A problem with an automotive trouble codes diagnosis device
  • belalmondeo
    • Dec 2018
    • 33
    • مصر
    #41
    Re: A problem with an automotive trouble codes diagnosis device
    will power up from the cars obd port
    Absolutely correct !, that's the way my device work, another thing to mention BTW which is an app called at530 included with the software folder which appears on this video https://www.youtube.com/watch?v=cw049QOIlTY
    at minute 8:26 from which You can display the device status when being connected to a vehicle including the firmware version of the (VCI) vehicle communication interface but none of these stuff show up and mine keep displaying a message of (Function in progress) then software won't respond, then the whole process stops !
    According to the pictures I've posted earlier in my 3rd post, does any of You guys know which IC\Chip on that board to have the firmware version if You're acknowledged enough about this business ?
    BTW thoughts of my English till the moment ?
    • CapLeaker
      Leaking Member
      • 8218
      Yeah, but without being plugged into the OBDII port, it will do squat.
      belalmondeo:
      The EEPROM AM29F040b holds 4 Megas. The 16c550c is a UART (in which you could maybe tap into). The Main IC sab-c161cs-lf is also flashable and got 16 Megas!
      Do you hear any relays clicking when you try to read a car?
      Your English is fine, don't worry about that.
      • belalmondeo
        • Dec 2018
        • 33
        • مصر
        #43
        belalmondeo:
        First of all, thanks for the uplifting reply regarding my language.
        Actually, I hear no clicks at all while I attempt to read, it also worths mentioning that it happened once to have the device responded just for once and it didn't repeat anymore by then.
        • CapLeaker
          Leaking Member
          • 8218
          The IC that does the comms to the car is the TJA1054T.
            • 31087
            i downloaded the driverpack 2.8.1.8
            i'm going to try to unpack it and see what that serial>usb chip is - it's still my prime suspect.
            • belalmondeo
              • Dec 2018
              • 33
              • مصر
              #46
              According to Your own experience, how can I specify a faulty chip either with the naked eye or using some diagnosis method - troubleshooting instead of wasting my time and money purchasing parts randomly and later I find out it wasn't defected ?
              • CapLeaker
                Leaking Member
                • 8218
                you need an oscilloscope and a good DMM with 50.000 counts. Then you just look at things in a streamlined manner. Pull datasheets and check things. No activity on the scope = dead. That's how I figure out things on PLL's, DDS IC's, etc.
                The naked eye method only works on catastrophic failures. Caps and IC's can fail, yet look perfectly fine outside, so one has to understand the circuit.
                  • 31087
                  my experience with chinese clones of diagnostic shit is that 99% of problems are related to windows and driver issues.
                  i mention windows because i had a box once, the software didnt work till i installed some chinese version of a standard update - i may have been looking for a dll or font not in western windows!!
                  • belalmondeo
                    • Dec 2018
                    • 33
                    • مصر
                    #49
                    Man, You're awesome I swear the god, thanks for giving me such useful guide to get started.
                    • belalmondeo
                      • Dec 2018
                      • 33
                      • مصر
                      #50
                      I've yet tried all of the drivers software version related to my issue except for the 2.8.1.8 which I'll try right on the next few days to tell if any changes has come to happen, I'm in an urgent need for a miracle.
                        • 31087
                        you need to find what driver/chip combination is being used for usb.
                        once we know the chip, we can do a simple test.
                        whoever sanded off the numbers should be shot in the head.
                        • belalmondeo
                          • Dec 2018
                          • 33
                          • مصر
                          #52
                          Consider a 50BMG if so for me Please
                          • belalmondeo
                            • Dec 2018
                            • 33
                            • مصر
                            #53
                            Hello again !
                            Since I really wanted to keep You all up to date with me, then I'd hate to say that my situation got from bad to worse
                            the device was supposed actually to work along when having it connected to the car and I can figure it by giving a red light out of the bulb then blinking green to know it runs with no connection problems but it gives nothing now but a green light when just connecting it for the first time and nothing else !
                            Does any of You have any Idea of a defected cap or varistor to cause such an issue / Do you know any part of the following located in the lower board can cause it ?
                            LIST OF COMPONENTS
                            S20K20
                            CTX33-1A
                            Coilcraft DO3316P-683(mld)
                            WURTH-865230653012-47UF,50V,RADIAL CAN
                            • belalmondeo
                              • Dec 2018
                              • 33
                              • مصر
                              #54
                              Note: the components mentioned above are replacements of the factory PCB for some rework.
                              I've unscrewed the db25 side of the obdII cable to check for any faults and everything was fine, there weren't any signs for damaged on the lower board db25 pins.
                              The picture shows the suspected parts, pic1 shows the pcb before any changes were done to it, the other shows these parts (Reworked).
                              • CapLeaker
                                Leaking Member
                                • 8218
                                sure it could be a signal not going through the bottom board (relay network). So to eliminate that, test the relays. For me I'd go to the top board.
                                If there would be a defective cap to GND, then something isn't getting power, but you didn't check yet if some voltage rail is missing, or something not getting any power. Other than a cap shorted to GND, I am going to rule out the caps. Could be an open inductor, open trace or a resistor that changed value to way out of spec. So then there are diodes, transistors and again the IC's. Something gave out at post 43. So look at my post #44 again. This IC is responsible for the communication with the car. Plus then there is still the original problem in which this tread started with (USB comms not working).
                                It makes sense to me that the light trick doesn't work, since the incident on your post #43. If that bulb trick works, you would have communication with the vehicle (which you don't!).
                                • belalmondeo
                                  • Dec 2018
                                  • 33
                                  • مصر
                                  #56
                                  Thanks for having me insighted.
                                  I'll have this postponed nowadays for being into 2 weeks of exams + being on tight budget to purchase any tools/parts !
                                    • 31087
                                    i looked at the software, you can extract it with "innoextract"
                                    it's 32 and 64bit, and it is using the FTDI usb drivers.
                                    • belalmondeo
                                      • Dec 2018
                                      • 33
                                      • مصر
                                      #58
                                      Update:
                                      I wanna thank everyone of You for trying the best of You !
                                      I've managed to contact the dealer and shipped back the defected item and he sent me an another one and it just works great so far since the last tuesday !
                                      thank You all again
                                      • theone111
                                        by theone111
                                        3. Problem: TV shuts down
                                        07-22-2024, 10:36 AM
                                      • Zeonalbasta
                                        Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                        by Zeonalbasta
                                        i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                        The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                        09-13-2024, 01:17 PM
                                      • Gibon378
                                        Problem with stopping audio and video for no reason
                                        by Gibon378
                                        PC Specs:
                                        • CPU: Ryzen 5 1600
                                        • GPU: GTX 1080 Palit JetStream
                                        • MOBO: ASRock ab350 PRO4
                                        • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                        • PSU: XFX 650W (don't remember what model)
                                        • OS SSD: ADATA SP920
                                        • OS: Windows 10 21H2
                                        Problem description:
                                        Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                        11-19-2022, 09:41 AM
                                      • perzyk23
                                        Lenovo T580 - LCD Panel problem - error 0288
                                        by perzyk23
                                        Good morning,
                                        I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                        10-25-2024, 12:42 AM
                                      • SDNarcia
                                        Dell 15R-5521 keyboard problem (KBC?)
                                        by SDNarcia
                                        Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                                        As additional information,...
                                        07-20-2024, 10:47 PM
