need eprom Canon G1020
Help me,need eprom Canon G1020
by REBZSaludos colegas, simplemente deseo compartir 3 respaldos de la eprom canon g3100.
Por si a alguien le sirven. A mi solo me funciono el primer par de archivos, ya que 1 de las spi flash era diferente.
Solo descompriman y reprogramen; yo use el tl866 plus.
el archivo de 8mb es para el lado del jack usb y el archivo de 2 mb es para el lado contrario.
Greetings colleagues, I just want to share 3 backups of the canon g3100 eprom.
In case someone is useful.... -
by CatisfactionHi all,
since my second device of this model number now died due to Canon being service unfriendly, I'd like to reset the counter myself.
This model of printer seems to be on non of the eBay sellers and other suppliers support lists for the Canon Service Tool. Other forums suggested the v5103 version of the tool, which did not work unfortunately.
Has anyone maybe experience with this exact model?
Thank you!07-02-2025, 07:46 AM -
by joaquinmjuanHello, I have a Canon TS8350 printer. The problem is that when I turn it on, "CANON" appears on the screen, but it never goes away. You can leave it on for a whole day, and it doesn't go away. Does anyone know how to fix this? I've tried unplugging it, but nothing. I've also tried holding down POWER, but nothing. In fact, once it turns on, it can't be turned off with the Power button. I've also held down Power and then plugged it into the Power supply, and the power light flashes once and doesn't turn on, but then when I press Power again, it turns on. Currently, it's a nearly new paperweight,...05-07-2025, 12:26 AM
by bamdad61Dear folks, recently got a canon dr-1210c and it worked perfectly just for one day. Right now it shows all possible errors on the screen and do nothing. I tear down the device and found a 32 pin plcc flash chip. I thought reprogramming firmware might be helpful. The firmware update file from canon support include a dll file which doesn't help. So if anyone has the dump it would such a great favor to share.04-15-2025, 02:43 PM
by shybearhi,
I've here this printer that is "locked" because Ink Absorber waste ink Counter is full so when I power on it give a sequence of 7 blinking orange LED in sequence with green power ON led.
Reading a lot over Internet it seem that is an "use&trash" model so there isn't a way to reset manually this counter and also seems that it is not possible to enter in Service Mode status to reset with Canon Service Tool utility.
This is really suck because I cleaned already the printer and bought both new cartridges!!!
Working around for a while I finally... - Loading...
