Re: Sharp Microwave - no backlight
replacing all 10 was a wise move,
i found that if you replace an led in anything the brightness/colour usually doesnt match the old ones
So I found out what the problem was. 1 LED was blown, creating high resistance. Took a long time to desolder the LCD Screen. Got there in the end.
I ended up replacing ALL 10 Green LED's with Bright White LED's. LOL.
Works sweet.
Thanks for all who chipped in to help.
Kool. Sorry I didn't read properly.
Originally posted by stj View Postthe radiation is in the oven cavity, the only times you need to worry is if you mess with the magnetron or the door seal.
the back of microwaves is not sealed/screened
Originally posted by stj View Postbuy the guy a new oven then.
there are lots of things that fail in microwaves that arent related to the high voltage capacitor.
newer machines may not even have one if they are invertor-driven.
... sorry folks... never mind... but in my oppinion a microwave oven is dangereous to fix and not worth to fix... take care of what u doin and think about what i said... i would never ever open such a thing... not worth riskin´yours and others health...
Originally posted by gurj1979 View PostWhat about Q2 ? It's directly connected to the LED.
Originally posted by R_J View PostLooks like the supply for the led circuit is around 18 volts, Q1 is the regulator transistor, C4 is the reg. output cap, R4 seems to be 51Ω1W then there is another C10? 47µf/16v so the actual voltage for the leds is likely around 10~12v, the schematic gets blurry when enlarged.
Yes I had that issue with blurriness too.
Originally posted by stj View Postwell if you can get to the transistor you can test that with a meter
10 leds in series is gonna need 20-30v so thats what needs to be seen
Will update this post after some results.
Thank you guys.
Originally posted by stj View Postno, but try reading the voltage across each led instead of just blindly changing stuff.
did you meter the transistor?
Originally posted by stj View Postif the leds are in series a bad one will stop them all
having said that - it doesnt look like they are driven hard
Any idea what the tranny part number is, or equivalent?
