i built a test box to test electronic dashboards on countax mowers but need help
  • petehall347
    • Jan 2015
    • 4439
    • United Kingdom
    ok so i built a box to test the electronic dashboards on countax ride on mowers , all works fine and can test all functions with the aid of switches buttons and lights . only thing is the engine rpm that i cant check so need some sort of oscillator i can put together with parts from my stock . and need confirmation where to connect it to on the board . engine kill is short to ground and with it being connected to the coil i presume the signal comes from there .
    thinking will need 1000 to 3000 rpm variable .
    will post pics of my build later .
    • 31200
    Re: i built a test box but need help
    never presume - scope a mower if you can.
    • petehall347
      • Jan 2015
      • 4439
      • United Kingdom
      it has to come from the coil . i know you can program these boards for 1 or 2 cylinder engines .. if it came from the alternator it wouldn't matter . i could do with an oscillator that equates to between 1000 and 3000 rpm . i dont know what frequency it relates to .
      ok i worked it out i think .. 16.66 hz to 50hz .. but its 4 stroke so those figures need dividing by 4 . or does it need multiplying by 4 ?
      • redwire
        • 3912
        3,000 RPM 2 cyl, 4 stroke is 50Hz at the coil
        1,000 RPM 2 cyl, 4 stroke is 16.7Hz at the coil.
        Assuming it's not a "wasted spark" ignition system that uses one coil with two HV outputs for 2 cylinders. Or maybe this is a magneto system?
        You can make an oscillator with a 555 or a couple transistors but most tachs are looking for a HV spike or several hundred volts to trigger, not 12V pulses.
        So you'd need to add an inductor to make the HV spike.
        • petehall347
          • Jan 2015
          • 4439
          • United Kingdom
          i expect the safest way is to try low voltage spikes first and see if it works . no way i want to probe a coil with my multimeter as have killed them this way . taking my scope to one isnt going to happen . i could take a spare scope that might not even work as has been left not used for years .saying that my bench one hasn't seen power for a long time .
          will see if i can trace the route to the mcu from where the signal goes to the board
          • petehall347
            • Jan 2015
            • 4439
            • United Kingdom
            ok as promised a couple of bad pictures .. ignore the rough and ready look .its a prototype
              • 31200
              lol - thats quite a mix of led mounts
              have to start calling you Mustie2 if your gonna make a thing of small engine repair
              • petehall347
                • Jan 2015
                • 4439
                • United Kingdom
                everything apart from a dc socket that i bought is from what i had lying around here that i got off freecycle and all brand new in packets . as far as i know its the only oms diagnostic box in existence . oms is onboard management system . its made my job loads easier . next upgrade will be a 16 pin socket so i can then make the various leads for other boards . thinking of using car obd stuff for that .
                • chth96
                  How Can I test PWM DM0365R?
                  by chth96
                  Hello
                  I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                  So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                  I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                  I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                  06-18-2025, 04:14 PM
                • khelane
                  test active pfc power with lamp test
                  by khelane
                  Hello
                  I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                  Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                  Is there a way...
                  06-03-2025, 01:00 AM
                • chronic519
                  Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                  by chronic519
                  Hello.
                  GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                  Found issue with a RAM block
                  Replaced, green lines gone.
                  Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                  Used a good card to test and same results low errors 32+.
                  I am just search for some form of command to do a full test on the GPU.
                  I just ran the mats command with my good GPU and passed after roughly 40 min.
                  The repaired one, ran...
                  05-20-2025, 07:56 PM
                • alltvrepairs
                  Lg TCon test pins for screen test
                  by alltvrepairs
                  i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                  Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                  Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                  Appreciate your help....
                  06-13-2025, 06:33 AM
                • signal.quest
                  Samsung LN40C630K1F LCD TV No Backlights and Flashlight Test Fail
                  by signal.quest
                  I have been working on a Samsung LN40C630K1F LCD TV. On power up the backlights only briefly light up when first powered on then they go out (2 seconds to black). The flashlight test also fails. The sound works fine. Please see attached pics.
                  I have researched the forums a lot. I have watched the videos of trying to locate the bad CCFL or transformer and bypassing. I can't find any evidence of a bad transformer/CCFL. I verified I get 376V from the big caps to the fuse. I have used a small/cheap oscilloscope and it looks like the MOSFETs on the inverter...
                  09-30-2024, 11:21 PM
