dell poweredge r310 bios request
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    hi all , today i got that server that didnt power on. i try read bios (3 bios chip onboard. i read one bios and saved data but cant find a .bin or .rom file for it as dell site only has hdr.
    if anyone has a bios dump (available on vina....) would be really appreciated.
    one bios chip is spansion 128mbit ( i think is sas bios) u26 code
    other is u28 mx25l3206e (i think that one is bios)
    attached file is u28 backup
    • 20865
    Re: dell poweredge r310 bios request
    here.
    • dellxps15
      • Feb 2014
      • 1588
      • italy
      tnx for the bios... flashed it but system still wont power on
      • dellxps15
        • Feb 2014
        • 1588
        • italy
        there is short on 12v yellow line.... and it tale 0,7 volt 5A but nothing get hot...
        • dellxps15
          • Feb 2014
          • 1588
          • italy
          update... was a n channel mosfet on gpu power side. after removing mosfet, put back original bios pc start. now im waiting new mosfet to see if it will ocme back to life
          edit: original mosfet was infineon n channel 090n03l and shop in town have pn0605 (40a 30v VS 55v 100A)
          should it be ok or better get same code and values ?
          • dellxps15
            • Feb 2014
            • 1588
            • italy
            today i got new cpu because pc was powering on as soon as i inserted power cable (there is a bios setting for that) but cpu was cold and no post.
            well with new cpu it's all the same....cpu is cold , no usb activity and pc doesnt post. no error code on the front panel...
            is there a schematic for that pc ?
            board code i read ul94v-0
              • 20865
              UL94v-0 is a fire standard set by UL – an American worldwide safety consulting and certification company headquartered in Northbrook, Illinois. UL94V-0 is used to determine the flammability of a specified material and the burn time associated with it.
              You can request a schematic in a seperate thread once you find the proper part number,but i don`t think its even available.
              • dellxps15
                • Feb 2014
                • 1588
                • italy
                more then schematic i removed other mosfet for gpu power because they were shorted. removed also cpu but still shorted. if i use lab psu it get 5A and 1.2 volt, but nothing get hot... and im wondering after mosfet and cpu removed what can be still shorted...
                edit: i have 3.3 volt on power btn and goes to 3 if i press it, but if i press it pc wont turn on.
                also pc power on automatically only if risers1 is connected. when it power on i cant power off keeping power btn pressed.
                i know a used mainboard is 50€ but i would like to understand why that board act like this
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
                • mikeybass
                  by mikeybass
                  04-23-2025, 04:30 PM
                • jhanra
                  by jhanra
                  in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                  11-02-2024, 04:19 AM
                • gizaha
                  by gizaha
                  02-13-2024, 07:18 AM
                • mrrubik
                  Dell Optiplex 7010 micro bad BIOS flash?
                  by mrrubik
                  Hi folks,
                  I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                  After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                  Steps I took:
                  1. Read BIOS with CH341a, verified hash twice
                  2. Patched
                  12-23-2024, 04:11 PM
