ASUS BIOS Downloads Source wanted
  • bigbeark
    • Jan 2010
    • 661
    It looks like ASUS has stopped providing BIOS downloads for my A7N8X2 motherboard.
    Asus Germany used to have an archive but I can't seem to find it.
    Has anyone got a source for this? This is an Award/Phoenix BIOS. Granted, the most current BIOS seems to be from 2004, so it's maybe a bit much to expect.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: ASUS BIOS Downloads Source wanted
    the '2' at the end throws me....I think I've got the BIOS for the A7N8X somewhere.....
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • bigbeark
      • Jan 2010
      • 661
      Hi, sorry its V2.0. Will work if its the latest version of the BIOS, 1008.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        It is still on their website, latest for PCB revision 2.0 is 1010 (press "expand all" or "show all")
        https://www.asus.com/supportonly/A7N8X/HelpDesk_BIOS/
        • ChaosLegionnaire
          HC Overclocker
          • Jul 2012
          • 3264
          • Singapore
          i have that issue also. the problem is that with certain browsers, it just shows a blank space where the text is supposed to be to display the bios downloads. if u dont see anything, ypu have to either try a different browser or update your browser.
          • RJARRRPCGP
            • Jul 2004
            • 6304
            Looks like the problem on the right, is NoScript not configured correctly and thus blocking required functionality, likely a JS.
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • ChaosLegionnaire
              HC Overclocker
              • Jul 2012
              • 3264
              • Singapore
              nope its not. i disabled noscript and ublock origin and the bios downloads still dont show. tried on linux firefox and winxp new moon. still doesnt show.
              but when i tried opera 12.17 (presto engine based NOT chromium based) and chrome, it had no issues. it must be a layout problem with asus' website and webpage design not playing nice with firefox based browsers.
              • diif
                • Feb 2014
                • 6978
                • England
                I run Firefox and it's displaying correctly. It's not a Firefox issue.
                It's a JS issue as RJARRRPCGP points out.
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • throwaway327
                  by throwaway327
                  Model No: RC72LA
                  Serial No: SBNVKD001014459
                  06-18-2025, 05:52 PM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • lrouw84
                  Asus vivobook s510ua bios changed to x510un
                  by lrouw84
                  Hi there,
                  I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                  I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                  01-28-2023, 01:31 PM
                • DynaxSC
                  by DynaxSC
                  06-14-2024, 03:49 PM
