dell poweredge r310 bios request
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    hi all , today i got that server that didnt power on. i try read bios (3 bios chip onboard. i read one bios and saved data but cant find a .bin or .rom file for it as dell site only has hdr.
    if anyone has a bios dump (available on vina....) would be really appreciated.
    one bios chip is spansion 128mbit ( i think is sas bios) u26 code
    other is u28 mx25l3206e (i think that one is bios)
    attached file is u28 backup
    • 21874
    Re: dell poweredge r310 bios request
    here.
    • dellxps15
      • Feb 2014
      • 1598
      • italy
      tnx for the bios... flashed it but system still wont power on
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        there is short on 12v yellow line.... and it tale 0,7 volt 5A but nothing get hot...
        • dellxps15
          • Feb 2014
          • 1598
          • italy
          update... was a n channel mosfet on gpu power side. after removing mosfet, put back original bios pc start. now im waiting new mosfet to see if it will ocme back to life
          edit: original mosfet was infineon n channel 090n03l and shop in town have pn0605 (40a 30v VS 55v 100A)
          should it be ok or better get same code and values ?
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            today i got new cpu because pc was powering on as soon as i inserted power cable (there is a bios setting for that) but cpu was cold and no post.
            well with new cpu it's all the same....cpu is cold , no usb activity and pc doesnt post. no error code on the front panel...
            is there a schematic for that pc ?
            board code i read ul94v-0
              • 21874
              UL94v-0 is a fire standard set by UL – an American worldwide safety consulting and certification company headquartered in Northbrook, Illinois. UL94V-0 is used to determine the flammability of a specified material and the burn time associated with it.
              You can request a schematic in a seperate thread once you find the proper part number,but i don`t think its even available.
              • dellxps15
                • Feb 2014
                • 1598
                • italy
                more then schematic i removed other mosfet for gpu power because they were shorted. removed also cpu but still shorted. if i use lab psu it get 5A and 1.2 volt, but nothing get hot... and im wondering after mosfet and cpu removed what can be still shorted...
                edit: i have 3.3 volt on power btn and goes to 3 if i press it, but if i press it pc wont turn on.
                also pc power on automatically only if risers1 is connected. when it power on i cant power off keeping power btn pressed.
                i know a used mainboard is 50€ but i would like to understand why that board act like this
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
                • mikeybass
                  by mikeybass
                  04-23-2025, 04:30 PM
                • capoplays
                  Help with BIOS update on Dell G15 5515 after chip replacement
                  by capoplays
                  Hey everyone,
                  I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                  The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                  When I check the BIOS using the F12 menu Flash...
                  10-24-2025, 06:53 AM
                • Akhlz001
                  by Akhlz001
                  09-20-2025, 07:15 PM
                • Sathsul
                  Dell Latitude 5431 issues with dumping bios
                  by Sathsul
                  So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                  The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                  However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                  Today, 07:49 AM
