Denon AVR-X2600H DAB - HDMI Ports dead
  • Data45000
    • Apr 2022
    • 9
    Hi there,
    I just wanted to watch another episode of Luficer last night and had turned on my AVR with the FireStick.
    Suddenly I heard a dull bang. "Poof"
    I noticed that several HDMI inputs no longer work at all. Some only work when a PC signal is present or only one signal on the whole input side.
    Often the picture goes black or it jerks up and down as if the signal is present briefly, but then disconnects in a loop.
    However, the front HDMI works perfectly...
    Would anyone have an idea what is defective here before I disassemble the part.
    Best Regards
    Data
  • disorder
    ps5 edm-033 dead after hdmi/usb ports destroyed
    by disorder
    hello guys,
    i need help to repair a edm-033 ps2
    history : as always hdmi port and usb ports destroyed after unplugged
    after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
    so i changed it
    now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
    but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
    i don't see any projection of liquid metal on pcb.
    01-14-2025, 12:48 PM
  • Andreasbest
    [Solved] Fujitsu Lifebook E558 USB / HDMI / DisplayPort / LAN / 3.5" jack dead
    by Andreasbest
    Hello.
    I just solved a mystery with the right USB or HDMI/Displayport or Ethernet or 3.5" jack of Fujitsu Lifebook E558 going suddenly dead.
    I realized i had 6 pieces of the same model with the exact same issue, nothing on google, neither schematics so i had to dig in my self and provide feedback here in case someone else has the same issue.
    I found out that the USB daughterboard is connected to the mainboard with 2 wide and non bending flex tapes that are 2mm longer than they should and this results in a constant pressure on flex connector and therefore eventually it cracks...
    11-26-2024, 11:50 AM
  • aliougm
    Marantz SR4003 AVR HDMI board issue, seeking for help
    by aliougm
    I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
    Connection as below:
    Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
    If I bypassed AVR then HDTV screen color be good.
    I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
    3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
    I replaced all...
    04-30-2022, 12:21 PM
  • japlytic
    Certain DisplayPort-HDMI cables can disable HDMI CEC communication
    by japlytic
    With a setup including a TV and AV receiver where HDMI Consumer Electronics Control (CEC) and Audio Return Channel (ARC) functions were working, these two functions stopped working after changing some connections (not the one between the AV receiver and TV), so I believed it was a corrupt setting in the AV receiver or TV, but when I disconnected a passive DisplayPort-HDMI cable (which a Multimode DisplayPort connector supports HDMI with a low cost passive cable or adaptor) connected to a home theatre PC, HDMI CEC and ARC functionality was restored.
    An examination of the HDMI CEC wiring...
    07-10-2022, 09:48 PM
  • spleenharvester
    Toshiba 50UL2063DB randomly rebooting with HDMI-CEC and/or HDMI-ARC enabled
    by spleenharvester
    I have this TV hooked up to only an AppleTV 4K and a Creative soundbar. Originally HDMI-CEC and HDMI-ARC wouldn't work at all, I replaced all the HDMI cables with decent UGREEN cables meeting the latest standards, now it all works perfectly but once or twice a day the TV itself reboots while watching a program, the AppleTV keeps running. I haven't fully pinned down whether it is ARC or CEC causing it yet. All are running latest firmware.
    I assume it is just HDMI-CEC being buggy as usual on a shitty Vestel machine, but can anyone think of anything I can try before disabling it?
    03-12-2025, 03:42 PM
