GIGABYTE GA-890GPA Desktop pc bios needed
  • Romy2018
    • Sep 2018
    • 174
    • japan
    I need a working bios on this desktop motherboard GIGABYTE GA-890GPA-UD3H please the board has two bios chip
    • 20795
    Re: GIGABYTE GA-890GPA Desktop pc bios needed
    Go to gigabyte support, choose board revision, download bios,extract bios .
    https://www.gigabyte.com/Motherboard...UD3H-rev-21#ov
    • Romy2018
      • Sep 2018
      • 174
      • japan
      thanks smdflea my board is the same on the link picture you provided does this rev 2.0?
        • 20795
        Rev 2.0 https://www.gigabyte.com/Motherboard...UD3H-rev-20#ov
        • Romy2018
          • Sep 2018
          • 174
          • japan
          I am confuse because all the image are the same and no rev written on the board. I have uploaded the image of the board could you confirmed please what revision should i download
          • Romy2018
            • Sep 2018
            • 174
            • japan
            here is the image of the board could confirm please if it is rev2.0 or up?
              • 20795
              The revision number will be on the edge of the board near the ITE i/o chip .
              • Romy2018
                • Sep 2018
                • 174
                • japan
                ok thank you i already saw it its rev 2.1
                • Romy2018
                  • Sep 2018
                  • 174
                  • japan
                  when i downloaded the file for revision 2.1 it has only 1 file but this board has 2bios chip
                    • 20795
                    Xpress BIOS Rescue - google it .
                    • Romy2018
                      • Sep 2018
                      • 174
                      • japan
                      ok thanks so the other chip is the backup chip, so should i flashed only the main bios chip?
                      • Romy2018
                        • Sep 2018
                        • 174
                        • japan
                        i flashed both the same file still the same issue turns on fan spins but no display
                        • ala_borbe
                          aka Donald
                          • 1625
                          • Malta
                          error
                          Im Back... sort of...
                          • DynaxSC
                            by DynaxSC
                            11-17-2023, 10:56 AM
                          • cekcons
                            Gigabyte G1 Assasain motherboard Bios IC model or Schematic needed !
                            by cekcons
                            Gigabyte G1 Assasain motherboard Bios IC model needed !
                            Bios ic fried and I cant read the model on top.
                            Thanks !
                            07-16-2025, 01:22 AM
                          • sect-sin
                            Gigabyte XT 6800 XT Aorus Master BIOS needed
                            by sect-sin
                            I have an AORUS MASTER RX 6800 XT (non USB-C version), and my problem is that FUSION RGB is not working, it is not finding the GPU, and the RGB lights are off. There is a new firmware on the Gigabyte site which is supposed to fix this exact issue, but their Firmware upgrade does not work (I just get the highly unhelpful Erasing Flash Failed message when trying to update). I tried various internet-recommended software fixes to address this, but nothing helped, the factory Gigabyte EXE refuses to flash the BIOS.
                            My last resort would really be flashing the...
                            10-13-2023, 06:08 AM
                          • grimacelord
                            Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                            by grimacelord
                            Hello there.
                            I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                            History:
                            1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                            I searched for this error online and discovered...
                            03-15-2023, 03:29 PM
