Nintendo wii u hand held console
  • vinceroger69
    • Mar 2012
    • 6714
    Hi guys Nintendo wii u console wont charge or turn on with a fully charged battery have these units got a pmic? as im wondering if its faulty theirs some good pictures in this tear down from post 13 thanks
    https://www.ifixit.com/Teardown/Nint...Teardown/11796
  • dragos2009
    • Mar 2013
    • 110
    • Romania
    Re: Nintendo wii u hand held console
    offtopic: don't you somehow have a youtube channel named my mate vince
    • vinceroger69
      • Mar 2012
      • 6714
      not me no but i do watch his videos, i have seen a wii u local too me with no charging fault basically same as what was in his video but as he couldnt solve his issue, i didnt buy the one i had seen on facebook sale site as was a little expensive £45.00 faulty could be a waste of cash if a main board fault
        • 31087
        that guy on utube needs to stop.
        i only watched one vid, but paying through the nose for something expecting a loose connection,
        knowing fuckall about how it works, then trying to reflow a chip with insuficient heat and no flux - fucking insane!!
        that was an xbox1 btw.
        incidentally, anything that wont charge - primary suspect is a fucked usb connector - but i think you discovered that before.
        • vinceroger69
          • Mar 2012
          • 6714
          yes on that hudl1 i had even replaced the port with another onei had (untested) i then hacked a old usb cable and soldered direct to the board power rails the hudl started up fine then so ordered new usb board that fixed all issues then, but lets say the port was fine and battery fully charged and unit still does not turn on i guess next step would of been too test the power management ic?
            • 31087
            well no, next step is to get a datasheet for it and check all the right signals are reaching it - incase of a surfacemount fuse or something failing.
            • vinceroger69
              • Mar 2012
              • 6714
              Thanks ive got a 10 inch tablet here i can practice fault finding on (china brand cracked digitizer i cant find replacement for and it wont charge) ive tried a amp meter zero amp draw, the port looks ok but will solder wires direct to board too rule it out.
              • Stefan Payne
                • 1267
                The battery is OK???
                The charging PSU is OK??
                Have you tried one of those custom Nintendo to USB Cables as its 5V to charge the WiiU Gamepad
                • flusher
                  Apple MBP16" A2141 820-01700 PMIC power cycles no boot no shorts
                  by flusher
                  Bought myself a project thing. Apple MBP16" A2141 820-01700
                  No shorts, no visible waterdamage.
                  Dead. no history.
                  All USBC ports do 20V and charging battery.
                  If you plug battery/charger PPBUS is 12.6v and all power rails like RTC, 3v3, 5v etc are present. U7800 PMIC all voltages are present APART from PPVCCPRIMCORE_PRIM_REG (not sure if it has to be present at this stage?! resistance is 40 Ohm). SSD 2.5, 0.9, 1.8 are present on both wings. Charger meter shows 30ma or something like this on charged battery.
                  But what PMIC does is that it power cycles(dropping to...
                  02-21-2025, 03:12 PM
                • gabri2211
                  Xbox Series X Console Won't Turn On - Broken Nexus Connector on Mainboard
                  by gabri2211
                  Inside the console there is a small circuit board (see photo) that contains the main power switch, the one on the front.
                  This circuit board connects to a 10-pin flat cable called NEXUS that terminates on the motherboard.
                  This NEXUS connector broke.
                  Can anyone tell me, while waiting for a replacement, if it's possible to turn on the Xbox by disconnecting this circuit board and making some modifications (like adding a small power button) on the motherboard?
                  The Xbox has a power supply that provides 12 volts on all outputs, so the power...
                  07-28-2025, 07:13 PM
                • stormanimal83
                  Nintendo Switch picofly installed cause parental lock how to get Master Key for restoring OFW
                  by stormanimal83
                  i bought a use console from ebay fixed it and it has parental lock. seller wasn´t helpful and nintendo either cause they don´t support used devices as they told me per mail. thanks for the bad support here in germany. was totally upset as i read the answer to my mail from 1 week ago.... there was no other way to get rid of that code rather than modding the console cause i didn´t even had the device id as it´s a patched V1 and for getting masterkey on salthax there is the need to type in the device id which was unknown in this case... i did a mistake. after the repair i entered my wlan and...
                  08-04-2024, 01:47 AM
                • fab13
                  Nintendo Switch lite shuts down after nintendo log and replaced M96T36o
                  by fab13
                  Hello everyone
                  After checking the defective USB-C port and close to a short circuit on the M96T36 chip (8ohm) I have changed both components.
                  I specify that there is no other short circuit or heating component(Vu thermal camera)
                  First, the problem arises: Error 2101-0001 after the start-up screen ("Nintendo" logo), poor soldering.
                  Secondly, I install a new M96T36 and the problem I have is a brief display of the "Nintendo" logo (no short circuit, no sure charge chip, no sure charge port, no sure charge management chip percentage)....
                  08-23-2023, 10:54 AM
                • arahban
                  Apple MacBook A2442 faulty PMIC - Question about possible replacement
                  by arahban
                  Hello Gentlemen,
                  I am working on an apple MacBook A2442 board pn 820-02098-A with a visible short on the PMIC U7700 MVK-PLUS as per the schematics
                  I have a donner board from apple macbook pro m1 A2338 PN 820-02020 and I saw that the PMIC U8100 TMLT46B0-JPE could be a possible replacement for the U7700
                  Can you please help me confirm if the U7700 can be replaced with U8100 ?
                  APL1098 is it the same as APL1096
                  Thank you very much in advanced
                  Ahmad
                  12-23-2023, 05:25 AM
