Original Xbox Replacement Caps
  • Mike.F
    • Jun 2023
    • 6
    Re: Original Xbox Replacement Caps
    Well after 20+ years my orig Xbox 1.0 finally started to Frag a couple of days ago.
    The 4 Caps near the Cpu are leaking from the top. (the right most cap isn't)
    The clock cap leaked all over the board too.
    I removed the clock one and cleaned up the MB using 91% rubbing alcohol with Q-tips.
    I couple of questions:
    Where do I buy the Cpu replacement caps? Links please. (I'm in NH, USA)
    Is a 15watt iron ok? That's what I used to remove the clock cap.
    I also have a 45watt de-soldering red bulb (radio shack) iron too, is that ok to clean the holes of solder? (I didn't use it yet)
    The pic shows the cpu caps, I removed the orange stuff leaking from the top to see the writing on them.
    Thank-you, Michael
    • jayjr1105
      • 281
      Thank-you, Michael
      https://www.digikey.com/en/products/...AAE014/6196333
      You may struggle with a 15w iron, especially when trying to clear the holes. You may have to use the wiggle in and out method heating the two holes off and on.
      Ryzen 3600x
      16GB Patriot 3600MHz
      MSI B450 Gaming Plus
      MSI Air Boost Vega 56
      Acer 32" 1440P Freesync
      Rosewill Capstone 750W
      Hakko FX-888D Station
      FX-8802 Iron
      MG Chem .8mm 63/37 RA 2.2%
        • 31087
        you have no chance with 15w
        a 40w iron is still difficult.
        you may be able to do it with a 25w iron by clearing the holes with a stainless-steel needle
        • Mike.F
          • Jun 2023
          • 6
          So the 45watt de-soldering red bulb iron is safe; as in not too hot??
          Also thanks for the link at digikey.
          Michael F.
            • 31087
            well, it's not temperature controlled so it's a bit risky.
            use it fast - dont use the bulb, it wont work anyway.
            just melt the solder and rock the cap out - clean the hole(s) out later
            • Mike.F
              • Jun 2023
              • 6
              Well I received the Caps from digikey from the link jayjr1105 posted.
              When looking at the picture from NeMesiS34 xbox 1.1 board, the numbers are a little different on the cpu caps then the one's I have.
              Example:
              His: K759 -- mine: K750 1st line
              his: 6.3T44 -- mine: 6.3V18 2nd line
              his: 1500 -- mine: 1500 3rd line
              Does it matter; just to be sure ?
              Thank-you,
              Michael F.
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                #207
                See page 12 of the datasheet, first line is series, second is voltage withstand rating and production date.
                Third is capacitance.
                • Mike.F
                  • Jun 2023
                  • 6
                  I'm still trying to get my 1.0 xbox working, but it's not there yet.
                  Things I've changed so far:
                  I've removed the clock cap and cleaned around it.
                  Replaced the 5 1500uf CPU caps that were leaking on their tops.
                  Tried a different power supply; no change.
                  The next thing I'd like to replace are the 2 power supply caps near the power connector.
                  The thing is they are 3300uf 10v caps (C1G1, C2F3) on my board.
                  NeMesiS34's reference guide lists them as 2200uf- 10v, and in his pictures only used 2200uf- 6.3v.
                  Shouldn't I at least use 2200uf 10v polymers or try to find 3300uf?
                  Sorry I'm not that familiar with capacitor ratings.
                  Michael F.
                    • 31087
                    what exactly is happening?
                    and why does the picture look like you bent the legs outward on those polymer caps?
                    did you order the wrong diameter ones? xbox needs 10mm caps
                    • Mike.F
                      • Jun 2023
                      • 6
                      I ordered these that jayjr1105 suggested in a previous post:
                      Yes the leads didn't match up the holes, that's why their hovering over the MB
                      The xbox still has the original problem of FRAG, but sometimes will boot-up and work for a few minutes before freezing up.
                      The 2 3300uf capacitors don't look bad, no leaks/Bulge. Can they be bad without any visual signs?
                      Thank-you,
                      Mike
                        • 31087
                        what caps are on the psu?
                        is it delta or foxlink?
                        • Mike.F
                          • Jun 2023
                          • 6
                          I have 2 power supplies.
                          My original is an NMB Technology.
                          I also bought a replacement, it's a Foxlink.
                          The guy that sold me the foxlink claims it's working fine and was tested.
                          My Xbox behaves the same way using either supply, so I guessing it's still the system board.
                          Is changing the 2 3300uf's a logical step forward?
                          Thank-you,
                          Mike
                            • 31087
                            probably not the 3300uf caps,
                            this is where test gear is usefull - it may be a smaller cap or one related to the ram or nvidia chip.
                            if the fox psu has any 1200uf caps on it - they may be suspect.
                            that said, i'v not seen a u.s. one so it may be different from the 230v ones
                            • jayjr1105
                              • 281
                              I found this interesting, an Xbox with two 3300uf Sanyo's and three 1500uf UCC KZE's. I've never seen them mixed like that before. Always five 1500uf's or three 3300uf's.
                              Ryzen 3600x
                              FX-8802 Iron
                              • gcrezz
                                GameConsoleRezz
                                • Jul 2024
                                • 14
                                Are you sure they haven't just been replaced?
                                • gcrezz
                                  GameConsoleRezz
                                  • Jul 2024
                                  • 14
                                  Originally posted by NeMesiS34
                                  I've been modding Original Xbox consoles for over ten years.
                                  As these things age I find myself becoming more of a refurbisher.
                                  The most common problem is the clock capacitor which tends to leak.
                                  This is illustrated in the first 2 attached pictures below.
                                  The faulty capacitor is a SuperStor 1F 2.5v SuperCap (console v1.0 to 1.5)
                                  It wasnt until the final Original Xbox version 1.6 that the cap was replaced,
                                  with a Nichicon 1F 2.5v Gold SuperCap, as seen in the 3rd picture.
                                  I came across and have been looking for replacement caps at "mouser.com"
                                  I've noticed that smaller caps like 22uf 25v have a life span of around 2000hrs
                                  Medium sized have life span of around 5 to 7k hrs and 10k for the largest (psu) caps.
                                  I'd like these console to last another decade, I'm considering replacing most,
                                  if not all caps on the motherboards and power supply units.
                                  The 4th picture is a Xbox version 1.0 motherboard (with cpu fan)
                                  13x 25v 22uf Nippon SMG
                                  6x 25v 100uf Nichicon VR
                                  3x 16v 1500uf Nichicon PW
                                  2*x 10v 3300uf Nichicon PW
                                  1x 10v 680uf Nichicon PW
                                  5x 6.3v 1500uf Nippon KZE (6th picture)
                                  1x 1F 2.5v SuperStor
                                  The 5th picture is a Xbox version 1.1 motherboard (without cpu fan)
                                  1*x 10v 3300uf Nichicon PW
                                  5x 6.3v 1500uf Unidentified Solid Cap (7th picture)
                                  My Questions:
                                  I have little experience and limited knowledge in regards to caps.
                                  1) Would i need to replace solid caps with other solid caps or can I use wet caps?
                                  2a) Would it be better to use caps with a higher ripple current and lower leakage current?
                                  2b) Would it be better to use Nichicon HD series over PW series?
                                  3a) Any advantage in using higher voltage caps whilst maintaining capacitance?
                                  3b) For example 22uf 50v over 22uf 25v or 1500uf 10v over 1500uf 6.3v, etc...
                                  4) What would be a better clock cap alternative to the SuperStor 1F 2.5v?
                                  Thanks in advance, Nemo
                                  As far as the supercaps themselves, you do not need to replace them on the 1.6 versions of the boards. If your looking to put something in there that's going to last a long time, I just scrapping the idea of using a call at all and instead install rechargeable lithium button batteries. The Sega CD model 1 used then and I have yet to open one up where they needed replaced and they're over 30 years old.
                                  Use aluminum caps, not wet.
                                  Hope this helps.
                                    • 31087
                                    using Lithium-vanadium or other rechargable cells in place of a super-cap can go boom.
                                    they have to be charged with a very low current.
                                    • Dan81
                                      SNES-powered
                                      • Oct 2013
                                      • 1866
                                      #218
                                      Figured out 1.1's VRM allows for 3x 3300uF caps, just like the subsequent "ATX" versions. Original configuration had 5x 1500uF KZEs. Included are also 4 of the 8 RAM chips that form the 128MB RAM mod.
ID:	3331828 Replacement caps are 3x 3300uF 6.3v Sanyo WG.
                                      Main rig:
                                      Gigabyte B75M-D3H
                                      Core i5-3470 3.60GHz
                                      16GB DDR3-1600
                                      Samsung SH-224AB DVD-RW
                                      Delux MG760 case
                                      • jayjr1105
                                        • 281
                                        Finally finished my full poly recap on a 1.2
                                        Ryzen 3600x
                                        FX-8802 Iron
