Nutri Ninja Blender power conversion question
  • grss1982
    • Mar 2007
    • 225
    • Philippines
    Hi guys,
    My knowledge in terms of appliances is way behind my knowledge with computers.
    Anyway long story short, my aunt in the U.S.A. gave my mom this appliance:
    https://www.amazon.com/Professional-.../dp/B00P2PFMV0
    So naturally since I'm from the Philippines and we use 220V instead of the 110V this appliance requires, I'm a bit confused on how to go about this.
    My first was to use a cheap ass automatic voltage regular (AVR) that I use on my spare computer since it has a 120V plug along with 3 220v plugs. See here: http://www.lazada.com.ph/eco-power-5....0.qBGZIz&ff=1
    But then that 1000W on the box of this appliance made me wonder if I needed some special voltage regulator/converter make this work while in my country.
    Maybe something like these:
    a) http://www.lazada.com.ph/imarflex-hd....0.qBGZIz&ff=1
    b) http://www.lazada.com.ph/akari-avr-s....0.qBGZIz&ff=1
    Any help with this would be very much appreciated.
    CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
    GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti / GTS 450
    Main Driver: Intel i7 3770 | Asus P8H61-MX | MSI GTS 450 | 8GB of NO NAME DDR3 RAM (2x4GB) | 1TB SATA HDD (W.D. Blue) | ASUS DVD-RW | 22" HP Compaq LE2202x (1920x1080) | Seasonic S12II-620 PSU | Antec 300 | Windows 7 Ultimate with SP1
    Re: Nutri Ninja Blender power conversion question
    Why can't you just get step down transformer?
    • grss1982
      • Mar 2007
      • 225
      • Philippines
      So you're saying it does not matter that the appliance needs 1000 watts?
      As long as it's a step down transformer that gives you 110v the appliance will work just fine.
      Sorry. Not really familiar with wattages and what not.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        You need a step down transformer that can supply 1000w
        I.e. something like this but shipping will be a killer if it's genuine.
        Because it should be quite heavy, so try to find one locally...
        http://www.ebay.com/itm/Step-Down-Up...-/282410276376
          • 31199
          tools used on construction sites are usually 110v,
          so places that supply that stuff have big stepdown transformers.
          110v colourcode is yellow btw.
            master hoarder
            • May 2008
            • 12175
            An acquaintance of mine had one of those. Seemed a bit light for the advertised power output (I think his was 1.2 kW). But not too bad. Worked okay. I'd say it was probably 1.2 kW peak - i.e. capable of providing that power for a few minutes maybe. Definitely not continuous. But for an appliance that is ON just a few minutes, that might be alright.
            Also keep in mind that a lot of these cheap step up/down transformers like to give you a rating in Watts, but in reality, that's probably their VA rating. This difference doesn't matter if you use it to drive a resistive load, but can make quite a difference with an inductive or capacitative load.
