simpson 160 battery lead help
  • awyatt2
    • Feb 2012
    • 407
    • america
    I have an old simpson 160 vom and the battery terminals needed cleaning so I removed the board separated the battery box and found the 22v battery lead broken at one end. anyone know where this wire goes on the board or switch? an old friend who has passed left me this meter and a bunch of other stuff because I used to help him at his tv shop, I would like to get it back in working shape if I could. I think it was the wire broken rather than the battery terminal.
  • R_J
    • Jun 2012
    • 9628
    Re: simpson 160 battery lead help
    Here you go
    • redwire
      • Dec 2010
      • 3912
      Wow, these analog multimeters are still for sale.
      The 260 is quite big but the 160 needs the 22.5V battery.
      22V (+) goes to 1.5V (+) and ohms adjust pot.
      22V (-) goes to switch
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8715
        How have those of you who have these old meters been dealing with batteries for these units?
        I sort of feel lucky with my not-as-good Eico 555 which uses 4xAA's for the Rx10k range...
        • awyatt2
          • Feb 2012
          • 407
          • america
          batteries plus.
          • awyatt2
            • Feb 2012
            • 407
            • america
            thanks for the help, got her running perfect now. yep, got 2 260's the 160 which is close to new looking. I didn't plan on using it as I have flukes and triplett dmm's but should the need arise.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8715
              Nice that batteries plus still carries that battery. I would have thought they were unobtanium due to the infrequent use of them.
              I actually use the Eico more than once in a while, mainly because I can measure voltage or current without having to worry about battery drain down and not need a power cord...
              Not much reason to measure resistance on the meter, however.
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • emeskay
                Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                by emeskay
                We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                08-06-2024, 07:13 AM
              • mkdj
                by mkdj
                Mark and model: ASUS X571
                Tests already made:
                - I have removed...
                07-14-2025, 09:16 AM
              • techfreak9356
                Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                by techfreak9356
                09-14-2023, 11:10 PM
                NVDC charger configuration...
                11-05-2024, 03:28 PM
