Aron bs-601 scope issue
Re: Aron bs-601 scope issue
Those voltages on the schematic are the PSU voltages and probably not enough to debug with. Not sure what else but to just trace things along since you have the other scope and have that signal generator (the probe calibration source). Else it is still possible to debug with a multimeter with the vpos pots.
I'd especially like to know what the voltages are on Q21 and Q22 as you spin the vpos pot up and down...Comment
I can test that, witch pins should i test on? and do you want a voltage readout or a scope signal? and witch pots to test with?Those voltages on the schematic are the PSU voltages and probably not enough to debug with. Not sure what else but to just trace things along since you have the other scope and have that signal generator (the probe calibration source). Else it is still possible to debug with a multimeter with the vpos pots.
It looks like you should have -8 volts going to the center of the vert. position control, That shouuld change the bias on q29 and q30 moving the trace up or down. You say you have all the voltages but where did you check them? they may be at P3 but do they get to get to where they should. There are a number of coils in the voltage lines, make sure the voltage is on both sides of them and one is not open.
Just so i dont stuff up, witch point should i test the -8? i haveonly tested voltages at the conectorComment
Curious as to the voltage on the collectors of both Q21 and Q22 with just one channel on, one measurement for when the vpos for that channel fully CCW and fully CW. There should be a significant difference of the voltage at that point I would guess for the two cases, ideally they should flip flop their voltages depending on which way the vpos pot is set...
I still wonder what the voltages across D10 R80 R89 D11 D14 are. Would imagine them to be something like 12V - D10 - 17V - R80 - 90V - R89 - 108V - R89 - 114V - D11 - 115V - D14 - 120V or something like that....
*sigh* lucky people with scopes that have schematics available... I wish my 20MHz scope had schematics somewhere. Not quite the same when you have schematics for a scope that has unobtanium ICs in them like the later Tektronix...Last edited by eccerr0r; 01-28-2019, 01:36 AM.Comment
U800
Sigh. If the U800 blows in my 2465, I don't know if it's worth keeping the scope or just parting it. Someone has hacked up a workalike but sheesh, needs to run with stable gain at something like 100MHz or so, maybe more in 10x mode.Comment
Is the vertical board easy to access? if it is You can check for the -8 volts on L4, It is located next to P1, You should also be able to check the voltage on P1, Pin 2 should be -8v and pins 1 & 3 will vary when you turn the vertical position control on the front panel for channel A
If you can, check the voltage on D10, (J5) then R80. also D11 and D14 they are near P2Last edited by R_J; 01-28-2019, 10:28 AM.Comment
Good to here he has it repaired.
FROM https://www.eevblog.com/forum/repair...-amp-issue/25/
EUREKA!!!! Found the problem!!! R80 was an open line! replaced with 43k and well, now we have full range on verticalLast edited by R_J; 01-28-2019, 02:21 PM.Comment
by ygorsanHi everyone,
🧩 Problem Summary:- The TV keeps scrolling through the menu or selecting items by itself.
- I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
- The remote control is not in use (batteries removed), and the TV still shows the same behavior.
- I
07-28-2025, 08:34 AM -
by rouninHi everyone,
🛠 Original Issue
⚠️ New Problem: One USB-C Port Only Works in One Orientation... -
by AstonishedHi friends of electronics
What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
Please help me fix this circuit.
(the datasheet of the IC: https://pdf.datasheet.live/28... -
by ugamazingI have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre... -
by shahnldGood day Experts
I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core... - Loading...
