looking for equivalent mosfet for (IR3598MTRPBF)
  • mohamed mm
    • Nov 2022
    • 41
    • India
    I'm looking for an equivalent dule mosfet for (IR3598MTRPBF - Dual MOSFET Driver, High Side, and Low Side, 4.0V to 13.2V Drive voltage, 20 ns delay, QFN-16)
    it's for motherboard ram voltage.
    I hope someone can help me.
    Thank you.
  • PeteS in CA
    • Aug 2005
    • 3582
    • USA, Unsure of Planet
    Re: looking for equivalent mosfet for (IR3598MTRPBF)
    Looks like Infineon bought that part of International Rectifier. Not sure if DigiKey operates in Hyderabad, India, but https://www.digikey.com/en/products/.../IR3598/286645 . If it doesn't, maybe Infineon has a distributor there.
    PeteS in CA
    • tofik
      MOSFET equivalent K8A60DA
      by tofik
      Hello guys,
      I have a shorted MOSFET K8A60DA with the following characteristics:
      Type Designator: TK8A60DA
      Marking Code: K8A60DA
      Type of Transistor: MOSFET
      Type of Control Channel: N -Channel
      Maximum Power Dissipation (Pd): 45 W
      Maximum Drain-Source Voltage |Vds|: 600 V
      Maximum Gate-Source Voltage |Vgs|: 30 V
      Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
      Maximum Drain Current |Id|: 7.5 A
      Maximum Junction Temperature (Tj): 150 °C
      Total Gate Charge (Qg): 20 nC
      Rise Time (tr): 25 nS
      Drain-Source
      07-19-2023, 05:18 AM
    • dreico33
      AON7403 Mosfet Equivalent
      by dreico33
      Hellow guys,
      I am trying to replace an AON7403 Mosfet but i dot not have in my stock the same. So i wonder if there is any equivalent to this Mosfet.
      Thank you very much.
      11-16-2024, 09:28 AM
    • Jane
      How do you test MOSFET in laptops ?
      by Jane
      I tried to use this method:
      Testing an N-channel MOSFET:
      Step 1: Discharge the Gate (turn off the MOSFET)
      Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
      Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
      Step 2: Charge the Gate (turn on the MOSFET)
      Now, place the red probe on the Gate (G) and the black probe on the
      09-27-2024, 03:31 AM
    • jackx
      equivalent MOSFET 4C09B
      by jackx
      hello brother
      i need equivalent MOSFET 4C09B
      05-27-2024, 03:41 PM
    • Nooy
      VGA MOSfet permanently shorted and loss of MOSfet pad
      by Nooy
      Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
      I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
      02-14-2024, 02:26 AM
