Bosch drill need help source cap
  • zomi
    • Nov 2011
    • 509
    Need help find a repalcing supressor cap
    detials are on the pic
    • 31199
    Re: Bosch drill need help source cap
    what country are you in?
    • zomi
      • Nov 2011
      • 509
      Sorry uk 240v
      • R_J
        • 9588
        The bosch part number is 1617328027. Thats actually 3 caps in one, 1 - 0.15uf and 2 at 2700pf at 250 volt, You should only need to replace it with a 0.15 uf 250 volt Polypropylene, or you can go with a higher voltage, 275, 300, 400, 600 depending on the room in the drill.
        • zomi
          • Nov 2011
          • 509
          So 0.15uf 300v to give it some more headroom
          What do I do about the 2 legs on one side
          aS in the original one we have 3 legs
          I can just attach extra leg to one side ?
          thanks
          • R_J
            • 9588
            Maybe provide the model of the drill, I don't know how the original was hooked up so I would not know which wire to leave off etc.
            What is wrong with the original cap? I believe its there for noise suppression only.
              They are safety X/Y caps and rated at 250 VAC so they not just any caps, they are noise suppression. Are they bad or something? DRILL will work without the caps but it will inject lots of noise into the power line.
              the 0.15 is the X cap across the HOT (PHASE) and NEUTRAL.
              The 2700pf Y caps, one will be between HOT and safety GND, another one will be between NEUTRAL and safety GND, these two cap are small in value so not to have lethal leakage current to the safety GND.
              BTW, most film cap Voltage rating are in DC, not in AC.
              • zomi
                • Nov 2011
                • 509
                the orginal blew up
                added new pics
                  • 31199
                  you probably need the original, a "delta cap" is going to take up more room.
                  http://www.maplin.co.uk/p/delta-supp...n-filter-rg21x
                    Yep, you will need the original one since you do not have the room to put in 3 discrete caps in that mold.
                    • zomi
                      • Nov 2011
                      • 509
                      Thats what i thought, new switch it is.
                      Can't find the original
                        • 31199
                        ask bosch, they have no problem supplying spares.
                        • zomi
                          • Nov 2011
                          • 509
                          They only sell it as a complete switch
                          not the cap alone.
                            • 31199
                            bastards.
                            • R_J
                              • 9588
                              If you google 1 617 328 026 that brings up the same value cap but slightly different mounting
                              • zomi
                                • Nov 2011
                                • 509
                                thanks
                                • Lvsitano
                                  Asus X532FL 3.2V at source and gate
                                  by Lvsitano
                                  I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
                                  First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
                                  I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
                                  First...
                                  06-26-2024, 02:13 PM
                                • Petr0x
                                  Bosch 12V and 18V chargers modification
                                  by Petr0x
                                  Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
                                  You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
                                  Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
                                  05-24-2024, 01:00 PM
                                • CapLeaker
                                  Bosch Nexxt 500 dryer blinking start button - no start fix
                                  by CapLeaker
                                  My Bosch NEXXT 500 dryer quit today, press start nothing happens and the start button just keeps blinking. Not cool. Reset the dryer, same thing.
                                  Even so the buttons feel good, my problem was the start button smd tactile switch on the PCB. Cleaned the switch with alcohol followed with Deoxit and the sucker runs like a champ again.
                                  I like these easy evening fixes!
                                  12-07-2023, 04:38 PM
                                • LarrySabo
                                  Samsung ProBook NP767XCM-K1CA battery connector replacment source?
                                  by LarrySabo
                                  Tonight I broke the battery connector on the motherboard of this laptop and need to source a replacement. See pictures. The marking seems to read B6u. The sticker on the motherboard reads TCZRFN6X00230 P03AJD BA92-20746B 06 29. If someone could suggest a proper part number and source, I would be very grateful....
                                  12-04-2024, 09:10 PM
                                • DanielCoffey
                                  Bosch GRA53 36V Lawnmower - no motor
                                  by DanielCoffey
                                  Hi folks. I have a Bosch GRA53 36V lawnmower that has developed a fault and will not spin the blade.
                                  I should say for the purposes of guiding what how you can explain things to me that that I have only modest knowledge of electronics, own a basic multimeter and soldering iron.
                                  The mower is four years old, out of warranty, discontinued and the brand has been sold to Honda who have iterated on the design a couple of times and now sell their own 36V mower. My mower was effectively a prototype when Bosch tried the 36V Bosch Professional range of garden equipment which...
                                  08-06-2023, 12:40 PM
