Long shot, but as the title says i need dumps of EPROMs of a Tektronix 2212 scope.
Need EPROM dumps for Tektronix 2212
Follow the white rabbit.Tags: None -
Re: Need EPROM dumps for Tektronix 2212
dang...condolences. How did you determine your rom images are toast? Did it fail boot checksum?
I wonder if I should pull the images of my Tek scopes before they exhibit Alzheimer's, except some of the eproms are soldered in... -
Yep. Failed to boot.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.Comment
I guess that's the unfortunate part of these computerized scopes...
My 2465 probably would behave the same if the roms get amnesia, despite being a full analog scope with no storage. I was able to find some EPROM images for 2465s but not the same as the ones I have in the scope. I should archive the EPROMs as I have no clue if they're the same or compatible with mine.
My 2440 is completely digital, no analog display possible. This scope has so many roms as it has three processors (waveform, main, and front panel)... Unfortunately the waveform processor ROMs are actually on OTP ROMs as EPROMs available at the time weren't fast enough at 0WS. No idea how I should back these up...
I think my scopes are 1980s vintage, probably 5 to 10 years older... my eproms are probably teetering on the edge if yours gave up
^ ill check over there....Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
by repair-itI am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
by whelanm87Hi everyone,
I’m working on a non-booting HP Envy x360 2-in-1 laptop and need verified firmware dumps for both the main BIOS and EC chip. I’ll be posting my own backups for reference and comparison.
🔍 System Details- Model: HP Envy x360 15-fe0053dx
- Product Number: 7HVO3UA#ABA
- Build ID: 23WW2GQZ6D
- Motherboard: JPR50 LA-M794P Rev: 1.0 (2023-03-03)
- Motherboard SPS: N30979-ABA
- LCD SPS: N49271-601
- Date Code: 172380
- Keyboard Type: 0
- Feature Byte:
3XeB7kN7.Ba.aqewkwBiBVuhcbdxYPgB
hZnp.praepq0Md4qkdf
🔧 Chip Info- Main BIOS chip: Winbond W25Q128JVSQ
Channel: BIOS Requests ONLY!
by SMDFleaJust a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
the infamous **"Endpoint Security" error message.
Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
The offsets and file sizes are part of the naming convention i`ve used for the extracted
files.
hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
filling everything after...-
need eprom Canon G102006-09-2025, 09:55 PM
- Loading...
