So one of my most detested repair scenarios, does anyone else dislike working on their own equipment. So I use this scope mostly for testing capacitors, relays and occasional testing of hot side switching PSU's and have had it for years it failed the other day which is an annoyance mostly since I like the scope's compactness and that it can be run from battery. Well the likely culprits included a leaking electrolytic and a bunch of really bad solder inc some split 100 nf caps see below although I have already started reworking the boards. It is now more or less functional besides the supply board putting out a lower voltage than expected. I am trying to source 6 tagged D cell rechargeable batteries for this, they all seem ridiculously over priced and I don't have a spot welder to attach my own tags
Telequipment D34 oscilloscope
Re: Telequipment D34 oscilloscope
I managed to find several sets used in emergency lighting that I'm going to adapt. The originals were 4000 ma and based upon the 1800 ma draw from an external power supply I will get around 2 hours continuous usage from the new set when fully charged.Comment
Would still leave me the problem of spot-welding tags to each cell, I would need the cells configured as pre-tagged which for some reason makes them very expensive. Maybe I should take this opportunity to construct one.Comment
The setup inside the scope is quite tightly packed, the D cells are arranged in two packs of three stacked side by side being clamped in place with insulated metal brackets. With each pack occupying a tight spot on each side of the tube. Anyways I have an appropriate set on order now which leaves the question of a DC short spot welder which I have developed an interest in building.Comment
I have not been able to measure that current draw from the pack yet due to the installed pack being non serviceable, when supplied via and bench supply in place of the battery pack the device draws about 1.8 amps.Comment
Looking at the data sheets for these batteries the discharge curves etc and assuming they are not some cheap copy, they are high temperature and suitable for a discharge rate of up-to 4amps. So should be more than suitable, I can always check charging and discharge characteristics before final installation.Comment
Well it lives, packs have been installed and seem to be charging nicely, in operation as far as I can tell the discharge rate is around 1.4amps maybe a little less. This anomaly is to the way the packs are configured one bank of 5 cells at 6 volts and a single cell at 1.2 volts while this does not appear to be the case when referring back to the circuit with the battery pack shown as configured for one pack of 7.2 volts. I am not intending to investigate the discrepancy further.Attached Filesif you find these attachements useful please consider making a small donation to the site
I would make sure the charger is OK, schematic shows always on constant-current 340mA charging, no voltage limit.
Main power is a two-transistor DC-DC that is unregulated which seems unusual. No idea what the oddball cell is doing.Comment
Yeah I measured around 200-300 ma charging current which is around that specified for the cells, I was concerned about the charging pcb since one of the failure modes encountered on this repair job was significant corrosion on the charging board and some corroded solder joints. This was likely related to the leaking electrolytic filter capacitor nearby. I had reworked most damage before getting around to take photos but if you look closely at the images you will see some of it.
I left the scope on charge over night to top off the new battery pack looking at bench meter I have 7.2 volts charging which seems reasonable. Due to the schematic showing always on its not my intention to leave the unit plugged in all the time.
Anyways I do like the JINHAO P6100 scope probes, they were obtained cheaply from Ebay, they seem to be of reasonable quality and hopefully not some knock off lol.Comment
Hello.
I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
I want to learn how not to damage it, and I found instructions on the internet obscure.
They talk about ground, earth, floating ground, this, that....
But they don't actually say anything anything useful so far.
I want to know:
Don't connect exactly this to exactly there or it blows up.
For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
I want to know what not to connect... -
by EvetsI have recently acquired a Dynamco D7100 analogue oscilloscope without a user manual. As this is the first time I have owned or used an oscilloscope I would like to try and find an instruction book. The manufacturers no longer hold any information and a Google search only found one site but when I downloaded a 'service manual' all I got was gobbledegook. Any help would be gratefully appreciated or even pointers to a generic manual where I could learn more.
by SolomonManAll,
Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor... -
by BartoloniHi, i have a Lenovo S145 that after 20 seconds shutdown and restart (it's working correctly on thse 20 seconds)
everything seems ok, but on Vcore inductor ( this is an i3 with just 1 switching power supply for CPU)
there is an output to teh CPU with a spike.. seems that inductor can't handle the input...
replaced the capacitor (330) and the inductor (R15) without any change
any idea? very thank you!
input of the inductor seems as usual... only strange thing is that the upper/lower voltages seems to be 21V (main power line is 19.3) ... but not sure this... -
by repair-itSearched online but wasn't able to find. Trying to locate a copy of this document - AutoLeap Oscilloscope Handout.
- Loading...
