Identifying badcaps in a Xbox360
  • sofTest
    replied
    Re: Identifying badcaps in a Xbox360
    Originally posted by slimwadey
    I have read this thread with interest and would like to know a bit more about fitting the polymer capacitors are they the same general shape/size as the original ?
    Forgot this question.
    Polys are often the same or smaller than the 'lytics ones. If you are replacing VRM-caps, you can go down in uF, as the important factor here is ESR. I've not recaped Xbox', but usually you can replace an 820uF VRM 'lytic cap, with a 560uF poly cap.
    If you are unsure, post the manufacturer, series, capacitance, voltage and physical size of the original caps, and someone will recommend you suitable replacements.
  • sofTest
    replied
    My question is : i also have some other popped caps on the board and finding them in the UK is quite hard, these are 820uf 4v caps, can these be replaced with higher rated caps? could i use the 2200uf 6.3v ones i have just ordered or does the Voltage have to be the same ?
    To be safe, it's best to keep the capacitance (uF) the same, but you can use caps with higher voltage rating without any problem, if they fits physically. The 4v caps are probably on VRM, so use caps with same or better ESR. For sourcing caps:
    https://www.badcaps.net/forum/showthread.php?t=613
  • slimwadey
    replied
    Hi everyone ,
    I too have issues with Xbox360 caps , i have ordered my self some new 2200uf 6.3v caps to replace around 10 that have popped when i failed to properly protect them while reflowing my 360.
    I have read this thread with interest and would like to know a bit more about fitting the polymer capacitors are they the same general shape/size as the original ? i ask because when i shop for them i dont want to buy the wrong ones and visual cues are pretty helpful
    I considered buying a Reballing machine to fix the tons of 360's i could buy on fleabay and make a few quid .... but then i found out the $900 price tag of them !
    Steve
    replied
    external the dvd,
    replace the toy gpu heatsink with a cpu one from a second box and jack the fans up.
    then just mod the white-plastic air-shield for the new heatsink.
  • lkvee
    replied
    I'm trying to identify a cheap (enough) source for polymer capacitors. I found this site:
    http://thecapking.com/nich63le820.html
    I'm only planning to buy as few as possible, but I think I'm looking at ten, maybe more.
    I'm also researching cooling methods, conventional and otherwise.
  • c_hegge
    replied
    In the two last pics, all of the rubycon caps look like they are bulging. I would recommend poly-modding that unles you want the replacments to fail also.
  • lkvee
    replied
    Direct uploads of the same pictures.
  • lkvee
    replied
    Pictures of the inside of my XBox 360 Arcade (HDMI)
    http://img22.*************/img22/5944/xbox36005.jpg
    http://img710.*************/img710/1035/xbox36004.jpg
    http://img33.*************/img33/3185/xbox36003.jpg
    http://img710.*************/img710/7986/xbox36002.jpg
    http://img132.*************/img132/8949/xbox36001.jpg
    If any of them have popped, I can't tell definitively.
    The staggered row of six has the two "strongest" culprits. The tops felt like they have popped a little.
    I'm planning to get the ESR-Micro capacitor meter. I'm just not sure whether to buy 3.1 or 4.0
    replied
    i'm not reading this thread, i'm just gonna give some info.
    the towel "trick" will trash the console.
    the fault is bad cooling of the gpu because the heatsink is too small and the fan's are crippled to reduce noise.
    you cant make one reliable once it fails.
    also, the "x-clamp" under the pcb often causes the pcb to flex stressing the bga soldering.
    all 360's are shit - designed like shit and built like shit.
    i dont care if someone is an MS fanboy or the games are good - that changes none of the thing's i'v said.
    back to reheat tricks - or that should be stunts.
    you cant reflow solder without flux, crushing with washers as spacers etc is not fixing the problem, just pressing broken joints together for a while.
    if you do one thing, pull the 2 large-ish surfacemount transistors near the fan connector and link the emitter & collector pins to make the fans run flat-out.
    i deal with a guy who get's maybe 100 of these damned consoles a month - i'v seen it all.
  • Spacedye69
    replied
    I know in some 360's, if not all, the 6.3v 2700uf caps are Rubycon MFZ, which are suppose to be polymer. If they are bulging, I'd say the oven just cooked them all.
  • 370forlife
    replied
    I was thinking about flipping the rear fans around to blow in and cut a hole in the side for a 120mm fan to exhaust the air, but mine's a newer one though and doesn't get hot at all.
  • gdement
    replied
    There's many machines (360 probably among them) that run so hot that cap failures are common regardless of the brand.
    I've also seen blown Rubycon MCZ in a small form factor computer. It was just too hot, and heat reduces their lifespan.
    The endurance spec of high performance caps like the MCZ is 2000hrs at 105C. That doubles for every 10C reduction in temperature, so reasonable temperatures will last a very long time. But some machines don't have reasonable temperatures.
    If you do recap it, polymer capacitors might be more ideal. They have a reputation for tolerating heat better than conventional caps. Either that, and/or come up with some mod to improve ventilation in the 360.
    I wonder how hard it would be to mount a 360 in a bigger chassis, instead of the original shell (I've never owned or looked at one myself).
  • lkvee
    replied
    I may have found bad capacitors in my XBox 360.
    It's an Arcade version with HDMI, manufactured around 2007.
    I'm not sure if this schematic corresponds to my console:
    http://www.scribd.com/doc/23509655/Diagrama-xbox360
    From a casual visual inspection, capacitors C6C3 AND C7C1 look like their tops have blown, even if only slightly. They're Rubycons, too, rated at 820 uF, 6.3V
    I'm waiting for the battery in my digital camera to completely charge up. Once that happens, I'll be posting pictures.
  • Krankshaft
    replied
    I have never heard of this before the only fix I've heard of is the CPU and GFX overheat trick.
    A tutorial is at:
    http://www.llamma.com/xbox360/repair...-clamp_fix.htm
    Ovening your 360 as said prior to my post is not a good idea.
    As a matter of fact one of our forum members used an oven and baked caps to judge at what temp that they would bulge and fail.
    If the solder joints are cloudy thats normal since the 360 uses Lead Free Solder thats something we all have to get used to.
    If the joints are just cloudy replace the bulged caps and try to power the console on if you still get the ring of death try the above fix. If not part it out.
  • gdement
    replied
    Caps can't tolerate the heat that's required to reflow solder. You'd have to pull out the caps, and then you still have plastic to worry about. Ideally, you should try to find a way to quickly heat the immediate area that needs to be reflowed, without getting everything else so hot.
    I don't really know anything about the 360, but I've heard of that towel trick before. I don't understand how it can really work since it's not gonna get hot enough to reflow anything. If it did, the chip would probably be long since ruined anyway, ICs are more heat tolerant when they're not running.
  • Eversor
    started a topic Identifying badcaps in a Xbox360
    Hi.
    I have a broken Xbox360 here and I've been checking it. So far it really seems to be bad solder, really bad solder. Lots and lots of holes in the middle of what should be little solder dots, but I'm here for another thing.
    The thing is, I was trying an extreme version of the "towel trick" and some capicitors bulged, some, but almost all of them at the same time.
    The towel trick consists in wrapping a x360 in towels and turning it on while she has a RRoD, after some twenty minutes, take the towels and turn it on after it cools. It should turn on and be good for a few days, or if more measures are taken, be good for a long time, if not ever.
    Since that wasn't working for me, I tried a few minutes in a oven, aware of the risk that might bring to capacitors. Still, with no hot air gun around, I gave it a go.
    First time tried like two minutes, RRoD still.
    Tried again, now with a proper heatsink mod, to help put things in place and a few more minutes in the oven. All was good till I heard boiling. Allowed it to cool and took it out.
    Well, all of the 6.3v and 16v big caps were bulging, some more than others, most of them were also pouring liquid, hence the boiling.
    The interesting bit is that there are 4 other fat caps, 4v 820uF, which are apparently ok. I took them out and two of the other ones and they all measured good for capacitante. I'm looking to buy an esr meter now.
    My question is, are they supposed to bulge so easily? The bad solder points, which were a lot, all remain the same, so the temperature didn't seem enough for solder to melt, but I also don't know how much temperature it would be needed. Since most caps are good for what? 5000hours at 100ÂșC? Are they supposed to bulge so easily? Or perhaps were they prone to failure?
    They were all in some hot areas, so I'm inclined to also think that. Right, wrong?
    The thing is they are Nihicons and Rubycons, so when I looked at them for the first time, I though they couldn't be accountable for anything, but now I'm in doubt. They just bulged too easily, as far as I know.
    Any thoughts?
  • corrize
    Best way to solder LVDS connector for beginner (and qfn) ?
    by corrize
    Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
    I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
    I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
    See the test :
    https://youtu.be/bNAzC-EvqHs?t=1767
    With hot air from bellow the board, that's...
    03-09-2023, 02:57 AM
  • myth77
    UV solder mask - high temp resistent, recomendation?
    by myth77
    Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
    Is there any solder mask...
    03-28-2022, 04:04 AM
  • petemanuk
    BGA solder balls not connecting - help pls
    by petemanuk
    So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
    I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
    I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
    11-16-2022, 05:21 AM
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
  • sircastor
    Solder not reflowing - what am I doing wrong?
    by sircastor
    I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
    For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
    03-03-2024, 02:44 AM
