ps4 1215 model Changed port and encoder still no video?
  • irepair559
    • Dec 2022
    • 134
    hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
    Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
    ps4 seems to boot fine blue light then solid white after a minute.
    i was wondering if anyone had the diode values of all the caps and diodes/resistors around encoder / port and underside ??
    My board is similar to this one
  • vinceroger69
    • Mar 2012
    • 6714
    Re: ps4 1215 model Changed port and encoder still no video?
    could be a faulty new encoder as a lot of fakes around also you could try asking on this facebook group for advice https://www.facebook.com/groups/console.repair.legion
    • irepair559
      • Dec 2022
      • 134
      Ok here are the Diode readings for HDMI port
      i made sure all pins on encoder are intact..
      i kept getting blown fuses with no power just testing with multimeter ?
      Maybe from the heat??
      All filters are good now and encoder looks solid.
      Here are the current readings
      • lotas
        • Jan 2016
        • 4599
        • Russia
        You have an error in reading on 1, 4, 10 pins (they should have the same as on 3, 6, 7, 9, 12 - the same resistance relative to gnd
        • irepair559
          • Dec 2022
          • 134
          ok touched up all the pins and now i get normal readings on each pin but still no picture ?? What are the readings supposed to be for a 1215a ? im getting 400s- 500s and one 600 ? check new pic thanks
          • irepair559
            • Dec 2022
            • 134
            Anyone ? Really want to figure this out i will not let it defeat me!! ��
            If readings are good that mean encoder and hdmi and filters are all good? im getting 5v to pin 18 to .. Fuse is good ? what else can it be?
            • diif
              • Feb 2014
              • 6978
              • England
              Check the resistance between the HDMI pins and encoder pins going through the filters.
              • irepair559
                • Dec 2022
                • 134
                they are good all have contiuity , if the hdmi readings are good doesnt that mean the lines from the hdmi port to the encoder are good ?
                • vinceroger69
                  • Mar 2012
                  • 6714
                  have you checked the hard drive health using crystal disk
                  • irepair559
                    • Dec 2022
                    • 134
                    ive tried in safe mode and without drive it should still produce a ps logo , even without drive safe mode should show video but doesnt . can it be something else ? Gpu? or other chip ?
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      true yes should still produce logo a faulty encoder would still be my guess
                      • irepair559
                        • Dec 2022
                        • 134
                        so 2 bad encoders ? But if they were bad i wouldnt get those readings ?
                        • throwaway327
                          by throwaway327
                          Model No: RC72LA
                          Serial No: SBNVKD001014459
                          06-18-2025, 05:52 PM
                        • An-klamm
                          Ps4 slim WLOD not HDMI encoder IC
                          by An-klamm
                          Hello!
                          I bought 3x PS4 slim in the hope that I can repair all three so I can sell two and have one for free.
                          All three had the error that no picture is outputed but the LED lights up white.
                          I have already replaced the HDMI encoder IC and one PS4 is working straight away.
                          It seems to be a different error with the others.
                          I have measured everything that I can measure in the installed state. There are 5V, 5.1V, 2.4V, 3.6V, 1V, 2V. I can't see any differences between the working PS4 and the defective ones.
                          I have measured the HDMI port and all PINs have approximately...
                          03-30-2024, 03:57 AM
                        • masoksian
                          Dell latitude e7470 not turn on .power buton on off and Run Power problem
                          by masoksian
                          I am dealing with the problem of turning on and off my Dell e7470 notebook.
                          The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                          The system does not turn on, there is no post.
                          I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                          The problem continues in the same way.
                          I tried to turn on the Fn key, nothing came to the screen....
                          02-15-2025, 12:08 PM
                        • cajoeg
                          Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                          by cajoeg
                          Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                          The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                          02-10-2025, 04:01 PM
                        • Francesc V.
                          How to simulate a potenciometer encoder?
                          by Francesc V.
                          Hi:
                          I have a Rotel amp where the main volume works badly...........going clockwise the volume goes up and down.......anticlock wise more or less the same..........it's like a fight to turn volume up or down......xDD
                          Here is the schematic.
                          My question is how I could simulate to turn volume up or down to isolate the issue......maybe it's not the encoder but it's the main board.
                          A PWM signal between pin 1 and 4???
                          Thanks in advance,
                          Francesc.
                          01-28-2025, 01:43 PM
