Re: Identifying badcaps in a Xbox360
Ok, I will try and ask around on the xbox-scene forum. They've a hardware mod section but oddly enough, I've never seen anyone attempthing a poly mod. Especially on Falcons, they don't even have the Fujitsus around the GPU but Nichicon HN!!! (Yes I know HN is good after '05/'06)
You need to check the volts in the circuit.
Good chance it's a 5v circuit and that will toast a 4v cap in no time.Leave a comment:
Hmmm. Nichicon LG. Looks good. I would be comfortable replacing with 4v . Next time I open it up for the JTAG. I want to hack the NAND to modify the I2C default fan settings. Thanks.Leave a comment:
Mouser is back. - All they have in poly @2700 is a 4v.
You would have to check actual voltage in all system conditions.
If it never goes over +4v [including Ripple] then the poly would work.
http://www.mouser.com/ProductDetail/...nyKaom4Q%3d%3dLeave a comment:
To compare caps look at ESR and Ripple
https://cdn.badcaps-static.com/pdfs/...43c4079d93.pdf
ESR - Less is better [may say Impedance in data sheet vs ESR]
[ESR is *like* a caps resistance to Ripple. Since these caps job is to pipe Ripple to the ground plane less 'resistance' to Ripple is better.]
Ripple - More is better
[Ripple rating is *like* a caps watt rating. - Tells you how much ripple it can handle without overheating internally. - Kind of like a measure of how heavy duty it is.]
Look at data sheet for the 2700uF HZ:
ESR = 7 mOhm @100kHz [or 0.007 Ohm @ 100kHz]
Ripple = 3770 mAmp @ 100kHz
[This is a very high grade of low ESR cap.]
Now go look at ESR/Ripple for LXZ & LXY.
These are much lower grades but still good brand and low ESR.
Digikey has none for poly that size.
Mouser just crashed. Can't check there on poly.
If they have a 2700uF 6.3v poly you may have to give up your first born son or a body part to get some.
.Last edited by PCBONEZ; 08-29-2010, 02:10 AM.Leave a comment:
Ah, these are Nichicon HZ... But do you know what polymer series would be a suitable replacement? Also how do HZ compare to UCC LXZ or LXY?Leave a comment:
Sorta.
They are "Functional Polymer" as opposed to "Solid Polymer".
They've pretty much kept what "Functional Polymer" is a secret [trade secret I guess] so the need for the vent unknown.
The early versions [made before 2003-ish - guessing] occasionally had problems where moisture from the air would slowly leak -in- and cause minor bloating but since then the seals have improved.
That may have been the only reason for the vent as the very new ones don't have vents anymore.
[I've replaced bloated ones on boards made in 2000-2001 and seen them on boards made from the late 90's thru 2001-2002 or so.]
There is no performance difference or known longevity difference between them and actual solid polymer anymore.
Just consider them the same as solid polymer.
.Leave a comment:
Good, so I don't have to worry about replacing those. They're all near the GPU which gets very hot. The Rubycon MFZ are 6.3v 2700uf. I can't find anything with that value that low ESR on Digikey.
Which polymer caps would you recommend?Leave a comment:
Yes,they are. Fujitsu FP caps are now under Nichicon branding.
Nichicon HZ, Ruby MCZ, Nichicon HN.
Or, you go nuts and poly the entire board.Leave a comment:
I was looking to replace the yellow Fujitsus in my Xenon with equivalent Sanyo Oscons. Are the Fujitsus already Polymer eventhough they have a K-Vent?
Also, the 2700uf Rubycon MFZ... What would you guys recommend replaceing them with as this value is a little out of the ordinary.Leave a comment:
OK. They changed the Fujitsu's for Rubycon's.
Heat gun method requires a ~carefully~ cut-out, 2 layer aluminum foil shield that blocks everything the chip(s). If you just blasted away without the shield, there's the problem. Same happens with the "oven-bake" method. Just put the new caps and you should be in good shape. Until it RRODs again...
Look into building the foil air tunnels that channel the fan draft over the GPU and CPU. Also consider investing (~$25) in the newer GPU heatpipe style cooler that places a second coil in front of the CPU cooler airflow. A fan upgrade to the Talismoon LED fans (just the regular ones, not the Turbo-switch style) is $20 well spent. A 60% increase in air volume without an increase in noise level (actually a 3dB decrease) is nice too.
There are loads of mods out there. Some make sense, some are a waste of time. YMMV
Toast
I'll look into the other mods, I have a Talismoon on its way and Ill try the aluminum shield duct.
When I heat gunned I did cover the caps with foil, although I just threw a sheet over it rather than securing it properly. I really rushed it because I wanted to get the thing fixed already.Leave a comment:
EDIT:
...foil shield that blocks everything but the chip(s).Leave a comment:
ToastLeave a comment:
What model is the system? Age?
MCZ is typical in these nowadays.
HZ is also typical. HZ(M) is the proper marking and should be under the (-) negative stripe and above the H0732.
If yours has the yellow Fujitsu 820uf/4v, and you managed to damage them, you've really gone beyond the extreme in roasting. BBQ anyone?
I don't have 820uF/4v caps, only nichicon and rubycon 820uF/6.3v. I only damaged the ones around the CPU (4 of them are buldged, another 4 have leaked and 4 of them have looked like it had a volcanic eruption). I had the heat gun on for 4-minutes, which seemed long but I blindly followed the YouTube guide anyway.
Normally I would just give up and buy a new Xbox, but I live in Australia where its a PAL region. I got my system from the states and have some games with it already. On the plus side it seems like a good learning experience.Leave a comment:
If yours has the yellow Fujitsu 820uf/4v, and you managed to damage them, you've really gone beyond the extreme in roasting. BBQ anyone?Leave a comment:
Awesome, great to hear they should work.
Thanks PCBONEZ. Your help has been invaluable.
Now for the waiting gameLeave a comment:
07 = year 2007
32 = week 32
My guess is they are HN or HZ series.
Should be written on them somewhere. - If not they may be counterfeits.
The FL is the series.
MCZ is fine for those too.
I think MFZ are just a RoHs compliant replacement for MBZ and/or MCZ.
.Last edited by PCBONEZ; 08-28-2010, 06:58 AM.Leave a comment:
Cheers,
@stj
It is a mix of Rubycon and nichicon capacitors. The Rubycons have MFZ on them. The nichicon doesnt list additional info except H0732
@Per Hansson
I plan to buy Rubycon MCZ 6.3v 820uF to replace the Rubycon MFZ 6.3v 820uF AND the Nichicon 6.3v 820uF capacitors.
They are roughly the same dimensions to the current ones although the current caps are taller (both Rubycon and Nichicon caps are roughly 22mm tall and 7mm in diameter).
I also plan to order the Rubycon MCZ 16v 1500uF to replace the current 16v 1500uF capacitor.
The current one does not have a brand on it, the other details it says on it is 105 deg C FL and it has a logo of an M with a circle around it.
The dimensions are again quite similar.
Again I appreciate all the comments and info from you guys.
RegardsLast edited by migu3l; 08-28-2010, 04:15 AM.Leave a comment:
Before placing your capacitor order do post exactly what you intend to buy here, the system is quite demanding on the capacitors, just any wont make do...Leave a comment:
by corrizeHello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
See the test :
https://youtu.be/bNAzC-EvqHs?t=1767
With hot air from bellow the board, that's... -
by myth77Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
Is there any solder mask... -
by petemanukSo I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder... -
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by sircastorI'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components... - Loading...
