hy1908 mosfet equivalent .hoverboard
  • petehall347
    • Jan 2015
    • 4450
    looking for equivalent or exact replacement in the uk .. these seem to be Chinese made .
    same as these ...https://www.aliexpress.com/item/10PC...758503553.html
    its for motor control in a hoverboard i just got given to play with .
    • 31294
    Re: hy1908 mosfet equivalent .hoverboard
    broken link.
    what's the part number?
    • diif
      • Feb 2014
      • 6978
      • England
      The link doesn't seem to work.
      I found these on RS http://uk.rs-online.com/web/p/mosfet...stors/7983047/ and http://uk.rs-online.com/web/p/mosfet...stors/7917810/
      • petehall347
        • Jan 2015
        • 4450
        Originally posted by stj
        broken link.
        HY1908
        T0220 case
          • 31294
          data
          • petehall347
            • Jan 2015
            • 4450
            have been rooting round on ebay and found a complete board kit plus other bits for £22 brand new so its a no brainer really .. just trying to revive the battery pack first as they are bloody expensive .
            • petehall347
              • Jan 2015
              • 4450
              there are 10 dead cells and 10 good cells in the pack ..looks like i have a battery pack to rebuild now ..
                master hoarder
                • May 2008
                • 12175
                Be careful with the Lithium batteries in those cheap hooverboards. They may be unprotected. And if dealing with cheap or recycled cells, you've got a fire hazard on your hands.
                That aside, why do people even call these devices "Hooverboards" when they don't hover at all!
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  too many of these shit "hoverboards" have no monitoring taps to a bms.
                  10s li-ion with no bms=FIRE!
                  • tofik
                    MOSFET equivalent K8A60DA
                    by tofik
                    Hello guys,
                    I have a shorted MOSFET K8A60DA with the following characteristics:
                    Type Designator: TK8A60DA
                    Marking Code: K8A60DA
                    Type of Transistor: MOSFET
                    Type of Control Channel: N -Channel
                    Maximum Power Dissipation (Pd): 45 W
                    Maximum Drain-Source Voltage |Vds|: 600 V
                    Maximum Gate-Source Voltage |Vgs|: 30 V
                    Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
                    Maximum Drain Current |Id|: 7.5 A
                    Maximum Junction Temperature (Tj): 150 °C
                    Total Gate Charge (Qg): 20 nC
                    Rise Time (tr): 25 nS
                    Drain-Source
                    07-19-2023, 05:18 AM
                  • dreico33
                    AON7403 Mosfet Equivalent
                    by dreico33
                    Hellow guys,
                    I am trying to replace an AON7403 Mosfet but i dot not have in my stock the same. So i wonder if there is any equivalent to this Mosfet.
                    Thank you very much.
                    11-16-2024, 09:28 AM
                  • Jane
                    How do you test MOSFET in laptops ?
                    by Jane
                    I tried to use this method:
                    Testing an N-channel MOSFET:
                    Step 1: Discharge the Gate (turn off the MOSFET)
                    Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                    Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                    Step 2: Charge the Gate (turn on the MOSFET)
                    Now, place the red probe on the Gate (G) and the black probe on the
                    09-27-2024, 03:31 AM
                  • mohamed mm
                    looking for equivalent mosfet for (IR3598MTRPBF)
                    by mohamed mm
                    I'm looking for an equivalent dule mosfet for (IR3598MTRPBF - Dual MOSFET Driver, High Side, and Low Side, 4.0V to 13.2V Drive voltage, 20 ns delay, QFN-16)
                    it's for motherboard ram voltage.
                    I hope someone can help me.
                    Thank you.
                    11-01-2023, 07:28 AM
                  • jackx
                    equivalent MOSFET 4C09B
                    by jackx
                    hello brother
                    i need equivalent MOSFET 4C09B
                    05-27-2024, 03:41 PM
