Honda XL 600 LM 1985-1989 PD04,Resistor blown up and losted
  • labello
    • Mar 2018
    • 258
    • italia
    Hi guys a friend of mine give me this old counter it's for Honda XL 600 LM 1985-1989 PD04.
    He opened it and found a resistor that was blown up. Then he lost it. I knowing it's not easy to fix it, but I just guess (maybe we can) thank you so much
    • 31281
    Re: Resistor blown up and losted
    9ohms or 39ohms
    remove it to test it - then test that zener diode thats probably shorted.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8706
      Re: Honda XL 600 LM 1985-1989 PD04,Resistor blown up and losted
      R2?
      That's going to be quite hard to figure out what it was, I was wondering how to derive 9Ω or 39Ω from a missing resistor... probably will need to locate an identical board or do a complete reverse engineer of the board and where each wire connects ...
        • 31281
        i missed that, was looking at the discoloured one.
        lets see the track-side to see what it does
        2 ceramics, 1 tantalum, 2 diodes and a chip to test too - i doubt that resistor killed itself anymore than epstein did
        • redwire
          • 3912
          What is the IC's part number? Is this a tachometer?
          • labello
            • Mar 2018
            • 258
            • italia
            Originally posted by stj
            9ohms or 39ohms
            Hi thanks for your reply, but on the mark R2 it's empty I mean it was a resistor there but it losted. It remain a color like roasted.
            • labello
              • Mar 2018
              • 258
              • italia
              Hello it's a tacho rmp the part number of ICI is this on the picture. I hope to clean it good enough. Thank you for your help 🙏
              • redwire
                • 3912
                Toshiba T2295A IC is used in several tachometers for frequency to voltage converter. So the circuit can be figured out. Schematic is from a GB250? I could not find the IC datasheet.
                Can you give a picture of the other side of the board.
                There's no reason for any resistor to burn up (other than the 39Ω is just for IC power/feed for zener diode ZD1).
                I think water might have got in and the resistor R2 arced or carbon-tracked on the board? The ignition coil input is high voltage, >400V spikes.
                If the burnt resistor goes to the trimpot then it is 680Ω.
                It might have damaged the IC. This might cook the 39Ω as well then if the IC is shorted.
                • labello
                  • Mar 2018
                  • 258
                  • italia
                  Hi thanks for your reply. I asked him, and he told me it was his mistake because he still restored the motorbike, and some wire about cabling was not connected to the ground on the chassis. So I look something smoking and turn everything off but unfortunately the resistor on tacho blown up. Now I don't know if the ICI is still good or it broken also
                  • labello
                    • Mar 2018
                    • 258
                    • italia
                    Sorry i forgot to say thank you for the schematic 👍
                    • redwire
                      • 3912
                      • labello
                        • Mar 2018
                        • 258
                        • italia
                        Sure... Here you are
                        • petehall347
                          • Jan 2015
                          • 4448
                          • United Kingdom
                          looks to me like it got powered backwards and the diode did its thing and blew the fuse .
                          • redwire
                            • 3912
                            The tach has reverse-polarity protection with D1. +12V is the black wire though... so I could see that mistake when running it on the bench.
                            You can't damage it connecting it up wrong. I drew the schematic.
                            It could be a shorted capacitor like C2 or C3. For the age of the tach, I would replace the 4 caps.
                            The burnt resistor is R2 is possibly (based on G250 schematic) 680Ω and worst case is 0.3W, it would not burn if the tach was connected wrong. You can put in a new resistor and power it up but it's a bit lower value but still would not burn so bad? Or the tech did something weird power it over 20V.
                            The IC is rare and the chinese offerings are apparently no good.
                            • labello
                              • Mar 2018
                              • 258
                              • italia
                              Thank for your explanation, well I'm going to put the R2 resistor and we'll see what happens
                              • labello
                                • Mar 2018
                                • 258
                                • italia
                                Redwire you was right! The bolt capacitor are almost gone the c2 has very high esr so I thought it is shorted, the low capacitor in the c3 side give me strange voltage lower than 22uf and esr is a bit higher so I will replace all of them. It could be difficult to find this one. I never see someone like this one
                                • lotas
                                  • Jan 2016
                                  • 4837
                                  • Russia
                                  This capacitor is tantalum.
                                    • 31281
                                    224 = 0.22uf, i would use a 220nf 63v polyester film cap
                                    • labello
                                      • Mar 2018
                                      • 258
                                      • italia
                                      Hey thanks. The capacitor meter shows me 0.16 uf with a high esr. 220nf 63v are you sure? The motorbike is running just 12v
                                      • redwire
                                        • 3912
                                        Here is the Honda XL600 tach schematic I drew. It's hard with no IC datasheet or missing some part values. The 470uF 6V part usually fails and gives low or erratic readings or no reading. Check the other two electrolytics as well.
                                        Polyester film caps come in 50V, 63V at the lowest. So a 0.22uF 63V MKT is OK to replace the tantalum part.
                                        Toshiba F/V IC is used in many Japanese tachometers in cars, motorcycles, mopeds etc.
                                        Maybe look at Honda CX500, Spree, Flush and Elite 50 etc. or Yamaha Virago.
                                        T2295A IC a little bit similar to T2685A used in Toyota 4AGE MR2, Pontiac Firebird, Fiero tach. or TA8029S.
                                        • x_orange90_x
                                          Sony Bravia KD-50X690E blown resistor
                                          by x_orange90_x
                                          I just picked up this tv yesterday and the previous owner said while watching tv he heard a loud a pop and then the screen went dark. I removed the back cover and found the source rather quickly; resistor R8601. A chunk of the ceramic had blown off exposing the inner wire. Due to the damage I cannot make out the colors of a couple bands. I likewise cannot find a datasheet for the power supply. I tried pulling up pictures of the same board online but the resistors have different colored bands which I half expected as I've had this happen before.
                                          The power supply is 715G8413-P01-001-0H2S...
                                          07-16-2024, 06:53 AM
                                        • redbaron1007
                                          Arcade PSU blown resistor ID
                                          by redbaron1007
                                          I'm working on one of the PSU's in my backlog today that came out of an NBA Jam arcade machine a year or so ago. The PSU is a Pan Yes brand with a model number PY-TV-C. From what I remember the 12v rail wasn't outputting anything. I opened it up and was reminded that the resistor at R28 had blown it's shell off and I have no idea how to ID a replacement for it. (see pictures) The color bands that are still intact a little are brown, black, missing band/bands, and what I'm assuming is silver. When I check it with my DMM it's reading 100ohms exactly but I don't know if that's what it's supposed...
                                          01-06-2023, 04:13 PM
                                        • mikey5791
                                          Need help to replace burned resistor in 350w atx psu
                                          by mikey5791
                                          Hi to all forum members,
                                          Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                          The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                          Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                          Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                          12-26-2024, 04:55 AM
                                        • MidnightRoller
                                          Can a resistor lose resistance after hot air?
                                          by MidnightRoller
                                          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                          02-02-2022, 11:46 PM
                                        • artvandalai
                                          What resistor ohm will work better to repair this waterpik?
                                          by artvandalai
                                          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                          01-05-2025, 04:10 PM
