                              by G0RIT
                              Good evening I am working on a Reebok oneGT40s treadmill. It had a flashing display which the replacement of D3 rectified. However the lift motor now runs when the mains is turned on and does not stop. If I then select start so the tread motor runs and disconnect the up lead to the lift motor it stops. If I then reconnect the lead the lift motor works as it should with the controls. It will continue to work correctly until the mains is turned off and on again, or the safety device is removed and replaced. It then runs again and only by disconnecting and reconnecting the up lead will it operate...
                              06-23-2022, 05:57 PM
