A problem with an automotive trouble codes diagnosis device
  • belalmondeo
    • Dec 2018
    • 33
    • مصر
    Re: A problem with an automotive trouble codes diagnosis device
    Originally posted by techman1025
    Hi
    Well in the device management any? Marks Showing next to the driver . If yes then you need to locate the correct driver once that is gone then you need to see why it's not communicating . Start with different cable.
    Techman1025
    Nope, for this point I actually haven't seen any since the first time I tried it, watch this video that I've uploaded on Youtube a while ago that shows everything I'm facing and for the device manager notice at first minute of the video at 00:42 that there's a drive known as (I+ME Actia XS Device) with no marks next to it !
    https://www.youtube.com/watch?v=JYkhgXAk_v4
    • belalmondeo
      • Dec 2018
      • 33
      • مصر
      elm thing is a joke .. ross tech is good as does programming but only for vag group .am looking at trying a Delphi for use with laptop pc next .
      Clone Passthru is not bad at all as well, just giving You an advice to purchase the 2011 version and get some rework done on it for a stable and quick performance in a addition to a hex dump for the latest software version for PIC chip on the board and You're good to go !
      Need more on that, talk to me and I'll give You the full guide.
      • belalmondeo
        • Dec 2018
        • 33
        • مصر
        On scale from 1 to 10 what's Your rating for my English till now ?
        • petehall347
          • Jan 2015
          • 4427
          • United Kingdom
          i want one i can simply install the software and use the device just like the ross tech one i have .
          • belalmondeo
            • Dec 2018
            • 33
            • مصر
            I understand, You want no complication right ?
            • petehall347
              • Jan 2015
              • 4427
              • United Kingdom
              #26
              as little complications as is possible . and late version . up to say 2016 should be fine ,i do have an all in one scanner but only a cheap launch viii that sometimes tells lies giving me codes for things that are not even fitted to the cars . and incorrect voltages and sensors output values ,
              • belalmondeo
                • Dec 2018
                • 33
                • مصر
                #27
                Launchs are actually known to perform better with asian manafacturers, for European and American cars You'd better go with Autel such as (MS906 - MS908).
                • petehall347
                  • Jan 2015
                  • 4427
                  • United Kingdom
                  #28
                  i dont have that sort of money .even if i had i would no way make it back .
                  • belalmondeo
                    • Dec 2018
                    • 33
                    • مصر
                    #29
                    Could the usb cable be the reason behind it ? it's 4 wires black (ground) - Green (Data +) - White (Data -) - Red (5V).
                    My idea is to replace it with a Printer cable and have the red wire disconnected as this dude did before as mentioned in this link: https://cartechnology.co.uk/showthre...light=fantomel (Post #34).
                    • CapLeaker
                      Leaking Member
                      • 8220
                      can't read that post. login required.
                      • petehall347
                        • Jan 2015
                        • 4427
                        • United Kingdom
                        #31
                        after looking at the ds150e clones that look very similar some are reporting they wont work on 64 bit systems . maybe it could be that and needs 32 bit .
                        • belalmondeo
                          • Dec 2018
                          • 33
                          • مصر
                          #32
                          Here is my China unit, I chopped the original cable off and used an old printer cable, its been working OK, sometimes very slow connecting.
                          I will change the small parts on the PCB to see if it helps, will the CTX50-1P be OK or is it best I change it ?
                          Said that guy I told about.
                          • belalmondeo
                            • Dec 2018
                            • 33
                            • مصر
                            #33
                            I've kept it in mind as the vendor instructs to install it on only 32 bit OS.
                            • CapLeaker
                              Leaking Member
                              • 8220
                              So you are using the serial port on your computer now?
                              • belalmondeo
                                • Dec 2018
                                • 33
                                • مصر
                                #35
                                I mean the modern printer usb cable !
                                • CapLeaker
                                  Leaking Member
                                  • 8220
                                  o.k. so you have to have a bad cable or a bad USB port on the OBDII device then.
                                    • 31090
                                    no, he cut the red so the computer does not power the device.
                                    it's possible that it overloads some laptops - a desktop would have unlimited current.
                                    • belalmondeo
                                      • Dec 2018
                                      • 33
                                      • مصر
                                      #38
                                      then that would be good anyway no matter I kept the red wire or cut it ?
                                      • CapLeaker
                                        Leaking Member
                                        • 8220
                                        and how does this programmer power up without 5V and only have the GND, Data - and Data + connected? I don't understand that.
                                        Interesting to see if there is a short between 5V and GND on that circuit board?
                                        • petehall347
                                          • Jan 2015
                                          • 4427
                                          • United Kingdom
                                          #40
                                          will power up from the cars obd port
                                          • theone111
                                            by theone111
                                            3. Problem: TV shuts down
                                            07-22-2024, 10:36 AM
                                          • Zeonalbasta
                                            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                            by Zeonalbasta
                                            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                            09-13-2024, 01:17 PM
                                          • Gibon378
                                            Problem with stopping audio and video for no reason
                                            by Gibon378
                                            PC Specs:
                                            • CPU: Ryzen 5 1600
                                            • GPU: GTX 1080 Palit JetStream
                                            • MOBO: ASRock ab350 PRO4
                                            • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                            • PSU: XFX 650W (don't remember what model)
                                            • OS SSD: ADATA SP920
                                            • OS: Windows 10 21H2
                                            Problem description:
                                            Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                            11-19-2022, 09:41 AM
                                          • perzyk23
                                            Lenovo T580 - LCD Panel problem - error 0288
                                            by perzyk23
                                            Good morning,
                                            I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                            10-25-2024, 12:42 AM
                                          • SDNarcia
                                            Dell 15R-5521 keyboard problem (KBC?)
                                            by SDNarcia
                                            Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                                            As additional information,...
                                            07-20-2024, 10:47 PM
